Rear main seal replacement advice - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Engine Problems/Maintenance
Thread Tools Display Modes
  #1
Old 07-08-2010, 12:45 AM
BABYBLUE9C1's Avatar
BABYBLUE9C1 BABYBLUE9C1 is offline
BABYBLUE9C1 is on a distinguished road
Default Rear main seal replacement advice
well time has come to change this seal, so was hoping you guys can offer some helpful tips
so far i know i can drop the tranny and go in from there,
so any advice guys, im all ears
thanks
__________________
So Cal INC
1996 Caprice 9c1
5-15-1996
R.I.P. David Fornwalt...burnin' rubber from up above
Old 07-08-2010, 01:26 AM
94MI9C1's Avatar
94MI9C1 94MI9C1 is offline
94MI9C1 is on a distinguished road
Default
Haven't done one yet, but did look into it sometime ago. Pretty straight forward, the seal housing has pry tabs on it, so you can pry it out. When installing tap evenly around the edge, make sure you lube up the inner portion that mates to the crank, so it will slide on easier. This pic may help
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
1994 Chevy Caprice 9C1, 126,000 miles, T56, 4.10's
C6 Grandsport Brake Install C6 Z06 Wheels T56 Installation Manual
  #3
Old 07-08-2010, 01:58 AM
Dustan's Avatar
Dustan Dustan is offline
Dustan is an unknown quantity at this point
Send a message via AIM to Dustan
Default
That couldnt of been done any better Mike.
__________________
1996 Impala SS DGGM-Blueprinted and balanced 355, forged wiseco's, Level II heads, LE cam, U2-55ed, budget headers, 2500 stall, built 4L60E,CAI,PCMforLessed, Sprint springs, Walbro 255
1996 Impala SS DGGM (moms)-chrome stockers, flows, charcoal carpet
2006 Suzuki GSXR 750
Impala SS Owners Association of Hawaii (ISSOAH)
Originally Posted by Cracka Ass Crackuh
"Yea. You're wearing my underwear backwards. SO the hersey highway is on the front with easy access to the rear"
  #4
Old 07-08-2010, 10:51 AM
BALLSS BALLSS is offline
BALLSS
Default
a tool like this http://www.myaston.com/k/?view=item&...taller+J+35621
makes the job VERY easy. I did not use the KM one, IIRC it was a "matco" one i borrowed from a friend but works the same. bolts to back of crank and you just screw in the center bolt/handle on tool to press it in.
As mike said you can tap it in evenly without a tool but if you can find a tool cheap/free than use it.
Grease inner lip of seal before install. My $02 is go with the 'rubber" FelPro (not teflon) rear main seal.
__________________
\'96 BBB 383/T-56
  #5
Old 07-08-2010, 01:10 PM
HYWAY KOP's Avatar
HYWAY KOP HYWAY KOP is offline
HYWAY KOP
Arrow
BALLS,....Thanks again for the info on this. In a few weeks I'll be installing my YANK and will change the rear main at the same time.
__________________
FRANK
  #6
Old 07-08-2010, 02:49 PM
Oklahoma Oklahoma is offline
Oklahoma is on a distinguished road
Default
I used the felpro rubber one as well. So far no leaks. As Roger said, use the tool if you can borrow one. If not, I used a small piece of wood to tap mine in. It is only a 3 minute job --- once you get the tranny out!
__________________
Ron
96 Impala SS, T56, CenterForce DF 4.56 gears, 383 Stroker, AI Heads
05 Dodge Ram SRT10
08 Trailblazer SS
79 Chevy Luv 4WD
  #7
Old 07-08-2010, 04:41 PM
Default
lol thanks guys, if i can i'll see about that tool, but this tranny drop is gonna blow!! more then likely i'll be doing this in my driveway(hoping not the street) and if i'm lucky my bro can give me a hand, since hes dropped his before
__________________
So Cal INC
1996 Caprice 9c1
5-15-1996
  #8
Old 07-08-2010, 05:13 PM
BALLSS
Default
you will be glad if you bought this...
http://www.harborfreightusa.com/usa/...o?itemid=39178
__________________
\'96 BBB 383/T-56
  #9
Old 07-08-2010, 05:22 PM
Default
wow 80 bucks is not a bad investment, but its also not in the budget right now, unless there is a great sell out here, i think i missed the 4th sale
__________________
So Cal INC
1996 Caprice 9c1
5-15-1996
  #10
Old 07-08-2010, 06:24 PM
BALLSS
Default
when I got mine it was $50....floor jack balance act is the "cheap" option
__________________
\'96 BBB 383/T-56
Forum Jump
(c) 2007-2011 Impala SS Forum
