One rear tire further back in wheel well - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Suspension
Thread Tools Display Modes
  #1
Old 01-14-2010, 04:27 PM
SSTEVESS SSTEVESS is offline
SSTEVESS
Default One rear tire further back in wheel well
Have a 96' SS and was contemplating putting extended LCA's on it. Started looking at the rear end and could visually notice that the passenger side rear tire was further back in the wheel well than the driver's side. I saw in another post that Ghetto stated there was an old TSB on the axle having to elongate some bolt holes. I bought the car with 25,000 miles and it had aftermarket LCA's (Metco I believe). Is it possible they didn't install them correctly or do I have another problem or is it not a problem at all?
Old 01-15-2010, 10:48 AM
UMI Sales UMI Sales is offline
Vendor
UMI Sales is on a distinguished road
Default
Hello
I just wanted to suggest to you that UMI Performance offers a extended upper and lower control arms. They will allow you to recenter the rear back to the correct position. We offer it in a street version (poly bushing) and we offer it in a race (rod end) Below is a link to show you what all we have to offer!
http://www.umiperformance.com/catalo...8s3fqs1ldidi91
Brad
  #3
Old 01-15-2010, 11:16 AM
Raxstone Raxstone is offline
Raxstone is an unknown quantity at this point
Default
It could be simply that the body was not mounted squarely to the frame. It's a common occurrence that doesn't do any harm other then cosmetics. Check the position of each rear tire to the frame to see if it's actually further back.
__________________
94 9C1, 21%, 15x10's w/295's, Astro OH, Edge 2800, Built tranny, SSRI, 160 stat, Gary's Harness, ZQ8's, LT4KM, Stealth bolt, BH tune, 1.6RR, tru-trak and 3.73's, x-pype and aerochambers.
95 9C1, built tranny, Home Depot intake, otherwise stock with 404,000 Km.
  #4
Old 01-16-2010, 06:46 PM
stratman stratman is offline
stratman is an unknown quantity at this point
Default
SSteveSS,
Yea on my 96 SS I think its my drivers side rear wheel that seems to sit a bit further back then the rear passenger side wheel and I think its just a strange factory anomaly on some B-bodies, I also have the UMI standard length lower rear CAs and they sit in the same position with the drivers side slightly cocked back...and props to UMI on your wonderful suspension parts btw!!! Definite handling improvements after adding those CAs and Spohn anti-sway bars all around!!!
  #5
Old 01-17-2010, 08:46 AM
SSTEVESS
Default
Originally Posted by stratman View Post
SSteveSS,
I started looking at my car a little closer and it seems that the the drivers' side front and rear tires are furter back in the wheel wells than the passenger side is by at least an inch or so. What are the chances of getting this squared up w/o throwing something else out of whack?
  #6
Old 01-17-2010, 09:44 AM
MrBuick (Magnum)'s Avatar
MrBuick (Magnum) MrBuick (Magnum) is offline
MrBuick (Magnum) is an unknown quantity at this point
Send a message via AIM to MrBuick (Magnum)
Default
It's not off, side to side? Meaning one side the tire is sticking out of the wheel well, the other is tucked inside.
__________________
~Cory Magner "My name is Cory, and I'm an addict."
95 DCM Buick RMS. 14.21 at 91.79 "Jesus", Motor Swap at 85k
95 DCM Buick RMS 13.52 at 99.12 Buffman's car, Cracked Piston at 180k
96 DGGM Buick RMW 263k Stock Tranny
RAISS, Tri-Y's, Pypes X pipe, Spintech Prostreets, 3000 Edge, 3.73's, Eaton Posi, and the rest of the Bolt-ons. Fried #7 Ring.
And 5 other LT1 B-body's... Is there Rehab for this Sh*t?
  #7
Old 01-17-2010, 12:22 PM
Lance's Avatar
Lance Lance is offline
Lance is an unknown quantity at this point
Post GM Service Bulletin No. 53-34-03
Subject: Rear Wheel/Tire Position in Wheel Well Openings
Models: 1994-95 Chevrolet Caprice/Impala SS
Condition-
Some customers may comment that one rear wheel may appear more
forward in wheel well opening than wheel in opposite side of
vehicle or that vehicle appears to dog track when viewed fro the
rear when in operation.
Cause-
Rear lower control arm frame bracket holes pierced off location
during frame manufacturing.
Correction-
Elongate holes in rear axle control
__________________
ISSCA #2305
ECIRS #222
WAIL
95 9C1:
12.32 @ 109, ESE 357, LE2 heads, LE 224/230
12.86 @ 105, Reman 355, Z28 heads, CC 502, CPT 3, Edge 3400, 4.10, PCM4Less
96 SS:
11.74 @ 117, ERE 383, LE2 heads, AI 234/242, CPT 3, Yank 3600, 3.73, PCM4Less
12.28 @ 110, Golen 383, LE2 heads, CC 503, CPT 3, Yank 3600, 3.73, PCM4Less
13.07 @ 101, Rebuilt LT1, LE2 heads, Crane 227, CPT 3, Yank 3600, 3.73, PCM4Less
14.11 @ 95, Stock LT1, Edge 3000, 3.73, PCM4Less
  #8
Old 01-17-2010, 03:11 PM
Default
^^^^^^^^^There we go, I thought there was somethin out there about that! Although strange that it doesn't mention 1996's as mine is and I def have that symptom to some extent...
  #9
Old 01-17-2010, 07:10 PM
SSTEVESS
Default
My car is a 96 as well. The vertical alignment within the wheel well doesn't look bad but the front and rear tires on the drivers side definitely look further to the rear of the wheel well when looking from the side of the car than on the passenger side.
  #10
Old 01-17-2010, 07:15 PM
SSandman's Avatar
SSandman SSandman is offline
SSandman is an unknown quantity at this point
Default
It could be a few things. Firstly, like Lance mentioned a manufacturing 'defect'.
Also likely that the body isn't centered on the frame or a panel is out of alignment, this is very common.
Could be a bent LCA/UCA.
Could be simply that the trim on that wheel well isn't pushed all the way on. I have seen this happen and it makes it look like there is more clearance on one side.
__________________
96 BBB Pro Touring- In the works- Mods list includes functional money incinerator, should have stuck to bolt-ons button, 100 dollars in mild steel MIG wire, a really expensive air compressor and a letter from Tire Rack saying nobody makes 335/35/17's anymore. (396/AI heads/D1SC)
http://www.impalassforum.com/vBullet...formance+build --frame off build up thread
Old N/A setup http://www.youtube.com/watch?v=3ZvPZi9fL8k 396, LE2 heads, TH400
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
