HELP!! HELP!!vacuum line or diagram? - Chevy Impala SS Forum
Impala SS Forum
Thread Tools Display Modes
  #1
Old 04-25-2010, 05:27 PM
memphizballa's Avatar
memphizballa memphizballa is offline
memphizballa is on a distinguished road
Default HELP!! HELP!!vacuum line or diagram?
I Need A Vacuum Diagram Of The Passenger Side Of A 96 Impala Ss, Labeling Where The Vaccuum Lines Go From The Passenger Side Of The Top Of The Motor. Thanks
Old 04-25-2010, 05:43 PM
Mean SS's Avatar
Mean SS Mean SS is offline
Mean SS is an unknown quantity at this point
Send a message via AIM to Mean SS
Default
__________________
1995 Impala SS 13.3 http://s126.photobucket.com/albums/p...pala/?start=80
  #3
Old 04-25-2010, 05:44 PM
SS DD's Avatar
SS DD SS DD is offline
SS DD is an unknown quantity at this point
Default
Unlike this pic; on my purge Solenoid valve the top line going out is going to the EVAP canister and the bottom to the throttle body.
According to this my SH!T it backwards.
I know this pic is for a 95 Camaro but shouldn't it be the same for a 96?
__________________
ITSSA96
  • Stock 350
  • K&N intake
  • High flow 255LPH fuel pump
  • 24lb Ford SVO injectors (stock, but so nice!)
  • 50 series Flowmasters
  • 400lb Eaton posi
  • 3:73 gears
  • Tri-y's w/Random Tech cats
  • CPT Level 3 tranny (awesome work Shane)
  • OBD1 PCM (great programing Bryan)
  • Precision 22k TC
  • AMSoil 5W30
http://www.cardomain.com/ride/487392/
  #4
Old 04-25-2010, 06:09 PM
Default
Yeah It Is Set Up Like That But The Only Difference Is That I Have A Module Or Something Sticking Out From There And It Has A Rubber Elbow That A Line Is Supposed To Be Going Into.
  #5
Old 04-25-2010, 06:15 PM
Default
My Car Is A 96 Ss
  #6
Old 04-25-2010, 06:19 PM
SS DD's Avatar
Default
That goes to the EVAP canister.
Are your lines from the solenoid set up like the photo?
__________________
ITSSA96
  • Stock 350
  • K&N intake
  • 400lb Eaton posi
  • 3:73 gears
  • Precision 22k TC
  • AMSoil 5W30
  #7
Old 04-25-2010, 06:26 PM
SS DD's Avatar
Default
Are you just missing lines or are you experiencing some funky
noises coming from the engine when your driving at 3-4
thousand RPM?
I had some nasty sounds under full throttle a while back I had
missing and cracked vaccum lines.
http://www.impalassforum.com/vBullet...d.php?t=232538
...but even though the noise is gone I'm still trippen off how the pic
setup is opposite of mine.
__________________
ITSSA96
  • Stock 350
  • K&N intake
  • 400lb Eaton posi
  • 3:73 gears
  • Precision 22k TC
  • AMSoil 5W30
  #8
Old 04-25-2010, 07:02 PM
Default
Originally Posted by Mean SS View Post
96 has more stuff does it look like this?
is there a Vacuum Diagram on your raidator support ?
http://www.shbox.com/1/component_location_views.html
yeah my drivers side is like this and it has line where this diagram says "vent no hose" and the right side is also different.
  #9
Old 04-25-2010, 07:09 PM
Default
thousand RPM?
yes i am missing a line on the passenger side. the line that goes to the canister is there and it does go to the canister. i have just came in the house from looking at it again. the little thing is a round connector between the line from the intake to the cainster but also on the bottom of the connector thingy there is a rubber elbow needing a line from somewhere. and when i try to start it stalls for about 1-2 seconds.
  #10
Old 04-27-2010, 07:59 PM
SS DD's Avatar
Default
Ok, then I'm good to go (top line goes into the throttle body and the bottom goes to the solinoid and the solinoid goes to the canister)....and this should be enough for you to get the lines you need and hook them up correctly.
Thanks Mean SS
__________________
ITSSA96
  • Stock 350
  • K&N intake
  • 400lb Eaton posi
  • 3:73 gears
  • Precision 22k TC
  • AMSoil 5W30
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
