What are the signs of a Bad Water Pump? - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Heating/Cooling/HVAC
Thread Tools Display Modes
  #1
Old 09-02-2010, 12:04 PM
STILL SLUM's Avatar
STILL SLUM STILL SLUM is offline
STILL SLUM is on a distinguished road
Default What are the signs of a Bad Water Pump?
I wanted to find out if my water pump was going out, what signs to look for. The car does not overheat but after you cut it off, radiator fluid comes out of the cap. I just replaced the thermostat to see if that would fix issue but it doesn't, Any suggestions on what to look for?
1995 Caprice 4.3
Old 09-02-2010, 12:07 PM
thebigbadWOLF's Avatar
thebigbadWOLF thebigbadWOLF is offline
thebigbadWOLF is an unknown quantity at this point
Default
1995 Caprice 4.3
weap hole on the underside of the WP, if it leaks its bad...no warning...its bad
overheating is another sign.
if water is coming out the CAP (where the stats goes) you didnt put it on right/tight enough.
you dont need a gaskit for the stat, thats the point of that rubber around the edge of the stat.
thanks
Wolf
__________________
Cali-SS
Originally Posted by Rocko350 View Post
Go fix your fleet of 91's. I wipes my tushy with TBI.......
Originally Posted by Needles.Kain View Post
Much like date night with BK, this isn't about what you prefer.
  #3
Old 09-02-2010, 12:09 PM
STILL SLUM's Avatar
Default
It bubbles back out of the radiator cap.
  #4
Old 09-02-2010, 12:10 PM
Default
the rad cap needs to be pressurized, so you could have a bad cap.
i assume you recently did some type of service....have you bleed the system?
__________________
Cali-SS
  #5
Old 09-02-2010, 12:16 PM
STILL SLUM's Avatar
Default
I just had the AC clutch removed due to it being damaged due to it grinding metal to metal until I get the entire AC compressor replaced. Nothing other than that.
  #6
Old 09-02-2010, 12:24 PM
fbi9c1 fbi9c1 is offline
fbi9c1 is an unknown quantity at this point
Default
Replace the radiator cap. Easy fix. Use the 18# '96 Cap.
__________________
Jim B.
'95 9c1, pcmperformance.com 93 tune, Dynomax Ultraflo catback, K & N box filter, LT4 KM, 160 stat, 3.08 Posi.
  #7
Old 09-02-2010, 12:27 PM
STILL SLUM's Avatar
Default
I'll replace the radiator cap & repost ASAP, thanks FELLAS!!
  #8
Old 09-02-2010, 12:29 PM
STILL SLUM's Avatar
Default
Just to make sure, this is the Cap that goes on the coolant tank above the battery.
  #9
Old 09-02-2010, 01:02 PM
Default
Yes, that is it.
__________________
Jim B.
  #10
Old 09-02-2010, 05:00 PM
STILL SLUM's Avatar
Default
I replaced the cap & the issue has stopped. I rode for 20 mins then parked & no fluid out of the cap. Thanks Guys for the $5.32 fix.
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
