Opti vent line check valve and ??? - Page 2 - Chevy Impala SS Forum
Impala SS Forum
Thread Tools Display Modes
  #11
Old 10-03-2010, 05:59 PM
WindSSurfer WindSSurfer is offline
WindSSurfer
Default Dorman valve fits
This Dorman valve fits. It can replace the one way check valve.
Dorman - OE Solutions Vacuum Check Valve Universal - 47149
$4.99
We need to fabricate the restrictor/filter. Anyone have any ideas. How much flow needs to be restricted?
__________________
94 RMW
Custom tune (secret tuner), Fred Brown trans, Homemade RAISS, LT4 knock mod, X-pipe, Dynamax in and out muff dumps in front of rear wheels, Gary's headlight & batt. cable, Mueller bushings, Air lift bags w/aftmkt compressor, Blacked out window chrome/pillars
TB bypass, Tranny cooler w/fan, Air pump delete, Elec. fan cnvrsn, UMI LCAs, HO swaybar, Bilsteins, Vogtlands, ZQ8s, Blazer floor shift cnvrs w/twin buckets, leopard print velvet roofliner
Old 10-03-2010, 06:07 PM
POPIMPIN CUSTOMS I.N.C.'s Avatar
POPIMPIN CUSTOMS I.N.C. POPIMPIN CUSTOMS I.N.C. is offline
POPIMPIN CUSTOMS I.N.C. is on a distinguished road
Default
Originally Posted by WindSSurfer View Post
This Dorman valve works. It will replace the one way check valve.
$4.99
yeah screw chevy and there $60 for a new one.... i need to get some new filters for my homemade harness lol
__________________
ALL RWD,4 B BODIES!!!
1995 white 9c1 24 inch rims, muffler delete 4-20-09,hollowed cats, touchscreen, kicker cvx 15 2000 watt rms DD
1991 CAPRICe CLASSIC 1st B Body all original 350 tbi over 200,000 custom 20's sold it in like '06 and hate myself for it!!!
1991 caprice w 305 around 160,000 paid $600 sold for $1200
1976 datsun 620 truck
Proud owner of a RARE 1965 oldsmobile starfire 425 big block, also B BODY 400+- horse MY LT1 EATER
http://www.cardomain.com/ride/2417157
R.I.P. DAVID SSON22'S
  #13
Old 10-03-2010, 06:23 PM
HUF's Avatar
HUF HUF is offline
HUF is on a distinguished road
Default
A cigarette filter might work. LOL
__________________
1995 Cadillac Fleetwood Brougham 105,XXX miles.
  #14
Old 10-03-2010, 10:04 PM
Garrison Garrison is offline
Garrison is on a distinguished road
Default
If their opti fails due to some Jerry rigged set up, $60 bucks will seem like cheap insurance.
I hate paying for something that doesn't seem priced fairly but time is $ and I'd end up paying $500 if I devoted the time in trying to build one versus making $.
I hope they can do it though and sell a bunch of them for $25 bucks.
  #15
Old 10-03-2010, 10:07 PM
HUF's Avatar
HUF HUF is offline
Default
Come on guys, let's come up with $15 vent harness. All we need is an accurate vacuum meter, new harness and some work to test homemade modifications.
__________________
  #16
Old 10-03-2010, 10:22 PM
Default
I just offered $40 bucks for one. I don't even need one [and my car still isn't even drivable ~ unrelated issues] as mine is new but for $40 bucks I figured it was worth it as a spare so I'm really no help with a price point perspective.
I'll offer my support as I wouldn't have a clue where to start otherwise.
  #17
Old 10-03-2010, 11:42 PM
Mr pogo's Avatar
Mr pogo Mr pogo is offline
Mr pogo is on a distinguished road
Default
need to find out what the orifice size is on the restrictor, might be under the part specs or in the fsm.
or take one apart and see.
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
  #18
Old 10-04-2010, 11:56 AM
Henry '06 Henry '06 is offline
Henry '06 is on a distinguished road
Default
I followed this write up, mine ended being clean though.
http://www.9c1.net/forum/index.php?s...ic=174356&st=0&
__________________
1995 9c1 Impala Clone
  #19
Old 10-06-2010, 02:28 PM
HUF's Avatar
HUF HUF is offline
Default
Originally Posted by Marky Dissod View Post
I just took apart a V&V Harness ... for which I paid ... $50 ... plus $15 shipping ... ...
All the plastic orifices are the same size: 3/32" ID.
Using unexceptional lung power, I pulled and pushed air manually and individually, through each CHECK VALVE.
The larger of the two CHECK VALVES either contains (more likely), or is (less likely), the filtration media; based on the greater difficulty in pulling and pushing air through it (that, and I can't see through it either.
I could neither pull nor push air through either of the two CHECK VALVES 'from blue to white'. BOTH CHECK VALVES only permitted air to pass 'from white to blue'.
The filter on 'shoebox's V&V Harness is only solid blue, not twotone white & blue. Maybe his was merely a filter/flow reducer, but on mine, it's one of two CHECK VALVES.
1)
That neither explains nor justifies the egregiously brazen and ridiculous markups.
(I've heard of Lexus charging $800 for a CMOS battery, by the way, so I'm not surprised, just angry.)
2)
Though I'll admit that it doesn't answer the question of how much flow needs to be restricted ... how many combo CHECK VALVE/filter/flow reducers of that specific physical configuration could there really be?
3) Since it's apart ... with what, and how, do I test the check valve/filter/flow reducer's restrictive value?
The write-up Henry '06 was referring to will answer your questions:
"...If you don't find yourself replacing the harness, there is a way to clean the piece that causes the most problems: the pinhole check valve.
Before I explain that, please note that there are two check valves in this system. The first is located closer to the intake manifold on the driver's side. The vacuum line attaches to a nipple on the side of the aluminum manifold and runs to the first check valve. This first valve is called a "one way" valve (#1 in the diagram above). It typically doesn't go bad very often. But it should be inspected as well. If you blow through it, air will only go one way.
The second valve in the chain (the pinhole valve, or GM calls it a filter) is the one that causes the most problems. This is #2 in the diagram above.
It is located about here, though it could be further back toward the intake manifold on some cars. I've relocated/unburied mine since I like to check on this and keep it clean:
Remove it from the vacuum line by giving each tube a tug on each side.
Once removed, it looks like this. Note that one end is open plastic, and the other has a metal insert/collar as shown. This side is actually the location of the pinhole.
You can hold the valve up to a bright light source to inspect the pinhole. You should see a small point of light pass through as shown.
If light does not pass through or you feel like cleaning it anyways, then stick a very small pin or piece of wire. In this example, I stripped a twisty tie. Even that was a little too thick. A pin or a needle with a sharp point is best for this job. "
What I do not understand is how a pinhole can act as an unidirectional check-valve.
__________________
  #20
Old 10-06-2010, 04:38 PM
Sshockr Sshockr is offline
Sshockr is an unknown quantity at this point
Default
I don't believe its a check valve so much as its a restriction orifice.
The check valve is one way and is the check valve.
The second part is the pinhole and is just a flow restrictor. It works exactly like restrictor plates in Nascar.
And rather than dig our my fluids text books I'm going to leave it at that.
- Brian
__________________
'95 B4U LT1/T56 in Purple Pearl. 24x 355 with I believe most of the bolt-ons.
'63 C10 LT1/4L60E from B-Body. Rides like a Cadillac thanks to air bags.
'06 GTO LS2/T56 Torrid Red with CAI and Borla Cat-back thanks to the lady who rear ended me.
Still in Wichita.
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
