Parking Brake Release - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91 thru 96 B-body Model Specific > Fleetwood
Thread Tools Display Modes
  #1
Old 10-18-2010, 02:10 PM
cason234's Avatar
cason234 cason234 is offline
cason234
Default Parking Brake Release
Hello all,
I've had my Fleetwood for a year and a half, and one thing on it has never worked, but I'd like to fix it..... the parking brake.
If I put my foot on the parking brake lever and push it to the floor, it simply pops right back up and will not stay depressed. I can tell that it will hold the car (just to check, I've pushed on the lever while the car was in gear), but the lever won't 'catch'..... ie: it just jumps back to the 'released' position and won't stay down (in other words, the problem is at the front of the car, not the brakes themselves).
Any others experience the parking brake not catching? Is it possibly a vacuum issue? I've never really looked into how it functions, but I figure before I rolled up my sleeves, I'd check the list here.
Thanks in advance for your help!
__________________
1994 Hardtop - Black on Black / 4.10's / Auburn Posi / Trifecta PCM / Corvette starter / 1G starter cables / Traction Control relocate / Denny's Aluminum Driveshaft / Hotchkis Springs / Bilstein Shocks / BMR Sway Bars / C3 Fabrication LCA's / SS Wheels / MOMO 10" Steering wheel / Homemade CAI / Black Troll Hair seatbelt pillars / Summit Turbos / cat delete / 3" stainless tailpipes
Old 10-18-2010, 06:45 PM
96 Black 96 Black is offline
96 Black is an unknown quantity at this point
Default
Try it in Park. There may be a feature that auto releases it in any gear.
__________________
. . . . . . . . . . . . . . . . . . . . . . . . "Oh Bob, It's So Big And Long!" . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
\'96 BBB: SSRI, Herter Tune, Tri-Y II, SLP SS, 3000 Edge, F/HO bars, METCO extendeds, Bilsteins, currently Vredestein Ultrac Sessanta (315/35 rear)
\'95 FTSS: total mono gray, SSRI, Anthony tune, Aero catback/H/resonators, SS bars and coils, Hotchkis LCAs, Bilsteins/Airlift 1000, NL rear discs
  #3
Old 10-18-2010, 09:53 PM
skill3 skill3 is offline
skill3 is an unknown quantity at this point
I had the same problem. I figured out it had to do with the tooth mechanism. I bought another parking brake assembly from a forum member. I replaced it and it works fine. After I got the non-working assembly out, I still couldn't figure out the problem. Good luck!
  #4
Old 10-18-2010, 11:03 PM
Fred Kiehl's Avatar
Fred Kiehl Fred Kiehl is offline
Fred Kiehl is on a distinguished road
Default
The ratchet assembly is not engaging the sector gear. You may have a sticky, or worn ratchet arm. Try shooting it with some WD40 or equivalent. The release arm may be bent or the cable end is caught on the wrong place.
__________________
1991 OCC upgraded LO5, LT1 cam, 46mm TBI, bored intake manifold, wrapped headers, true duals w/Flowmasters, 3.23 posi, flash to pass, drop spindles & springs, custom fender skirts, stainless full moons, Recaros, Blazer console, Nardi/wood SW w/QR, custom wood shift knob, Pioneer DEH P77DH
1992 OCC now with 5.7 tbi, DEH P77DH
For a parts list, check http://www.impalassforum.com/vBullet...1#post11691762
  #5
Old 10-19-2010, 04:15 PM
cason234's Avatar
cason234
Default
Thanks guys.... I'll take a closer look at the mechanism itself. (BTW: this condition exists in any gear, Park or Neutral included)
appreciate the responses.
__________________
  #6
Old 10-19-2010, 04:16 PM
cason234's Avatar
cason234
Default
Was this tough to get at? How much work involved? I'm comfortable tackling anything, but it sure looks like it's buried in there!
__________________
  #7
Old 10-19-2010, 08:04 PM
It wasn't that difficult. I did it completely by myself, but a helper would be nice. I started by unbolting the top nut from the firewall in the engine compartment. There is also a bolt that goes from the assembly to the kick panel area (at least I think there is). The easiest way to remove the brake cable is after unbolting the assembly. Reverse to install. I would buy the replacement assembly first. Having it in hand gives you a guide. I think it took me about 30 minutes to do the whole process.
  #8
Old 12-27-2011, 09:43 PM
joflewbyu2 joflewbyu2 is offline
joflewbyu2 is on a distinguished road
Default
Same problem. Going to investigate mine in the AM.
  #9
Old 12-28-2011, 09:41 AM
Default
Just got to it this morning. Took the under dash cover off and shined a flash light. Noticed the slack in the parking handle cable. The lever was rusted. Sprayed lubricant and back in business. Worked the lever a little and works like a charm.
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
