Broken Water Pump - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Heating/Cooling/HVAC
Thread Tools Display Modes
  #1
Old 12-28-2009, 08:26 PM
SSleepingbeauty SSleepingbeauty is offline
SSleepingbeauty has a little shameless behaviour in the past
Angry Broken Water Pump
So I have been having a no heat, engine overheating issue with my car since we had a week long freeze. I don't drive my car in the winter unless it's a nice dry day. So I decided to start up the car and let it run for awhile when I noticed my temp gauge starting to peg and ice cold air blowing out of the heat.
So I do the obvious, check thermostat, flush heater core, flush and change entire cooling system and bleed out air. Same problem
So now I am thinking it has to be my water pump. Which is a pain in the butt to remove since I have to remove my supercharger just to get to one of the bolts. Anyways after getting it off and taking it apart. The input shaft sheared right in half from the propeller inside the pump housing This pump has less than 3k miles on it. Has anyone ever have this happen before? I have had a couple of 6500 revs on this motor. (Built SC Stroker)
Anyways I think I am going with a electric pump. I was just wondering if this has happened to any one else?
__________________
2006 TBSS
1996 Impala SS
Old 12-28-2009, 11:58 PM
95wagon's Avatar
95wagon 95wagon is offline
95wagon is an unknown quantity at this point
Default
So, not enough antifreeze Sid??
__________________
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
Drag strip pics and video
My Wagon
My W-31 Cutlass
  #3
Old 12-29-2009, 12:33 AM
Default
It was mostly antifreeze. That's what surprised me? The impeller was in good shape the shaft was actually broken in half. Of course there was some wear from running the engine trying to figure out the problem.
Now that I think about it; metal shavings in the water jackets shouldn't harm the engine itself, if I flush the block out should it?
__________________
2006 TBSS
1996 Impala SS
  #4
Old 12-29-2009, 09:01 AM
B-Body Builder's Avatar
B-Body Builder B-Body Builder is offline
B-Body Builder is an unknown quantity at this point
Default
If you suspect that there are any shavings at all in the cooling system......I would thoroughly flush the entire cooling system out, starting by pulling the knock sensors out of the block and flushing the block itself 1st, then the rest of the cooling system and NEW Coolant to top it all off.......My .02
__________________
"Da Factory Rat"
95 DCM Caprice LT1
  #5
Old 12-29-2009, 01:57 PM
96 Black 96 Black is offline
96 Black is an unknown quantity at this point
Default
Don't feel bad. I just replaced a 3 year old AZ rebuilt WP in the Cady with just a couple thousand miles on it. I was getting a faint temp light after commutes and found a weeping seal hole so likely just low sys pressure.
You never know when you're gonna lose a seal, especially in a rebuilt. But I never heard of snapping a driveshaft.
__________________
. . . . . . . . . . . . . . . . . . . . . . . . "Oh Bob, It's So Big And Long!" . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
\'96 BBB: SSRI, Herter Tune, Tri-Y II, SLP SS, 3000 Edge, F/HO bars, METCO extendeds, Bilsteins, currently Vredestein Ultrac Sessanta (315/35 rear)
\'95 FTSS: total mono gray, SSRI, Anthony tune, Aero catback/H/resonators, SS bars and coils, Hotchkis LCAs, Bilsteins/Airlift 1000, NL rear discs
  #6
Old 12-29-2009, 05:33 PM
RE LAC SN's Avatar
RE LAC SN RE LAC SN is offline
RE LAC SN is on a distinguished road
Default
Just for the simple fact u have to remove sc to change wp I would def go electric...6 bolts a plug and some rtv and your back in business...easier than changin a tire..and u free up a couple ponies.
__________________
77 Chevy Caprice
80 Chevy Caprice (droppin in a lt1 and 4l60e from a 94 fleetwood)
95 Fleetwood Brougham (my daily) K&N filter, Meziere Elec. WP
Forum Jump
(c) 2007-2011 Impala SS Forum
