ICM, symptoms when going bad? - Chevy Impala SS Forum
Impala SS Forum
Thread Tools Display Modes
  #1
Old 01-30-2010, 11:25 PM
jmccart jmccart is offline
jmccart is on a distinguished road
Default ICM, symptoms when going bad?
Hello. What are the symptoms of this when it is going bad? Starting weird when warm? Dying in gear?
Thanx.
__________________
John
94 Buick Wagon/teal/3.73/posi/Hotchkis bars & lower arms/SS wheels/Herter 87-tune/129k/Walbro 255/Flowmasters/Pypes-X/lil' Edge 2800.
Old 01-31-2010, 04:03 AM
SEOK's Avatar
SEOK SEOK is offline
SEOK is on a distinguished road
Default
suddenly dies when warm is a symptom. trouble starting while warmed up. It can get heat soaked and needs to cool off. or just gives up completely.
Do you think yours might be going/gone bad?
__________________
95 CAPRICE B4U WHT (SOLD)
6000K HIDs, LEDS, Steelies/Chromed caps W/ Coopers, Grey Bonnies, Gary's Wires, TB bypass, Air Pump delete, CAI, Dual Elec fans
68 BUICK SKYLARK 2D HT--2nd owner, all original, rust free 350/th350, almost ready for paint!
79 Eldorado Biarritz White on White, factory Olds 350
  #3
Old 01-31-2010, 08:04 AM
SSANITY SSANITY is offline
SSANITY
Default
Thanx.
I had a dramatic loss of top-end power. No problem starting or dieing when running with my experience. Call your local Auto Parts stores to see if they have the capability to test ICMs. Both the Advance and O'Riley stores in my area do.
__________________
96 SS: SSRI| F-Body MAF| 58mm TB| 30lb SVOs| Racetronix Fuel Pump Kit| 160* T-Stat| Mieziere Water Pump| TB Bypass| AI Heads, Cam, Intake| Try-Y's| X-Pype| DynoMax| Pro-Built Prostreet| 3600 Edge| Aluminum DS| Adjustable Extended Trailing Arms| Dick Miller Suspension Support Arms| 3.73s| 400lb Eaton| IC Brackets| Vogtland Springs| QA1's
  #4
Old 01-31-2010, 10:12 AM
DiGGM95's Avatar
DiGGM95 DiGGM95 is offline
DiGGM95 is on a distinguished road
Default
The test the parts stores run on the ICM does a series of several tests, so I would figure that they can die in more ways than one. Just either make them test it enough to get it hot, or take a lighter and lightly warm the metal bottom of the ICM right before having them test it.
__________________
1995 Caprice 9C1
1995 GMC Yukon
2003 **** CVPI
2009 **** CVPI
Youtube
  #5
Old 01-31-2010, 01:37 PM
MrBuick (Magnum)'s Avatar
MrBuick (Magnum) MrBuick (Magnum) is offline
MrBuick (Magnum) is an unknown quantity at this point
Send a message via AIM to MrBuick (Magnum)
Default
I bought my 96 Caprice 9C1, and it wouldn't start. First thing I changed was the ICM, and it fired right up afterwards. Even on 2 year old gas. I didn't know the parts stores could test them. I should have mine done. A guy on Buick forums was having starting issues, and it turned out to be the coil. You can do a test of those yourself, with a multimeter. But I don't know how, as I have never done one.
__________________
~Cory Magner "My name is Cory, and I'm an addict."
95 DCM Buick RMS. 14.21 at 91.79 "Jesus", Motor Swap at 85k
95 DCM Buick RMS 13.52 at 99.12 Buffman's car, Cracked Piston at 180k
96 DGGM Buick RMW 263k Stock Tranny
RAISS, Tri-Y's, Pypes X pipe, Spintech Prostreets, 3000 Edge, 3.73's, Eaton Posi, and the rest of the Bolt-ons. Fried #7 Ring.
And 5 other LT1 B-body's... Is there Rehab for this Sh*t?
  #6
Old 01-31-2010, 02:50 PM
Default
Thanks for popping in guys. I am still having the funny starting problem that came with the car. When I found that my oil leak was coming out of the lil' tube @ the bottom of the opti, I thought I had it solved. So I changed the opti (and the timing chain while I was in there). Car definitely felt crisper/faster. But still the lame starting problem. Before that I changed to a Walbro pump & changed the filter.
I must admit that advise was given to me on checking the EGR system, and I have not done that yet. I have yet to find the canister & check stuff out.
Thanx again.
__________________
John
  #7
Old 01-31-2010, 03:17 PM
sherlock9c1 sherlock9c1 is offline
Sophomore Member
sherlock9c1 can only hope to improve
Send a message via AIM to sherlock9c1
Default
Mine was also getting sensitive to cold humid mornings (would not start). Let it sit a few hours and it would start.
My ICM died suddenly one day. Would not start, but you could see a spark if pulled the coil wire. Replaced it, and the car fired right up.
The parts stores in my neck of the woods (Advance Auto and Autozone) do NOT have the ability to test ICMs.
__________________
"As I have gotten older, I have become much more patient with some things, and much less patient with other things." - sherlock9c1
  #8
Old 01-31-2010, 03:42 PM
Default
Thanx Sherlock. Mine is doing the opposite. In the morning, it fires up w/just a click. After I drive for a while, the starter needs to spin for like 2 seconds straight. But if I start it right after turning it off (when warm), it starts right up.
I don't know if it is the ICM.
Thanx.
__________________
John
  #9
Old 02-02-2010, 07:59 PM
Dan Fahey's Avatar
Dan Fahey Dan Fahey is offline
Dan Fahey is an unknown quantity at this point
Default ICM and Wire Wiggle Test
Hello ALL:
The SSuperWagon has a similar provacative start, cut off, will not start. Then Start up for no reason.
Hot or Cold made no difference.
Same behavior.
When ran it ran normal. Until it stopped.
Fuel Pressure was fine.
These were the things my Mechanic did.
The mechanic did wire wiggle test.
Mechanic got the car to start.
One of the problems.
The Tandem Connectors on front of the Coil.
Pull off and slightly twist the Pins. Reinstall.
They were loose and were additionally Tie Wraped tight/
The ICM was replaced anyway.
Discovering water behind the Finned Coil Plate.
Cleaned up everything and put on fresh Diaelectric Grease
The ICM Connector was fine
We are testing it again tomorrow.
So far the Car is runnng ok
No frustrating NO Start.
Then for Start and Run.
It now starts every time.
BUT going to be retested tomorrow. COLD.
Will report after tomorrows tests.
Dan
Dan
  #10
Old 02-02-2010, 08:10 PM
Mean SS's Avatar
Mean SS Mean SS is offline
Mean SS is an unknown quantity at this point
Send a message via AIM to Mean SS
Default
Originally Posted by Dan Fahey View Post
Hello ALL:
Same behavior.
Dan
Dan
I had the wire inside the black coil connector go bad on mine
__________________
1995 Impala SS 13.3 http://s126.photobucket.com/albums/p...pala/?start=80
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
