official rough idle/surge/misfire - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Engine Problems/Maintenance
Thread Tools Display Modes
  #1
Old 06-23-2010, 07:03 PM
thebigbadWOLF's Avatar
thebigbadWOLF thebigbadWOLF is offline
thebigbadWOLF is an unknown quantity at this point
Default official rough idle/surge/misfire
the object to this thread is to make a some what of a check list of everything that can / has caused a idle issues/ surge and a mis fire...
i dont need the entire story, just what fixed the issue
i have noticed latly there is a asssss load of threads about mis/rough idle. 80% of the time people jump to opti's. I personally dont think the opti is the root of all problems, ya its a pita but a well taken care of opti will last years.
please post something you have fixed,or have had fixed....not something you have read and you think can cause a mis or rough idle.
IF you post something general like a vacuume line, please explain what line it was...
i will start.
spark plugs(crossed wire and or bad wires)
bad sparks & incorrectly gapped sparks (0.50 fyi)
ICM
Vaccuum (the line that comes from the front of the TB to the side of the head)
opti
opti harness
fuel pump
fuel filter
coil
__________________
Cali-SS
Originally Posted by Rocko350 View Post
Go fix your fleet of 91's. I wipes my tushy with TBI.......
Originally Posted by Needles.Kain View Post
Much like date night with BK, this isn't about what you prefer.
Old 06-23-2010, 09:17 PM
Mean SS's Avatar
Mean SS Mean SS is offline
Mean SS is an unknown quantity at this point
Send a message via AIM to Mean SS
Default
power wire to coil "black coil connector" on 94-95 coil, the wire was corroded and frayed internally no change in how it ran with wiggle test
__________________
1995 Impala SS 13.3 http://s126.photobucket.com/albums/p...pala/?start=80
  #3
Old 06-23-2010, 10:07 PM
Rocko350's Avatar
Rocko350 Rocko350 is offline
Rocko350 is an unknown quantity at this point
Default
Egr valve. Car will even present with running a little hotter than normal, stalling while coming to a stop, and on cammed cars can cause a part throttle surged when not tuned properly.
Chris
__________________
Originally Posted by Erik View Post
My first advice to you is to edit that and call me from a payphone.
Originally Posted by Goldmaster View Post
I really can't say for sure. Once the roofies kicked in she seemed calm and easy going.
  #4
Old 06-24-2010, 07:48 AM
96 Black 96 Black is offline
96 Black is an unknown quantity at this point
Default
Here's my reply in a similar vein from back in Dec.;
Originally Posted by 96 Black View Post
oh boy would YOU be getting reamed for not Searching if the server hadn't wiped out everything....
There's about a billion documented causes of off-idle stumble;
intake leak
IAC
MAP
Vapor Can
plugs
wires
vac hoses
water pump - yes, it drips on the opti
wet/humid opti
that'll get you started.
Added:
EGR
Of course several overlaps with your list -Wolf, but I notice no mention yet here of intake manifold leaks. That's so obvious (and gotta be real common on a 15 year old iron motor) that I guess I always overlook it.
Click image for larger version
Name:	Oily Intake 1.jpg
ID:	13974   Click image for larger version
Name:	Oily Pass Rear Intake 2.jpg
__________________
. . . . . . . . . . . . . . . . . . . . . . . . "Oh Bob, It's So Big And Long!" . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
\'96 BBB: SSRI, Herter Tune, Tri-Y II, SLP SS, 3000 Edge, F/HO bars, METCO extendeds, Bilsteins, currently Vredestein Ultrac Sessanta (315/35 rear)
\'95 FTSS: total mono gray, SSRI, Anthony tune, Aero catback/H/resonators, SS bars and coils, Hotchkis LCAs, Bilsteins/Airlift 1000, NL rear discs
  #5
Old 06-24-2010, 08:51 AM
95BRMW's Avatar
95BRMW 95BRMW is online now
95BRMW is on a distinguished road
Default
In my case the previous owner had a mechanic tune up the car, new plugs and wires. ran rough and missed on one cylinder. One plug on the passenger side was loose, had oil on the threads and would not make a good ground. New plugs took care of it.
__________________
1995 DCM Roadmaster Wagon 106K
1995 LDM 1A2 Caprice Wagon 202K
1994 9C1 Caprice 145k
1996 Black/Black FWB 170k
1975 Impala Coupe
1997 Riviera Supercharged
  #6
Old 06-24-2010, 10:12 AM
sherlock9c1 sherlock9c1 is online now
sherlock9c1 can only hope to improve
Send a message via AIM to sherlock9c1
Default
My experience:
1. Ignition coil was shorting internally, making a tic noise every time it fired that was tied to engine RPM. The car ran noticeably better and started quicker with a new coil.
2. Fuel injectors can and do partially fail. My wagon had run hot for awhile and was poorly maintained. I sent the injectors to Witchhunter performance and they found 2 or 3 injectors that flowed at around 60% of capacity with an awful spray pattern. One was also not opening in time so we had to junk that one. It costs around $17 apiece to have an injector tested and cleaned. Cheaper than a tuneup.
3. The #7 spark plug wire will short on the frame or brakelines when wet if you don't run it in the factory loom, or build a plastic/rubber insulated holder assembly. If you tie it to the frame or brakelines, leave enough slack for the movement of the motor relative to those components, otherwise the motor will pull that wire off when you rev it.
__________________
Don't let people change the definitions of words on you. If an illegal alien is now called an "undocumented immigrant," is a drug dealer now an "undocumented pharmacist?"
  #7
Old 06-24-2010, 10:55 AM
POPIMPIN CUSTOMS I.N.C.'s Avatar
POPIMPIN CUSTOMS I.N.C. POPIMPIN CUSTOMS I.N.C. is offline
POPIMPIN CUSTOMS I.N.C. is on a distinguished road
Default
for those that do not know, the spark plug wires ALL have to click twice into the opti or they are not seated properly
__________________
ALL RWD,4 B BODIES!!!
1995 white 9c1 24 inch rims, muffler delete 4-20-09,hollowed cats, touchscreen, kicker cvx 15 2000 watt rms DD
1991 CAPRICe CLASSIC 1st B Body all original 350 tbi over 200,000 custom 20's sold it in like '06 and hate myself for it!!!
1991 caprice w 305 around 160,000 paid $600 sold for $1200
1976 datsun 620 truck
Proud owner of a RARE 1965 oldsmobile starfire 425 big block, also B BODY 400+- horse MY LT1 EATER
http://www.cardomain.com/ride/2417157
R.I.P. DAVID SSON22'S
  #8
Old 08-13-2010, 10:32 AM
Default
ttt ..
__________________
Cali-SS
  #9
Old 08-14-2010, 12:45 AM
DiGGM95's Avatar
DiGGM95 DiGGM95 is offline
DiGGM95 is on a distinguished road
Default
I had a fouled O2 sensor that caused a closed-loop multi-cylinder misfire on the corresponding side. Unplugging the O2 sensor and driving it verified it, as it ran on all 8 cylinders that way.
Also, in cold weather if I didn't wait for it to warm up, It would run great until you could first feel a little heat coming out of the vents, from that point on it ran like crap.
__________________
1995 Caprice 9C1
1995 GMC Yukon
2003 **** CVPI
2009 **** CVPI
Youtube
  #10
Old 08-24-2010, 10:45 AM
Default
there has to be alot more....who has fixed their idle issue post up
__________________
Cali-SS
Forum Jump
(c) 2007-2011 Impala SS Forum
