#1
please help i really rely on my vehicle
I have been having this issue but I don't know if it is related to whats happening today. For the past month I have been having troubles starting my car sometimes it will fire up then stall right away, and start it again then its fine... other times it will really stumble Today, my car was fine in the morning to get to work, I went to start my car after work, and nothing, it wouldn't even turn over. So I disconnected the battery then it starts, I thought it was fine, I stop and get gas, went to start it after and nothing, so I disconnected the battery again, started it up, got home, shut off my car then started it again after 5 seconds, it started so I thought it was fine, 10 mins later I went to start it, and its not even turning over again.... thanks if anyone can help
__________________
-1994ImpalaSuperSport- http://www.cardomain.com/id/-thizzin- Last edited by -Andrew-; 08-17-2010 at 05:54 PM. |
| Sponsored Links | ||
Advertisement | ||
#2
Start by getting the battery tested.
__________________
94 Caprice Wgn,DCM,C5 corvette brakes,impala SS 17" rims,kumho tires,flowtech headers,pcm for less,ram-it,pioneer sound sys,hooker aero chambers,gauge pod,b&m floor shifter, full tint,Eibach springs,sway bars,3.73 yukon gears,eaton posi,14.2@97mph without a tail wind. |
#3
Ditto. Something drains your battery or the battery does not keep the charge. When you disconnect it you prevent draining and let the battery regain some charge. That's why the car starts after that.
__________________
1995 Cadillac Fleetwood Brougham 101,XXX miles. 1991 Cadillac Seville 175.000 Sold |
#4
Sorry, but some how it had something to do with my old alarm that was still installed, I took out the fuses to the alarm and my car works now, maybe it had something to do with the remote start? I should have told you earlier I ruled out the fact the battery could be dead when I saw that all my accessories worked fine, and it was holding a charge, and it started no problem after disconnecting the battery for 10 seconds..
I wouldn't have posted on here for a dead battery, come on guys that's the first thing I checked ![]() Thanks for the replies, I hope someone can learn from this.
__________________
-1994ImpalaSuperSport- http://www.cardomain.com/id/-thizzin- |
#5
__________________
grandpas wagon 1994 RMW 69K, clear corners, Gary's cables - battery, headlight, mech fan delete, air pump delete, home plate/first base delete, Bill Harper wiper mod, Corvette starter, 1LE elbow, Team SS pipe, K&N filter swiss cheese airbox, throttle body bypass, AutoMod Atlanta headlights. Last edited by grandpas wagon; 08-22-2010 at 10:42 PM. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
