Removing front control arm bushing? - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Suspension
Thread Tools Display Modes
  #1
Old 03-23-2010, 07:10 PM
fuzzcar's Avatar
fuzzcar fuzzcar is offline
fuzzcar is an unknown quantity at this point
Default Removing front control arm bushing?
Im trying to get these out. I tried burning the rubber out on one of them but the outter sleeve does not want to give.
__________________
Beater 1992 9C1 Caprice with L05
Project 1993 9C1 Caprice with L05
Project 1994 9C1 Caprice with LT1 - maybe one day it will be BK TP worthy
Old 03-23-2010, 07:18 PM
HuSSker's Avatar
HuSSker HuSSker is offline
Location: Colorado Springs, CO Where the sun sets on America's mountain.
HuSSker is an unknown quantity at this point
Default
Most people drill/cut the rubber out of the old bushing, and then cave in the sleeve through whatever means you prefer, without damaging the control arm.
__________________
'94 Impala SS
#14 of all TRI-9 Impalas
SSRI
Kore3 C5 front brakes
WX3 Performance C5 rear brakes
Hotchkis springs/bars/rear LCAs
Herter tuned
CIA Quad 1 Cermachromed headers
Muffler Man stainless X-pipe/Dynomax UltraFlo mufflers
Street Trends Smoked Euro Head Lights
RMCR rear with Trutrack and 3.42 gears
"Up front there ought to be a man in black"--Johnny Cash
"Is there anything beer CAN'T do?"-- Hank Hill
  #3
Old 03-23-2010, 07:24 PM
fuzzcar's Avatar
Default
How well do the tools made for it work? My ball joint press is just a little too big to do it.
__________________
  #4
Old 03-24-2010, 12:31 AM
Navy Lifer's Avatar
Navy Lifer Navy Lifer is offline
Navy Lifer is an unknown quantity at this point
Default
You talking upper or lower?
Lower can be removed with a properly-sized hammer/sledge, applied at the correct angle on the INNER lip of the bushing shell. The control arm is placed on it's side on a suitable supporting surface--work bench, large block of wood, etc, with the bushing "cantilevered" over the edge/end of whatever surface you're using--so there's room under the arm for the shell to move out of position. Hold the arm with one hand, and strike the bushing shell correctly and it will pop loose from the arm with no other effort.
TRUST ME, I've done enough of these.
Yes, corrosion and age can be issues.....and unless you're talking about uppers, that's how I have done it for quite a long time--and successfully. It is NOT how the book says to do it, I will admit....and the proper way to install new bushings is still using a press/tool of one type or another.
Uppers are more involved, so please say which you're having problems with.
__________________
Bill Harper
ISSCA #127
inov8r@windstream.net
  #5
Old 03-24-2010, 03:58 AM
fuzzcar's Avatar
Default
Lowers, I havent even tried the uppers yet.
__________________
  #6
Old 03-24-2010, 01:36 PM
Terry #585 Terry #585 is offline
Terry #585
Default
I have done the uppers the same way for years. A good air hammer with chisel works wonders. Walks even the most rusted bushings right out. It will beat up your body real well though.
__________________
Terry
2 1995 9C1s
30U Huet Silver Metallic built 5/26/95
36U Bonnat Silver Metallic built 7/19/95
2001 Camaro B4C SOB -- one of 288
2008 Z06 Jetstream Blue built 10/11/07
  #7
Old 04-09-2010, 06:57 PM
fuzzcar's Avatar
Default
Well guys it was a bear getting mine out. I used a torch to burn the rubber out and had to use a dremel to cut notches in the bushing shell then alot of beating and cussing.
The Kent Moore tool for doing it is $800! My ball joint press wouldnt work I didnt have the right adaptor cups.
__________________
  #8
Old 04-09-2010, 08:01 PM
wytltng's Avatar
wytltng wytltng is online now
wytltng is on a distinguished road
Default
Here is a tip when doing the uppers.
Remove one busing & then you can remove the shaft, then the second bushing.
Reverse to install.
__________________
MR.MISK OF ISSCA-2012
95 SS Blk w/77k-FOR SALE
  #9
Old 04-09-2010, 08:03 PM
fuzzcar's Avatar
Default
I used this tool on the uppers and it was a piece of cake!
Amazon.com: Upper Control Arm Bushing Removal Tool Repair Ford GM: Everything Else Amazon.com: Upper Control Arm Bushing Removal Tool Repair Ford GM: Everything Else
__________________
  #10
Old 04-09-2010, 08:06 PM
wytltng's Avatar
Default
I always install the rear bushing first due to it sitting more flush in the arm.
__________________
Forum Jump
(c) 2007-2011 Impala SS Forum
