1991-1996 caprice/impala Gears - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Drivetrain
Thread Tools Display Modes
  #1
Old 09-05-2010, 04:09 PM
fullname's Avatar
fullname fullname is offline
fullname is on a distinguished road
Default 1991-1996 caprice/impala Gears
"8.5" 10 Bolt 30 Spline Ring Gear Axle
GM8 - 2.56
GU2 - 2.73
GU3 - 2.93
GU4 - 3.08
GU5 - 3.23
GU6 - 3.42
G80= Positraction
1991 - L03 Caprice(5.0) 2.56Gears
1991 - L03 Caprice Wagon(5.0) 2.73Gears
1991 - L05 Caprice 9c1(5.7) 3.42Gears
1992 - L03 Caprice(5.0) 2.56Gears or (0ptional 3.08) or (LTZ 3.23)
1992 - L05 Caprice Wagon(5.7) 3.23Gears
1992 - L05 Caprice 9c1(5.7) 3.42Gears
1993 - L03 Caprice(5.0) 2.56Gears or (0ptional 3.08) or (LTZ 3.23)
1993 - L05 Caprice(5.7) 3.23Gears
1993 - L05 Caprice 9c1(5.7) 3.42Gears
1994 - L99 Caprice(4.3) 2.73Gears
1994 - L99 Caprice 9c1(4.3) 3.23Gears
1994 - L99 Caprice Wagon(4.3) 2.93Gears
1994 - Lt1 Caprice Wagon(5.7) 2.56Gears
1994 - Lt1 Caprice Wagon Tow Package(5.7) 2.93Gears
1994 - Lt1 Caprice 9c1(5.7) 3.08Gears
1994 - Lt1 Caprice B4U Tow Package(5.7) 2.93Gears
1994 - Lt1 Impala Ss(5.7) 3.08Gears
1995 - L99 Caprice(4.3) 2.93Gears (revised from the early 2.73)
1995 - L99 Caprice 9c1(4.3) 3.23Gears
1995 - Lt1 Caprice Wagon(5.7) 2.56Gears
1995 - Lt1 Caprice Wagon Tow Package(5.7) 2.93Gears
1995 - Lt1 Caprice (c1(5.7) 3.08Gears
1995 - Lt1 Caprice B4U Tow Package(5.7) 2.93Gears
1995 - Lt1 Impala Ss(5.7) 3.08Gears
1996 - L99 Caprice(4.3) 2.93Gears (Revised from the Early 2.73)
1996 - L99 Caprice 9c1(4.3) 3.23Gears
1996 - Lt1 Caprice Wagon(5.7) 2.56Gears
1996 - Lt1 Caprice Wagon Tow Package(5.7) 2.93Gears
1996 - Lt1 Caprice 9c1(5.7) 3.08Gears
1996 - Lt1 Caprice B4U Tow Package(5.7) 2.93Gears
1996 - Lt1 Impala Ss(5.7) 3.08Gears
So if u want some good cheap gears find any one of these vehicles like 1991-1993 9c1(5.7) for the 3.42s or a 1994-1996 9c1(4.3) for the 3.23 s
Old 09-05-2010, 07:14 PM
BBODYLT1's Avatar
BBODYLT1 BBODYLT1 is offline
BBODYLT1 is an unknown quantity at this point
Send a message via AIM to BBODYLT1
Default
Don't for get the 92 LTZ with the L03 had 3.23 gears.
__________________
99 Regal GS
HDI cold air|Gen-V Supercharger|3.5 Pulley|N* TB|LQ4 MAF|Drilled 180 t-stat|AL104 plugs|PJR wires|Alt rewire|9c1 Trans cooler|3.29 gears|TOG headers no cat no res|GTP dual exhuast|GTP trans mount|Flipped M/M's|Monte braces|Rear strut tower bar|GMPP Front-rear sway bars|GMPP trailing arms|9c1 struts|C-5 Corvette brakes|GTP HUD|05 GTP seats|Custom tuned.
  #3
Old 09-05-2010, 08:49 PM
wytltng's Avatar
wytltng wytltng is offline
wytltng is on a distinguished road
Default
My 91 had the posi & 3.08's. Would it be considered an LTZ even though it did not have leather & digital dash, but otherwise loaded to the hilt?
