Hard start - Chevy Impala SS Forum
Impala SS Forum
Thread Tools Display Modes
  #1
Old 02-27-2010, 01:22 AM
nightdrive9 nightdrive9 is offline
nightdrive9 is on a distinguished road
Default Hard start
I have a 96 impala,,
Recently I have noticed the following
I start the car at the afternoon and it starts from the first crank, I drive it for 5-10 min. leave it for an hour or two,, try to start it, can't do it until I keep holding the switch for a while and some time a push on the pedal..
The cars runs and drives smooth,
New fuel filter, new spark plugs wires, new PCV
Spark plugs are 1.5 years old NGK, the fuel pump has a noisy sound since I bought the car 2 yrs ago!
Thinking of performing a pressure test for the fuel pump.
Suggestions ppl please
Old 02-27-2010, 01:26 AM
RONSS96's Avatar
RONSS96 RONSS96 is offline
RONSS96 is an unknown quantity at this point
Default
Pull the vac hose off the fuel pressure regulator. If it has any gas residue or a drip of gas the regulator is bad. My 94 wagon had the exact symptoms and a new regulator made it start instantly again. Hope this helps!!!!!
Ron..
__________________
Ron Soucy
American cars from an American car company. Which country do you support?
1996 DCM impala (original owner)
1996 BBB impala
1994 caprice wagon ss clone (sold and missed
  #3
Old 02-27-2010, 01:41 AM
bigakphilly's Avatar
bigakphilly bigakphilly is offline
bigakphilly is on a distinguished road
Default
try to check or put a new regulator on the fuel rail...
also it could be quite a few things... you have to do the process of elimination technique...
not starting all the time could be anything from the ignition switch in the steering column to a major ignition problem.
__________________
I never lie because I don't fear anyone. You only lie when you're afraid. John Gotti
https://www.facebook.com/al.kleister
  #4
Old 02-27-2010, 01:45 PM
Default
Checked the regulator and there is no gas residue or a drip of gas.
made a pressure test and got the following:
1- switch on, engine off 51 psi.
2- engine on 45 psi
3- pressing the pedal 50 psi
So I think the fuel pump is working fine and responsive
Changed the Temp sensor and will see !!
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
