How to replace crankshaft seal - Chevy Impala SS Forum
Impala SS Forum
Thread Tools Display Modes
  #1
Old 03-18-2010, 01:58 AM
LiLYoungHyphy LiLYoungHyphy is offline
LiLYoungHyphy is on a distinguished road
Default How to replace crankshaft seal
Just like the title says, I am going to be replacing this seal and need some tips on how to go about it. From what I understand I need to take off the balancer, pull out the shaft with the puller, use lube to put the seal in and then knock the shaft back in. what do I use to knock the shaft back in? Any input will be helpful thanks
Old 03-18-2010, 02:21 AM
BALLSS BALLSS is offline
BALLSS is on a distinguished road
Default
...don't "knock" the hub (shaft) back on.
Of course there is a exploding wallet tool made by Kent Moore to pull/press the hub back on.
there are a few DIY methods using pullers more common from auto parts stores you get on loan. a search might show info, I have only R&R with the Kent Moore tool I borrowed from a friend.
yeah the crank seal you lube the inside lip then use a plastic mallet to tap into place.
__________________
\'96 BBB 383/T-56
  #3
Old 03-18-2010, 07:26 PM
Default
I remember seeing one of my uncles having difficulty taking out the hub in another caprice, even with a puller and getting it back in was even harder. Thanks for the feed back BALLSS. Anymore inout will be appreciated Thanks
  #4
Old 03-18-2010, 11:14 PM
sherlock9c1 sherlock9c1 is offline
Sophomore Member
sherlock9c1 can only hope to improve
Send a message via AIM to sherlock9c1
Default
To clarify what BALLSS said - the reason why you don't just hammer the hub back on is because you're basically hammering against the crankshaft thrust bearing and could damage it. Fixing that means removing the engine...
__________________
"As I have gotten older, I have become much more patient with some things, and much less patient with other things." - sherlock9c1
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
