I can't figure out my Dashboard removal - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91 thru 96 B-body Model Specific > Wagons
Thread Tools Display Modes
  #1
Old 05-01-2010, 03:14 PM
beastmaster's Avatar
beastmaster beastmaster is offline
Junior Member
beastmaster
Default I can't figure out my Dashboard removal
I need help bad and soon, I am desperately trying to keep my car out of the hands of the junkyard, heater core went, wife is pissed. I can't figure out how to take out the dash so I can fix it. And help would be greatly appreciated.
Theodore
__________________
94 Roadmaster Estate Wagon
http://rides.webshots.com/photo/2595140460100554282bavnjg?vhost=rides
Old 05-01-2010, 03:45 PM
Fred Kiehl's Avatar
Fred Kiehl Fred Kiehl is offline
Fred Kiehl is on a distinguished road
Default
You can replace it from the bottom with out removing the dash. Remove the panel under the glovebox...remove the bottom of the airbox...you can access the core from there. There used to be an R&R thread on the forum. Use the search function to see if it is still here. Your wife is being unreasonable. It is far cheaper to keep a car like this running than to pay for a new car.
__________________
1991 OCC upgraded LO5, LT1 cam, 46mm TBI, bored intake manifold, wrapped headers, true duals w/Flowmasters, 3.23 posi, flash to pass, drop spindles & springs, custom fender skirts, stainless full moons, Recaros, Blazer console, Nardi/wood SW w/QR, custom wood shift knob, Pioneer DEH P77DH
1992 OCC now with 5.7 tbi, DEH P77DH
For a parts list, check http://www.impalassforum.com/vBullet...1#post11691762
  #3
Old 05-01-2010, 03:50 PM
Fred Kiehl's Avatar
Default
Check this one guy for the part 1994 RMW Parts - Alpharetta GA - Still lots of items!
__________________
  #4
Old 05-01-2010, 06:04 PM
Sinister's Avatar
Sinister Sinister is offline
Sinister is on a distinguished road
Send a message via Yahoo to Sinister
Default
Hell, it's summer, if it's an emergency and the car needs to be driven bypass it and continue driving til you can change it. I would junk my wife before my car.
The purchase of a Factory Service Manual should be mandatory when purchasing one of these cars.
__________________
LS powered Impala SS.
  #5
Old 05-01-2010, 06:45 PM
Klez's Avatar
Klez Klez is offline
Klez
Default
Bypass, and repair it later (when wife is shopping). I know it took about 2.5 hours on the SS and about 30 minutes on the FW. Never had to change one on a Buick yet so not sure on the time.
__________________
Kevin
94 RM Wagon 12.15@108
94 Caprice wagon 14.15@96
95 Chevy crew cab dually 6/8 drop car hauler
09 G8 GT 13.63@103 (stock)
C5 Z06 11.81@122 on street tires
  #6
Old 05-03-2010, 10:01 PM
Brokecello's Avatar
Brokecello Brokecello is offline
Brokecello is an unknown quantity at this point
Default
..yeah, also take out the passenger seat too. Only a couple bolts holding it in and you will be VERY glad to have the extra wiggle room when laying down and working under the dash (you are taking off that large black box behind/under the glovebox. It holds the AC Evap core and Heater core.)
Honestly, if you take both front seats out...you will have an easier time rolling the carpet AND rubber backing out of the way. That will help a whole lot as far as space and getting the bottom of the box off and on right. (reaching those pesky little 7mm screws waay in the back)
http://www.impalassforum.com/vBullet....php?p=2239099
__________________
--1995 Jadestone Limited RMW
CarISSMA Club Member / ISSCA #2027
  #7
Old 05-06-2010, 12:01 PM
Junior Member
beastmaster
Default super help as usual
Thanks all, I did what you said, and following the core inlet and outlet to the dash line and looked under, WELL, i removed the seat so I could look under....ended up laying on my back in the car to do the whole job, the bitch of it was the cover bolts, tried many sockets before finding my 7/32. Then it was impossible to remove the last bolt closest to the firewall. I cut it, which leads me to ask, should that be ok? I pulled the old core and watched crud pour out, popped the new one in, put cover back on (and all of the dash peices I removed, honestly I would still recommend taking out the glove box, it gives you more light and room to move. So, the low coolant light stayed on for 2 days, running fine, heating and cooling fine, not low on coolant, then my battery completely died, have been recharging it. I swapped the battery and viola, the coolant light went off AND, my rotten egg smell has gone away (i think). Any chance that a bad battery not charging well could cause 02 sensors to read badly?
Theodore
__________________
  #8
Old 05-06-2010, 08:00 PM
Fred Kiehl's Avatar
Default
Low voltage can do wierd things. I would think the heaters in the O2s would not work as well with less voltage, along with other important parts, like the fuel pump, ECM, coil, sensors, and cooling fans just name a few.
You should put the screw back. It helps seal the pan, so if the condensation level get high, it does not run out on the floor.
__________________
  #9
Old 05-20-2010, 10:58 AM
Junior Member
beastmaster
Default Battery
Well, with the battery in the state it was in, you would have thought the car was on its last leg. I wanted to comment on this again in case any else with a BAD BATTERY, has problems they can't figure out. My car was shuddering, smelled like rotten egg hell x2, using more fuel, and the electronic accessories would start flickering like crazy even at highway speeds. I have never experienced this type of problem with a car running. I assumed that if it was started and the alternator was fine, that even if the battery had some issues, it would not be noticed. It makes sense that the alternator would keep everything functioning right? But, nonetheless, replacing that battery for me was the equivalent of replacing 02 sensors, egr sensors, cat's and re wiring the whole car
So, to sum up. If you have crazy wierd issues, you may want to have the battery checked before you start replacing things
Theodore
__________________
  #10
Old 05-20-2010, 11:52 AM
lakeffect's Avatar
lakeffect lakeffect is offline
lakeffect
Default
... and if the problems start re-ocurring again, it's the charging system.
I'm suspicious that the alternator didn't carry the load. Maybe you had a dead cell and were overtaxing the alternator, but in general I don't how the battery effects things negatively once the car is running, as at point you are using the alternator for all electrical power.
__________________
1993 Caprice wagon "SHAMMOO" Kicker demo car. 406ci, TPI'd SBC, 58mm TB, SLP siamesed runners, Comp Cam 230/236, AFR 195 heads, headers. Accel 300+system, remote fan cooled ignition module. Highly modded "4L65" Trans-Go kit, beast sunshell, 5 gear planetaries, B&M megashifter. Shaved roof and tailgate, debadged, billet grill, Front spoiler and rear pan. Custom four bucket interior, Nordskog digital dash. (Reworking current center console) 2" dropped spindles, Bell shocks, BFG's Weld Tomahawks
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
