Really high pressure on low side of a/c - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Heating/Cooling/HVAC
Thread Tools Display Modes
  #1
Old 05-14-2010, 07:57 PM
bob441's Avatar
bob441 bob441 is offline
bob441
Default Really high pressure on low side of a/c
1996 caprice that was low on freon,but when i went to refill it it got real high pressure on low side and it was not full, compressor seems to run fine any ideas????
__________________
1996 Caprice leather 3.73's driftwood met
1994 Fleetwood ~For sale~ CHEAP
1988 Trans Am AA8 Nothcback 5.7 TPI~ For sale ~
Old 05-14-2010, 07:58 PM
RatSSled's Avatar
RatSSled RatSSled is offline
RatSSled has a little shameless behaviour in the past
Default
What's the pressure of both high and low side?
__________________
______________________________________________
96 BBB Impala SS - Stock with bolt-ons 12.82 @ 106
96 DGGM Impala SS - 496 BBC 10.13 @ 134 all natural, 9.69 @ 143 on the gun
96 DGGM Wagon - Spun bearing, headed for the scrap yard!
  #3
Old 05-14-2010, 08:15 PM
bob441's Avatar
bob441
Default
65 to 70 psi on low side I never checked the high side because i did not get that far,the system was completely empty when I started and I only put 1 12 oz can in and the pressure went too high, and it worked fine last summer
__________________
  #4
Old 05-14-2010, 09:19 PM
cletus284 cletus284 is offline
cletus284 is an unknown quantity at this point
Default
Is the compressor running constantly when you're checking low side pressure? If it is off or cycling, the reading is not accurate.
__________________
2005 Pontiac GTO
  #5
Old 05-14-2010, 09:59 PM
RatSSled's Avatar
Default
That's 65 to 70 with the compressor on or off? What does it read when the compressor runs constantly? It should drop to less than 30 depending on the ambient temperature. What was the outside temperature at the time? Oh and check the high side too. The high side should be between 2 to 2.5 times higher than the low side.
http://www.autoacforum.com/
__________________
Forum Jump
(c) 2007-2011 Impala SS Forum
