Front Spring removal and install step by step - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Suspension
Thread Tools Display Modes
  #1
Old 12-27-2009, 07:02 PM
RollinSlow84's Avatar
RollinSlow84 RollinSlow84 is offline
RollinSlow84
Default Front Spring removal and install step by step
Rebuilding the Forum, one thread at a time.
Front coil spring removal and re-install how to. The work was performed on a Fleetwood Brougham but allipes to all B/D bodys. This is the remove spindle method, there are others ways to do it, but in my opinion this is the safer way and least likely to damage something. The other way is to unbolt the lower control arm, i've never done it that way.
First off, apply parking brake, jack up the car so your front wheels are about 3" off the ground, put on jackstands. Leave steering wheel unlocked. Take off wheels (duh), remove the old shocks, unbolt sway bar endlinks, unbolt brake caliper and tie up out of the way. Also remove ABS wheel sensors and tie up out of the way. Pull out the cotter pins from the castle nuts securing the outter tierod end, upper and lower ball joints. When all tear down is done it should look something like this.
This is the ABS wheel speed sensor location, its held in place with a 7mm bolt. If it's stuck in there twist it back and forth and easily pry it out. I guess a better way to remove a seized one would be to remove the rotor and tap it out with a punch.
Break loos the inner tierod first. Loosen the nut but leave it on to help guide the tool and help prevent damage to the threads. This picture is of the lower ball joint but shows the remval tool and the tierod is the same concept.
Place a jack under the lower control arm and apply enough pressure to somewhat compress the spring, but not enough to lift the car off the jackstands. NOw with pressure on the lower control arm break the torque in the upper and lower ball joints. Loosen the nuts but leave it on to help guide the tool and help prevent damage to the threads. Use the front end tools to seperate the upper and lower ball joints.
Remove the spindle and rotor assembly out of the way. Slowly, I repeat slowly, release tension on the floor jack to lower the control arm. Once all tension is released pull the jack out of the way. Use a prybar to un-seat the coil spring from the control arm, you might also have to kick it a few times. NOTE: I tried to use a coil spring compressor but, its not needed and just gets in the way.
There you have it. When re-installing the new springs make the sure the end sits somewhere between these two drain holes, as they are the lowest point in the control arm, to make sure your front end wil be level.
Reinstallation Tips: Make sure the upper end of the replacement coil is fully seated and centered in the upper pocket. If you choose to use the isolators use some good electric tape to take them to the coil so they don't run around on you. Once the upper end of the coil is centered, put the jack under the lower control arm and gently apply pressure as you jack up, begin prying the coil into the lower pocket. Take note on where the end of the coil is going to end up. Once the coilspring is fully seated, continue jacking apply enough pressure to somewhat compress the spring, but not enough to lift the car off the jackstands. Re-install the spindle and everything else.
Torque specs from 1996 Fleetwood FSM
Brake caliper mount bolts, 38 ft lbs
Wheel speed sensor, 71 Inch lbs
Sawaybar endlink, 13 ft lbs
Lower balljoint, 83 ft lbs then align to next slot to allow for cotter pin
Upper balljoint, 61 ft lbs then align to next slot to allow for cotter pin
outer tierod, 35 ft lbs then align to next slot to allow for cotter pin
Shock lower bolts, 18 ft lbs
__________________
2004 Suburban...What was I thinking...
1996 Fleetwood Brougham, Rear Disks, It handles now, tastefully modified
1984 Coupe DeVille, Budget Lowering Springs, 9C1 3.23 Posi/Disk Rear end, 18 and 20" Coys, awaiting 383/700R4 transplant.
1980 Malibu Coupe, Grandma fresh 100K original owner New Mexico rust free
1978 Pontiac Catalina Safari, old guy fresh 83K original owner New Mexico rust free
1996 Caprice Wagon SOLD
Happiness is driving a Wagon.
Old 12-29-2009, 06:34 AM
MrBuick (Magnum)'s Avatar
MrBuick (Magnum) MrBuick (Magnum) is offline
MrBuick (Magnum) is an unknown quantity at this point
Send a message via AIM to MrBuick (Magnum)
Default
Added to the sticky.
__________________
~Cory Magner "My name is Cory, and I'm an addict."
95 DCM Buick RMS. 14.21 at 91.79 "Jesus", Motor Swap at 85k
95 DCM Buick RMS 13.52 at 99.12 Buffman's car, Cracked Piston at 180k
96 DGGM Buick RMW 263k Stock Tranny
RAISS, Tri-Y's, Pypes X pipe, Spintech Prostreets, 3000 Edge, 3.73's, Eaton Posi, and the rest of the Bolt-ons. Fried #7 Ring.
And 5 other LT1 B-body's... Is there Rehab for this Sh*t?
  #3
Old 01-19-2010, 06:17 PM
BeaSStin's Avatar
BeaSStin BeaSStin is offline
BeaSStin is on a distinguished road
Default
Also I should add....if you have a 9c1..the springs are taller and a lot stiffer than the others..the springs are still under some pressure even with the A arm lowered fully.....DON'T STAND IN FRONT OF IT WHEN ATTEMPTING TO PRY IT FREE...IT CAN POP OUT AT YOU WITH A GOOD AMOUNT OF FORCE!!!!!! TRUST ME
If you are not completly sure of how to do this......let someone who knows what they are doing complete this task...A coil spring WILL and HAS Killed people!
