What are the best Spark plug/plugs wires for Performance? - Page 2 - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Engine Performance
Thread Tools Display Modes
  #11
Old 02-13-2010, 09:57 AM
Jim Rockford Jim Rockford is offline
Banned
Jim Rockford is an unknown quantity at this point
Send a message via AIM to Jim Rockford
Default
Its started to be reported that AC delco wires have really gone down hill in qaulity, and don't be fooler by the larger numnber on the wires..8mm-10.5 mm that just means you are paying for more insulation, Its a waste on these cars, just get some taylors , or even jegs makes some f body lt1 wires that are a good price and well made.
Old 02-13-2010, 10:48 AM
Chucks_96_DCM Chucks_96_DCM is offline
Chucks_96_DCM
Default
I've been running Bosch Platinum +4's in all my vehicles.
I'm still have the original plug wires / Opti / and water pump in the Impala (44K miles). I have replacement parts for everything, but as long as I get good gas mileage why do it. I know changing the Opti and plug wires can be a real PITA.
Chuck
96 Impala DCM
02 Regency Silverado 5.3
84 Corvette
  #13
Old 02-13-2010, 11:06 AM
toomanytoyz's Avatar
toomanytoyz toomanytoyz is offline
toomanytoyz is an unknown quantity at this point
Send a message via AIM to toomanytoyz
Default
You could run into header interference problems with the big boots on the Taylor wires, so be sure you have the room for them.
For the record, with aluminum heads and CIA Budgets, you don't.
Believe it or not, I've had the best luck with Belden Gold and Autozone top-liners (Duralast Gold, maybe?).
I like the NGK TR55's in my Impala, but you gotta change them once a year. I run the regular old Bosch Platinums in the wagon. I've run those for YEARS (like 15) and never had a problem. I like that they don't have platinum pucks to worry about falling off, like some other recommended plugs. I may switch to those in the SS this year, too, because I don't plan on ever running nitrous in the car anyways.
__________________
Bill "The Verb" Crovo - Resident Car Slut
95 WB4 -The Toasted Marshmallow- Quick and Fat, sorta like it's owner...
00 Sierra 2500 ECSB -The Big Slut- H2's & 33's, TB crank, CAI, Magnaflow, Cowl'd, etc...
94 Fleetwood -The Ill Brougham- Praise the Lowered! Satin Black, red wheels, whitewalls, glasspacks. 'Nuff said.
American Ricer
www.badassofne.net
"Ooooh! Look! Something shiny!"
LOWER IT!!!
  #14
Old 02-13-2010, 11:45 AM
katana1100 katana1100 is offline
katana1100 is on a distinguished road
Default
Best plugs? I have Autolite double plats in my car with 50K miles and it still runs good. When I replace them,I'll replace with some iridiums, they are without a doubt, the best.
My '06 GTO came from the factory with iridium plugs. When I had it dyno tuned, I asked if they replaced the stock iridium plugs with new copper plugs. They didn't. So, they replaced them with brand new champion copper plugs and we did some more dyno pulls.
Same temp/humidity conditions, so how did they do against these old iridium plugs with 18k miles? Not good!
On each pull, the car put out about 1.5hp less than with the old iridium plugs. You can quibble about the negligible amount of power, but fact is that a new plug should clearly outperform an old plug.These plugs also last well too. I went through a set of the overlly hyped ngk copper plugs and after 17k miles, I can say that I noticed no difference in performance over the plats, except at 17k miles when the idle was a bit off and the plugs were worn. I hate changing these plugs and for a stock motor, I recommend iridiums with a healthy dollop of antisieze goop on the threads and you won't have to look at them again for a long time.
__________________
'96 Impala bought new, with every bolt on imagineable
'06 GTO, headers, dyno tune, almost every stock suspension piece replaced with stuff that isn't crap!
'03 Jetta Wagon TDI, large injectors, euro tune, vr6 clutch, it is fast and gets over 45mpg
'91 Katana 1100.
