ABS Delete??? - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Brakes
Thread Tools Display Modes
  #1
Old 05-14-2010, 10:33 PM
chacho44's Avatar
chacho44 chacho44 is offline
chacho44 is on a distinguished road
Default ABS Delete???
is there a kit they sell to delete this, or do I have to fab up some stuff on the brake lines????? pics of whats needed to do this please
Old 05-15-2010, 06:50 AM
wytltng's Avatar
wytltng wytltng is offline
wytltng is on a distinguished road
Default
It needs to be fabbed. I did it.
What you building there mister?
  #3
Old 05-15-2010, 10:20 PM
chacho44's Avatar
Default
Its G14 CLASSIFIED CHUCKIE.... But might be for sale when its done...
  #4
Old 05-16-2010, 02:03 AM
pcordes1979 pcordes1979 is offline
pcordes1979 is on a distinguished road
Default
By what I can tell, if you are looking to remove the ABS unit completely from the system(and not just disabling it) you will need to make a jumper tube that goes from the "rear brake" line on the proportioning valve to the rear hard line and then a jumper tube with a splitter block that goes from the "front brake" line on the proportioning valve to the 2 front brake hard lines. I put "rear brake" and "front brake" in quote as the rear outlet on the proportioning valve is towards the front of the car(hence why to do the first part of the proportioning valve mod you remove the front bolt, remove the spring and piston, and cap it with the new solid bolt to change the rear brake pressure) and the front output is closer to the firewall. It will be quite impractical to remove all the ABS wiring from the car as its all intertwined with the rest of the wiring harness, but as long as its tied off so it doesn't come into contact with anything it should be fine. As for the dash indicator light if it comes on after you remove the ABS setup then simply remove the ABS bulb from the gauge cluster. - Peter
__________________
Peter Cordes
1995 Caprice SS/9C1 Black w/ tan leather interior
1993 Ford Escort LX Mocha Frost Metallic w/ tan interior
  #5
Old 05-16-2010, 03:43 PM
chacho44's Avatar
Default
Sounds like alote of work Ill have to ponder about this
  #6
Old 05-17-2010, 02:14 AM
Default
Its really not all that hard. Just would need to rent the proper tools from your local auto parts store and buy the raw hard brake like materials to make the brake lines. Splitter blocks are also readily available from GM even. The 94-96 B-body cars use a splitter block for the rear brakes (as they have a 3 channel ABS not a 4 channel ABS system like D and F bodies do). - Peter
__________________
Peter Cordes
  #7
Old 05-17-2010, 05:55 AM
wytltng's Avatar
Default
I can help you do it. Not hard at all. When you want to do it.
  #8
Old 05-17-2010, 11:31 AM
WHITEBOY_ZACH's Avatar
WHITEBOY_ZACH WHITEBOY_ZACH is offline
WHITEBOY_ZACH is on a distinguished road
Send a message via Yahoo to WHITEBOY_ZACH
Default
Not much but hope it helps.
http://www.impalassforum.com/vBullet...ght=abs+delete
ZACH
__________________
95 9C1/WX3 DELETE 396 SR LT4-4L80E-3.73 "My Baby"
92 Caprice Wagon LQ4-4L60E? "My Project"
96 Camaro LT1-T56-? "The Toy"
  #9
Old 05-17-2010, 05:01 PM
chacho44's Avatar
Default
Sounds good ChuckAs soon as she is runnin Ill be in touch, and Ill bring the cervesa's
  #10
Old 05-17-2010, 08:09 PM
wytltng's Avatar
Default
Don't forget the whores either. I might be in the mood for something mexican or dark if you got any.
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
