#21
I like it, looking good.
Mav
__________________
'95 DGGM.... '94 BBB.... ISSCA Region 3 Director
| Sponsored Links | ||
Advertisement | ||
#22
this build is sick i would luve to do something like that but my money doesnt allow me to
keep up the great wrk. i wanna see more pics of that engine. are u doing anything to the interior of the car?
__________________
Ecam racing engines |
#23
subscribed...
Nice build!
__________________
![]() '95 DCM Impala SS 125,000 miles Jax INC CAI, no cats, 2.5" exhaust with flowmasters and H pipe, 4.11 gears, Eaton posi, PCMFORLESS tune, airpump delete, bonnies, lowered on 22"s, tinted tails, GEN 2 Tri-y's, extended upper and lower rear control arms New motor under way!!
#24
sorry bout that
__________________
NotoriouSS Tad <-- up to no good! 96' ImpalaSS - Johhny 5 - 7.9 @ 89.07 1.734 - waiting for the DD 9C1 to get out of the way 96' 9C1 - POS / DD / Beater - wiring nightmare in progress~! 67' El Camino - Rosie - 7.9 @ 86.5 1.77 60' on a street tire NA Click here to check out my EFI tuning Blog! |
#25
Riiiiight...
So...wanna buy some valve covers?
__________________
EVERY day is the Zombie Apocalypse
Unless you are swimming or on fire there is no such thing as too much ammo www.libertydwells.com |
#26
I agree, your not gonna be happy. I have a set that I can't use either.
#27
Thanks all, progress is slow but I should get some time around the holidays to get the frame indoors, paint it, finish welding up a few things (going to extend the the crossmember support to overlap the boxed section of frame) and finally get the suspension together to make it a rolling chassis.
Still thinking about fuel tank plans. After taking the measurements, the 89 caprice tank is going to be too low for my peace of mind with a 2-3" sump hanging down. Still waiting for it to come in the mail to see for sure though. Going to start doing the measurements to see about using a flanged mustang style tank, weld the sump in and should have a lot more clearance. Not worried though, i'll figure something out...if I have to cut up the trunk so be it...i'll make it look goooood ![]() Tad, I noticed on the canton valve covers...aside from the obvious of not being able to use the greatest invention on earth AKA the GM orange valve cover gaskets, I noticed that where they weld the corners on there is an obvious step up in height after the weld (crappy aligning of the joints, too mind grinding on the weld, IDK). I'm going to lay a bead with the TIG at work and grind it down as flat and level as I can get it and give them a try with cork gaskets. If that doesn't work, screw em. What problems exactly have you guys had with them? We used them on one or two cars at work (bigblocks) and didn't have any unusual problems with them but I agree they are a big step down from OEM in rail design department. Any leaks after modding them and they are scrap but if I can get them to work they would look pretty awesome. BTW, you know I am flying you down here to tune this beast in what, 2022 when I get this thing running? So get ready for a vacation to beautiful NY! lol ![]() I'll get pics of the motor soon. I'll be taking it home from the machine shop and bringing it to my shop to assemble as soon as my machinists is done balancing it for the new pistons. Think i'll be sticking with the LT1, if anyone has an LTCC setup for sale let me know! Plenty of pics of every last detail will follow...but time to work on it is few and far between ![]() thanks for the interest everyone! It really keeps me motivated!
__________________
96 BBB --- In the works--- Forged 396, D1SC, AI 200cc, LTCC, TH400/Gearvendors OD, KORE 3 C5/6 brakes, notched/boxed frame, ect... http://www.impalassforum.com/vBullet...formance+build --frame off build up thread 94 BBB (daily driver) Flowtech afterburners, Summit turbos, Bryan H PCM, RAISS, Hotchkis springs, Bilstein sports, Global West rear LCA's, PPM Poly front end bushings Last edited by SSandman; 11-15-2010 at 10:50 AM. |
#28
![]() One last pic of the underbody. 2 coats of POR15, two coats of Blackcote topcoat. FYI the blackcote comes out shiny (similar to the uncleared paint on the firewall of our cars) but the bare POR15 has a much deeper, glossier look. I chose the blackcote as a topcote vs bedliners and such because the blackcote you can blast with a spray of brake cleaner, wipe it down and none of it comes along for the ride. Great for cleaning up when things go wrong lol. Random shot: My cheapo harbor freight auto dimming mask, welding up an exhaust for a friend. This thing isn't bad, not like the millers we have at work though.
__________________
96 BBB --- In the works--- Forged 396, D1SC, AI 200cc, LTCC, TH400/Gearvendors OD, KORE 3 C5/6 brakes, notched/boxed frame, ect... http://www.impalassforum.com/vBullet...formance+build --frame off build up thread 94 BBB (daily driver) Flowtech afterburners, Summit turbos, Bryan H PCM, RAISS, Hotchkis springs, Bilstein sports, Global West rear LCA's, PPM Poly front end bushings |
#29
You a brave soul working under that thing with only those 2 jackstands that close!!
Looks great though.
__________________
1995 9C1 06 CTS-V 1972 C10 shorty 1969 C30 Wrecker. |
#30
The canton valve covers seal poorly
the gasket are impossible to alighn durring install you have to glue the gasket to the valve cover pre install Tune it in NY hell yha! I would love to. Stay modivated! do at least one thing a day. If you can only work :20 minutes before or after work that is progress then on the weekends... head down..music on...energy drink cold...go go go~!
__________________
NotoriouSS Tad <-- up to no good! 96' ImpalaSS - Johhny 5 - 7.9 @ 89.07 1.734 - waiting for the DD 9C1 to get out of the way 96' 9C1 - POS / DD / Beater - wiring nightmare in progress~! 67' El Camino - Rosie - 7.9 @ 86.5 1.77 60' on a street tire NA Click here to check out my EFI tuning Blog! Last edited by ProTools4; 11-15-2010 at 03:30 PM. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
