Smog pump delete Bolts to plug exhaust manifolds? - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Exhaust
Thread Tools Display Modes
  #1
Old 10-26-2010, 01:34 AM
Steves95SS's Avatar
Steves95SS Steves95SS is offline
Steves95SS
Question Smog pump delete Bolts to plug exhaust manifolds?
Guys I had deleted my Smog Pump along time ago as well as had the PCM reprogrammed for it but never took off the aluminum crossover tube from one side exhaust manifold to the other. Since I recently rebuilt the motor and put it back in I want to go ahead and plug the exhaust manifolds where the tubes screwed into. So my question is where can I purchase the large Bolts to plug the exhaust manifolds? I know NAISSO superstore used to sell them but I looked and couldnt find them there. Where can I buy these? Thx Steve
__________________
95 DGGM SS, RAISS Intake, 160 Stat, TB Bypass, Descreened MAF, PCMforless Programming, Flowmasters, MSD 8.5 wires, Cowl Hood, LT4 module, 20" KMC SS Rims.
Old 10-26-2010, 07:21 AM
leak1210 leak1210 is offline
leak1210 is on a distinguished road
Default
Do a search for 'air pump delete' there are like 3 good threads on this topic. I used the jeep drain plug from NAPA referneced in one of the threads. Good Luck.
__________________
95 Impala SS, 79K, 304SS GEN II TRI-Y, 304SS CIA exhaust, tubular xmember, throttle body bypass, 160 t-stat, stealth bolts, LT4 KM, PCMFORLESS tune, Gary's cables, vette starter, 3.5MAF, RAISS, Racetronics, 55W 5000K DDM HIDs, s10 oil pressure sensor, AIR delete, Hotchkis springs/Bilstein shocks.
Deceased: 96 Caprice 9C1
  #3
Old 10-26-2010, 02:04 PM
eshaw301 eshaw301 is offline
eshaw301 is on a distinguished road
Default
I used the stock bolt and cut the tube, smashed the tube closed, and folded it over and put it on my headers.
__________________
Vandalized by the ex!!!
  #4
Old 10-26-2010, 02:15 PM
94MI9C1's Avatar
94MI9C1 94MI9C1 is offline
94MI9C1 is on a distinguished road
Default
You could always weld them shut like I have done on my cars before headers
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
1994 Chevy Caprice 9C1, 126,000 miles, T56, 4.10's
C6 Grandsport Brake Install C6 Z06 Wheels T56 Installation Manual
  #5
Old 10-26-2010, 02:21 PM
KW Baraka's Avatar
KW Baraka KW Baraka is offline
Location: South Central Texas....By Way of the South Side of Chicago!!!!!
KW Baraka has a little shameless behaviour in the past
Default
Originally Posted by Steves95SS View Post
......So my question is where can I purchase the large Bolts to plug the exhaust manifolds......
Got mine from True Value.
I think they're 3/4"......been a long time.....
KW
__________________
1996 BBB SS, 398ci Solid Roller LT4
1995 DCM SS, Heads/Cam LS3
2014 Chevy SS; 429ci LS3 -- 508HP, 455TQ @ the wheels....track results pending
  #6
Old 10-26-2010, 02:41 PM
HuSSker's Avatar
HuSSker HuSSker is offline
HuSSker is an unknown quantity at this point
Default The no kidding scoop on manifold plugs.
'95 cars have 2 versions of fittings. The difference is shown in these 2 pics:
'94-early '95
Late '95-'96
Notice the fittings on the manifolds. The threads in the manifold itself ARE different.
If you have an early '95, you can use these oil drain plugs that can be bought at Napa for a few bucks. I'm told the part number is BK 7041016.
http://www.napaonline.com/Search/Det...016_0282450010
If you have a late '95, you can use a 5/8" flare cap, availible at your local Lowe's.
__________________
'94 Impala SS
#14 of all TRI-9 Impalas
SSRI
Kore3 C5 front brakes
WX3 Performance C5 rear brakes
Hotchkis springs/bars/rear LCAs
Herter tuned
CIA Quad 1 Cermachromed headers
Muffler Man stainless X-pipe/Dynomax UltraFlo mufflers
Street Trends Smoked Euro Head Lights
RMCR rear with Trutrack and 3.42 gears
"Up front there ought to be a man in black"--Johnny Cash
"Is there anything beer CAN'T do?"-- Hank Hill
  #7
Old 10-26-2010, 03:46 PM
KW Baraka's Avatar
Default
Originally Posted by HuSSker View Post
.......If you have a late '95, you can use a 5/8" flare cap, availible at your local Lowe's.
Yes....this is what I have on my SLP Headers......5/8" is the correct size!
KW
  #8
Old 10-26-2010, 06:07 PM
94MI9C1's Avatar
Default
-10 AN fitting works as well for the later years, on the stock manifolds they are the same opening they just have a fitting that converts it to a flare, you can take that fitting out and us the plug as posted above instead of the cap for a lower profile installation, but with headers they come with a flare so you have to use an AN cap or the cap that was posted above.
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
