how to open headlights? - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Exterior
Thread Tools Display Modes
  #1
Old 03-31-2010, 09:38 AM
96ImPaLa*BLING*'s Avatar
96ImPaLa*BLING* 96ImPaLa*BLING* is offline
96ImPaLa*BLING*
Send a message via AIM to 96ImPaLa*BLING* Send a message via Yahoo to 96ImPaLa*BLING*
Default how to open headlights?
i had a halogen bulb explode inside of my ST clear headlights... how do i open them to clean the residue on the inside? i heard about putting them in an oven but im not sure the tempurature or how long. any input would be appreciated
__________________
1996 BBB Impala, 2" cowl hood, stock rims plated in chrome,
flowmaster 40 series mufflers,2 1/2" pipe, O/R X pipe, home-made CAI, Hypertech PP3,
Motive 3.42's, Eaton posi, brand new LT1
http://cardomain.com/ride/3065975
Old 03-31-2010, 09:48 AM
96dreamss's Avatar
96dreamss 96dreamss is offline
96dreamss is on a distinguished road
Send a message via Yahoo to 96dreamss
Default
or u can use a heat gun but look on the tread that says halo rings on it and it a video that tell u on the last page
__________________
Don't Watch Me Watch TV Its Safer..[IMG]
  #3
GA95DCMSS's Avatar
GA95DCMSS GA95DCMSS is offline
GA95DCMSS
Send a message via Yahoo to GA95DCMSS
Default
I use a heat gun and a screwdriver. Move the heat gun around a section at a time, prying between the lens and the body with the screwdriver. Once wide enough, stick another screwdriver in there to hold it open as you move to the next section.
__________________
Quentin-1995 Impala SS-6.0L LQ4-222/226-L92 Heads.PB: 1.75 60ft 12.70 @ 107.75 so far
  #4
Old 03-31-2010, 10:27 AM
Midnight's Avatar
Midnight Midnight is offline
Midnight is on a distinguished road
Default
250 deg for 10 min check then put back in if wont come apart.
__________________
  #5
Old 03-31-2010, 11:44 AM
bigblackss's Avatar
bigblackss bigblackss is offline
bigblackss is on a distinguished road
Default
headlights in the oven on the its lowest heat setting and for less than ten minutes usally works for me
  #6
Old 03-31-2010, 12:46 PM
IMPALASS_RIDER's Avatar
IMPALASS_RIDER IMPALASS_RIDER is offline
IMPALASS_RIDER is on a distinguished road
Send a message via AIM to IMPALASS_RIDER Send a message via Yahoo to IMPALASS_RIDER
Default
little homie BLING is back!!
__________________
95 DCM < unladylike *been down since jan 17th 2010*
2013 F250 LIFTED on 37's
2012 Accord
  #7
Old 03-31-2010, 09:45 PM
CandiSS CandiSS is offline
CandiSS is on a distinguished road
Default
When we had to fix her Grand Marquis lens, she put a hose to the vent while leaving the bulbs in to pressurize and it popped open.
She used 4 psi, but started off with a couple. And do wrap a towel around the lens in case it blows.
__________________
cheap stuff :
yellow coolant, 160stat, key fob, sewer pipe, tb bypass, air pump delete, 91 tails, pass rear window sag, rusted caliper pins
not so cheap : heater core, radiator, water pump, carpet,
driver side door switches, stock radio, black switch panels, clear corners, oil cooler hose
expensive :
2-tone seat covers
SEM gray 15393 : Duplicolor DGGM DSGM436 or WA9795
  #8
Old 03-31-2010, 10:05 PM
BYB_CUZ's Avatar
BYB_CUZ BYB_CUZ is offline
BYB_CUZ is an unknown quantity at this point
Default
I got some open with a flathead and blow dryer, I do want to know how people seal them back though.....
__________________
09 G8 GT, lets just say modded
95 b4u- basically sold sadly
2009 jeep cherokee- sold
2014 grand cherokee
  #9
Old 03-31-2010, 10:07 PM
BYB_CUZ's Avatar
Default
i wouldnt do the oven method, too dangerous, i had a bad experience. Blow dryer/heat gun easier to control and easier to work with.
__________________
2014 grand cherokee
  #10
Old 03-31-2010, 11:48 PM
bigblackss's Avatar
Default
re-heat the existing glue and clamp the lense and housing. or add some clear rtv slicone at the seam for more sealant
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