'11 Kawasaki Concours 14
  #15
Old 02-13-2010, 01:04 PM
udownwitk's Avatar
udownwitk udownwitk is offline
udownwitk is on a distinguished road
Send a message via AIM to udownwitk
Default
i have red MSD 8.5mm wires and AC delco plugs. been runnin smooth ever since.
__________________
1996 Impala SS 121K miles: Gen II Tri-Y's, No Cats, Yukon 3.73 w Auburn Pro, bored 52mm TB w/ Air Foil/Bypass, Spintech ProStreet 6000, 8.5mm MSD wires, Delco Plugs, C3Fab Extended Arms, Vogtland springs, Bilsteins, AIR Delete, PCMforless Tune, LT4 KM, Hypertech 160* stat, Viper Alarm, Impala #31,960 Built: 9-13-96
  #16
Old 04-16-2010, 10:35 PM
HUF's Avatar
HUF HUF is offline
HUF is on a distinguished road
Default
Has anybody tried these wires?
__________________
1995 Cadillac Fleetwood Brougham 105,XXX miles.
  #17
Old 04-17-2010, 10:21 AM
SSaxman SSaxman is offline
SSaxman
Default
I run Taylor Thundervolt 8.2mm wires with the '96 Delco double platinum plugs.
__________________
1995 DGGM; Herter PCM, SSRI, FB, HP, AIR, Cat delete; LT4 KM, MSD Coil/Ign, Taylor Thundervolt 8.2mm wires, Edelbrock 52mm TB, CIA Gen II Tri-y's, Pypes X, Flowmaster 40's, Dynomax OTA's, F-Body EGR, GMPP 1.6 RR's w/heavy duty valve springs; Hotchkis springs, Energy/Moog front end, Monroe SS shocks, Spohn RLCA's, B-Body Performance sway bars; Eaton posi w/3.42 and Yukon axles, braided stainless brake lines, Baer GT front brakes w/C5 Z06 calipers, stealth brake bolt; SSLED, sequentials, wig-wags.
  #18
Old 11-08-2010, 05:32 AM
podeveryday's Avatar
podeveryday podeveryday is offline
podeveryday is on a distinguished road
Default
I'm about to install tri-y's and change my plugs on my 27k ss.I was about to buy some tr55's until i read this. Why do you have to replace them once a year?
__________________
  #19
Old 11-08-2010, 06:36 AM
stratman stratman is offline
stratman is an unknown quantity at this point
Default
Just wanted to add that since I'm on my 2nd '96 SS and have to REINSTALL my CIA Gen II Tri-Y Headers that means I also may as well do plugs again since when I originally had my few mods (Headers&hi flow cats, intake, 1.6RRs, beehive valvesprings, F-body MAF, LT4 KM) that upon getting a tune I questioned Bryan about plugs and recommended to me The Autolite 104's and I got em in double plat and the car ran great the whole time...
So awhile back I recontacted him about a friends new-to-him '93 Z28 LT1 on a tune and recommended plugs and he mentioned really liking new Autolites they have that are Iridium so I believe that equivalent part# would be XP104 so I will probably try them out when I get to reinstalling my headers
  #20
Old 11-08-2010, 07:42 AM
DiGGM95's Avatar
DiGGM95 DiGGM95 is offline
DiGGM95 is on a distinguished road
Default
How many miles do you put on your car a year? Copper plugs (basic TR55's) last around 30k miles (alot faster than rare metal variations like platinum or irridum, if the plug quality is any count).
I like the basic TR55's, and changing plugs on my car doesn't bother me at all, so I save a decent amount of money. If I didn't care for plug changes or if they were extremely difficult to do, I'd cough up the $ and go back with a platinum/irridum set and be done with them for awhile. -Id hope for at least 60k miles, but that seems like asking for too much lol!
__________________
1995 Caprice 9C1
1995 GMC Yukon
2003 **** CVPI
2009 **** CVPI
Youtube
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