  #4
Old 09-05-2010, 08:59 PM
Fred Kiehl's Avatar
Fred Kiehl Fred Kiehl is offline
Fred Kiehl is on a distinguished road
Default
I believe the wagons came with 3.23s in the tow package as well.
__________________
1991 OCC upgraded LO5, LT1 cam, 46mm TBI, bored intake manifold, wrapped headers, true duals w/Flowmasters, 3.23 posi, flash to pass, drop spindles & springs, custom fender skirts, stainless full moons, Recaros, Blazer console, Nardi/wood SW w/QR, custom wood shift knob, Pioneer DEH P77DH
1992 OCC now with 5.7 tbi, DEH P77DH
For a parts list, check http://www.impalassforum.com/vBullet...1#post11691762
  #5
Old 09-05-2010, 09:07 PM
BBODYLT1's Avatar
Default
No, the LTZ's also got the FE3 springs, 235 tires and a few other things, its been a while since my LTZ so I don't remember exactly the options it had. But it had every option but leather and a sunroof, not to get off the topic though.
__________________
99 Regal GS
  #6
Old 09-06-2010, 06:55 AM
wytltng's Avatar
Default
Gonna check my option codes or build sheet today.
  #7
Old 09-06-2010, 12:11 PM
sherlock9c1 sherlock9c1 is offline
Sophomore Member
sherlock9c1 can only hope to improve
Send a message via AIM to sherlock9c1
Default
Hey fullname, add the axle housing size, carrier size an the three-digit RPO code to your list and you'll get a sticky!
__________________
"As I have gotten older, I have become much more patient with some things, and much less patient with other things." - sherlock9c1
  #8
Old 09-07-2010, 08:00 AM
fullname's Avatar
Default hummmmmmmmmmmmm.. lets see
Originally Posted by Marky Dissod View Post
1)
"1994 - L99 Caprice Wagon(4.3) 2.93Gears" ... Good luck finding this ONE ... IT is extremely rare
2)
Per the ImpalaSS FAQ and some factory documentation, the standard axle ratio for all L99 4.3L Caprices is 2.73, not 2.93. More importantly, all 2.73 B-bodies used a smaller, weaker axle housing.
3)
If you want some good cheap gears, and are lucky enough to find these ...
1993 L05 Cadillac Fleetwood V4P Tow Package 3.73
1994-1996 LT1 Cadillac Fleetwood V4P Tow Package 3.42
the 2.73Gears only came on the 1994 Caprice Civilian L99(4.3) and was later changed to 2.93Gears for the 1995-1996 caprice Civilian L99(4.3) Models
NEW FOR 1995:
* Impala SS model was available interim '94
* Caprice Classic LS model discontinued
* Bosch ABS V (TM) anti-lock brake system
* Revised exterior appearance w/new foldaway, outside rearview
mirrors and a new quarter panel, and quarter window treatment
(similar to Impala SS)
* Enhanced family of radios
* 2.93 axle ratio standard with 4.3L V8 engine (replacing 2.73
axle ratio)
* Cinching safety belts replace "free-falling" design (rear
seat)
http://www.caminokid.com/1995_chevrolet_caprice.htm
  #9
Old 09-07-2010, 06:24 PM
Marky Dissod Marky Dissod is offline
Marky Dissod is an unknown quantity at this point
Default
Originally Posted by sherlock9c1 View Post
Hey fullname, add the axle housing size, carrier size and the three-digit RPO code to your list and you'll get a sticky!
1)
2.56 ... 2.93 ... 3.08 ... 3.23 ... 3.42 for 94-96 Cadillac Fleetwoods with V4P Tow Pack ... and 3.73 for 93 Cadillac Fleetwoods with V4P Tow Pack
all used the 8.5" axle housing.
Only 2.73 used the 7.625" axle.
2)
2.93 ... 3.08 ... 3.23 ... 3.42 ... 3.73
all used the Series 3 carrier.
Only 2.56 used the Series 2 carrier.
__________________
1g1bl82p7rr127841
Rest In Pieces, In Peace
  #10
Old 09-07-2010, 06:46 PM
KLASS1C's Avatar
KLASS1C KLASS1C is offline
KLASS1C is on a distinguished road
Default
my trunk has a gw9 code which i believe is 2.93's...
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
