Anyone baffle the 6x9s on the rear of a wagon? - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91 thru 96 B-body Model Specific > Wagons
Thread Tools Display Modes
  #1
Old 08-12-2010, 06:05 AM
bondovw's Avatar
bondovw bondovw is offline
bondovw has a little shameless behaviour in the past
Default Anyone baffle the 6x9s on the rear of a wagon?
Yea , I know its car audio , This is a wagon only problem ! Anyone do anything to improve the rear 6x9s on a wagon? i was thinking about either fiberglassing the open area so they are sealed or buying the foam 6x9 baffles on e bay. Or should I give up and go work on something else?
__________________
I tint tail lights and fix bad bondo!
Old 08-12-2010, 08:02 AM
GoldSSWagon's Avatar
GoldSSWagon GoldSSWagon is online now
GoldSSWagon is an unknown quantity at this point
Default
I actually sealed the speaker to the bottom side of the cargo panel with some 2" foam. That way I used the whole cavity of that area as a chamber. Works extremely well. You will like the difference.
  #3
Old 08-12-2010, 08:05 AM
Pat's Avatar
Pat Pat is offline
Pat is an unknown quantity at this point
Send a message via MSN to Pat
Default
GM use to put the foam baffles on their high end cars with the upgrade factory sound system
if you happen to be in a junk yard take a look in the trunks of full sized boxy B and C body GM and you may find GM grey foam 6 X 9 baffles, I gotten them in most of my cars now
__________________
  #4
Old 08-12-2010, 08:40 AM
rematar's Avatar
rematar rematar is offline
rematar is an unknown quantity at this point
Default
I tried a little plastic basket built for 6x9s. It had very little volume and my ears claimed it made the sound more tinny.
Goldsswagon, are you talking about a piece of foam like you would take camping? How did you attach it and how big of a space did you create?
__________________
95 dcm wb4 rmw funeral car from fred
93 white woody rmw - sold
  #5
Old 08-12-2010, 09:11 AM
sherlock9c1 sherlock9c1 is online now
sherlock9c1 can only hope to improve
Send a message via AIM to sherlock9c1
Default
My two cents.
__________________
Those who turn their swords into plows will plow for those who don't. - Thomas Jefferson
  #6
Old 08-12-2010, 09:39 AM
Default
What I did was to cut a piece of 2" thick foam roughly 8x11 then cut a 6x9 hole in the center of it and sat it over the metal bracket that the speaker is bolted to then pushed the panel back in place. Space wise it created all the area between the wheel wells and the tail lights since the speaker is now sealed against the panel. Think I have a picture at home, can post it this evening if you like.
  #7
Old 08-12-2010, 10:25 AM
Turbo231 Turbo231 is offline
Turbo231 is an unknown quantity at this point
Send a message via AIM to Turbo231
Default
I ended up building my own out of foam...not fantastic, but certainly did the job nicely so that it's not awful. Helps the tinny sound quite a bit.
http://www.butchthecat.com/94caprice/speakers.htm
__________________
1986 Regal T-Type WH1 - 1999 S-10 4x4 - 1988 Fiero GT - 1994 Caprice Wagon
  #8
Old 08-12-2010, 10:49 AM
Stingroo Stingroo is offline
Stingroo is on a distinguished road
Send a message via AIM to Stingroo Send a message via MSN to Stingroo
Default
Yeah, I used the baffles from my Fleetwood.
  #9
Old 08-12-2010, 10:54 AM
Default
Those have big slices in the back of them. They aren't sealed by any means. Not sure what GM had them there for (whether aesthetics or protection from luggage or whatever), but clearly it was for something.
__________________
  #10
Old 08-12-2010, 12:00 PM
rematar's Avatar
Default
If it is different from turbo231 I would be interested. There's a couple of good links here already.
__________________
Forum Jump
(c) 2007-2011 Impala SS Forum