__________________
'95 9c1 Caprice SS: paid $1200 143K UNDERGOING ENGINE REBUILD! Aerochambers, X-pipe, afterburners, bonnies, ss grille, monroe ss, 3 inch ex tips, indy 500 tires, TB bypass, Airfoil, Performance Trans built by MYSELF!
  #4
Old 01-20-2010, 09:39 AM
Lance's Avatar
Lance Lance is offline
Lance is an unknown quantity at this point
Post
FYI, leave the front shocks in, unbolted from the lower control arm, to keep the coil spring from popping out at you when removing it.
Also, you do not need to remove the tie rod ends.
__________________
ISSCA #2305
ECIRS #222
WAIL
95 9C1:
12.32 @ 109, ESE 357, LE2 heads, LE 224/230
12.86 @ 105, Reman 355, Z28 heads, CC 502, CPT 3, Edge 3400, 4.10, PCM4Less
96 SS:
11.74 @ 117, ERE 383, LE2 heads, AI 234/242, CPT 3, Yank 3600, 3.73, PCM4Less
12.28 @ 110, Golen 383, LE2 heads, CC 503, CPT 3, Yank 3600, 3.73, PCM4Less
13.07 @ 101, Rebuilt LT1, LE2 heads, Crane 227, CPT 3, Yank 3600, 3.73, PCM4Less
14.11 @ 95, Stock LT1, Edge 3000, 3.73, PCM4Less
  #5
Old 01-20-2010, 11:31 AM
SSandman's Avatar
SSandman SSandman is offline
SSandman is an unknown quantity at this point
Default
I know this is a FRONT overhaul thread, but I figure I would add this in as a lot of guys seem to think the rear shocks are hell without buying those U bolts (if you can get them, go for it!) but if not...
A craftsman 1/4 drive ratchet fits on top of the frame and on top of the deepest bolt just fine. I use the 1/4 drive on top and another on the bottom nut to turn it and it only takes me a few seconds to get the rear shocks unbolted. I know a lot of guys try to fit a wrench up there but the angle makes it a pain in the ass. This way makes it cake coming out and going back in.
And for the front upper isolators, I normally have better luck sticking them up in the spring pocket over the 'claws' up there. They usually stick in there pretty good unless they are real old. This way you don't have to mess with taping them to the top of the spring which is tapered anyway and may get snagged on something when trying to guide them up into the spring pocket. This comes down to preference though. If tape works for you, go for it.
And for the ABS sensor, since many end up breaking it trying to get it out, might be better off just unplugging it, unbolting the one bracket that holds the wiring to the frame and just minding the hanging wire or ziptie it somewhere to the spindle Just be careful you don't hit the sensor with the pry bar or the spring doesn't hit it on the way out but this would be unlikely I think, probably more unlikely than breaking it trying to get it out which happens a lot.
__________________
96 BBB Pro Touring- In the works- Mods list includes functional money incinerator, should have stuck to bolt-ons button, 100 dollars in mild steel MIG wire, a really expensive air compressor and a letter from Tire Rack saying nobody makes 335/35/17's anymore. (396/AI heads/D1SC)
http://www.impalassforum.com/vBullet...formance+build --frame off build up thread
Old N/A setup http://www.youtube.com/watch?v=3ZvPZi9fL8k 396, LE2 heads, TH400
  #6
Old 10-17-2010, 08:11 PM
94MI9C1's Avatar
94MI9C1 94MI9C1 is offline
94MI9C1 is on a distinguished road
Default
Also one thing to note and this is a great write up by the way, if you loosen the lower control arm mounting bolts the arm will fall further and no need to force it down with your foot and have possible damage to an ankle or something like that. Just remember to tighten them back up with full weight on the car.
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
1994 Chevy Caprice 9C1, 126,000 miles, T56, 4.10's
C6 Grandsport Brake Install C6 Z06 Wheels T56 Installation Manual
  #7
Old 10-17-2010, 08:30 PM
Sinister's Avatar
Sinister Sinister is offline
Sinister is on a distinguished road
Send a message via Yahoo to Sinister
Default
It may not be needed but this tool is priceless and I never do a spring job with out it.
There is a different style compressor that does indeed get in the way (though I MADE one work once) and should be avoided.
Still a very nice write up. One of my ABS sensors shattered while trying to remove it. So now, I just unplug the wire and remove the clamp from the frame. That way I can just remove it with the spindle.
__________________
LS powered Impala SS.
  #8
Old 10-17-2010, 08:41 PM
Mr pogo's Avatar
Mr pogo Mr pogo is offline
Mr pogo is on a distinguished road
Default
I will speak up for removing the lower control arm pivot bolts instead of the balljoint.
a good floor jack and a bottle jack to line up the bolt holes when reassembling, no fighting trying to cram a spring in at an angle.
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
  #9
Old 10-18-2010, 11:29 AM
RollinSlow84
Default
That's a good idea. I'll try it next time.
__________________
  #10
Old 10-18-2010, 11:43 AM
subssonicimpalass's Avatar
subssonicimpalass subssonicimpalass is offline
subssonicimpalass
Default
Like I was saying in my thread, this really should be a sticky. Thanks for taking the time to do this write-up!!
__________________
'95 DCM Impala SS 125,000 miles
Jax INC
CAI, no cats, 2.5" exhaust with flowmasters and H pipe, 4:10 gears, Eaton posi, PCMFORLESS tune, airpump delete, bonnies, lowered on 22"s, tinted tails, GEN 2 Tri-y's, extended upper and lower rear control arms, Yank SS3600
Supercharged stroker underway!!
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
