Fixed my non-working Heated Seats *How-to w/ Pics* - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Interior
Thread Tools Display Modes
  #1
Old 11-19-2010, 10:46 PM
CoupeDTS's Avatar
CoupeDTS CoupeDTS is offline
CoupeDTS is on a distinguished road
Thumbs up Fixed my non-working Heated Seats *How-to w/ Pics*
My passenger heated seat never worked in my 96 Caddy FWB and I could find NO information on any sites on how to fix it so I gave it a shot myself.
First understand how they work. There is a switch on the seat that goes under the seat to a relay box that you can hear click when set on Hi or Low. The relay box gets power from the main power hookup under the seat. Power is then sent out to the Back rest heating element and the seat bottom element. The elements are made up of weaving wires that are underneath a glued down pad.
Here is the relay box removed from the seat. I took this apart and found a little corosion on the contacts for the relay. This wasnt the problem why mine didnt work but it could be for other people. Also good maintenance I guess
Since my relays were working the next thing to test is the elements themselves. Instead of tearing the seats apart you can test the elements with an ohm meter.
The black hanging plug is the plug from the seat back element. It has 2 wires. Set your ohm meter to 200 and touch it to both leads. It should be around 1 ohm. Could be 1.1 or 1.5, the elements themselves say .95 ohms so anything around that means there is no break in it. If there is a break in the elements wire somewhere it wont read any resistance.
These are the 2 wires that come from the bottom element. 1 had 2 wires and 1 has 4 wires. The plug with 4 wires put your multimeter end to the red wire and to one of the other wires on the 2 wire plug to test.
In my instance it was the bottom element that didnt have a reading. My seat back read 1.1. The bottom leather was pretty easy to release compared to the seat back. OF COURSE DO ALL THIS WITH THE SEAT OUTSIDE OF THE CAR!
Examining the element with the leather off I found a burnt spot. Obviously this is where the break was.
Instead of searching for a replacement I decided to try to repair it.
Turns out the wire is stranded copper wire with a hard jacket around it. This means it can be soldered easily. In the picture you can see the wire I stripped. MAKE SURE WHEN STRIPPING THE WIRE TO NOT CUT ANY STRANDS OF THE WIRE! This will weaken the wire and cause another burnout. Slowly strip away the insulation.
I used similar wire for the patch. Dont use anything smaller! Here you can see the patch.
To keep the cover back down over the element I used some gorilla tape. Glue might work also. I wouldnt use duct tape on stuff that heats up.
After the repair you can test the resistance again and see if it is fixed. Plug it all back in. Assemble the seat and enjoy heat again
__________________
Known for slammin' Cadillac Doors!
1996 - Fleetwood Brougham Black on Black V4P
1983 - Coupe Deville - Street Custom Show Lowrider
1970 - Calais 4dr HT
Old 11-19-2010, 11:08 PM
Fred Kiehl's Avatar
Fred Kiehl Fred Kiehl is offline
Fred Kiehl is on a distinguished road
Default
A break in the wire would read infinite resistance instead of no resistance.
__________________
1991 OCC upgraded LO5, LT1 cam, 46mm TBI, bored intake manifold, wrapped headers, true duals w/Flowmasters, 3.23 posi, flash to pass, drop spindles & springs, custom fender skirts, stainless full moons, Recaros, Blazer console, Nardi/wood SW w/QR, custom wood shift knob, Pioneer DEH P77DH
1992 OCC now with 5.7 tbi, DEH P77DH
For a parts list, check http://www.impalassforum.com/vBullet...1#post11691762
  #3
Old 11-19-2010, 11:28 PM
CoupeDTS's Avatar
Default
yea, I phrased it wrong. The meter always shows infinate, if it shows a reading than thats a change from the infinate
__________________
  #4
Old 11-20-2010, 11:14 AM
RollinSlow84's Avatar
RollinSlow84 RollinSlow84 is offline
RollinSlow84
Default
Thanks for the info. I guess I know what I'm doing tomorrow. The FSM does not have very much I formation on this job. Thank agian for putting up a thread on this.
__________________
2004 Suburban...What was I thinking...
1996 Fleetwood Brougham, Rear Disks, It handles now, tastefully modified
1984 Coupe DeVille, Budget Lowering Springs, 9C1 3.23 Posi/Disk Rear end, 18 and 20" Coys, awaiting 383/700R4 transplant.
1980 Malibu Coupe, Grandma fresh 100K original owner New Mexico rust free
1978 Pontiac Catalina Safari, old guy fresh 83K original owner New Mexico rust free
1996 Caprice Wagon SOLD
Happiness is driving a Wagon.
  #5
Old 11-20-2010, 12:02 PM
CoupeDTS's Avatar
Default
Luckily my break was easy to find. Usually its in the bottom because of all the movement from people sitting on it. My wifes buick SUV has a problem with the seat bottom heater too. I doubt youll find a break on the seat back.
As nice as it is to have the seat heaters these early versions werent very good. Ive had them in my 2000 DTS and my wifes SUV and a grand cherokee and those all get so damn hot u gotta turn them off. The fleetwood just gets warm, not hot. I think some of it has to do with the leather, the heat cant get through as easy. Those other cars the leather has holes in it, fleetwood doesnt. If you turn the heaters on and nobody sits in the seat you can barely feel the heat. But when you sit on it and push that leather up against the heating element you feel the heat better.
Doing some quick searches I couldnt find replacement elements so thats why I decided to try the repair myself. The element has part numbers on them so maybe theyre still available? But youll tear up your foam trying to get it off. If I had a new element I would stick it down on top of the old one.
__________________
  #6
Old 11-21-2010, 10:47 PM
Gregg-O's Avatar
Gregg-O Gregg-O is offline
Gregg-O is an unknown quantity at this point
Default
You left the bare soldered end's exposed to the padding??....
__________________
Taxes are not levied for the benefit of the taxed.
\'96 IMP SS BBB ,Stock, airbox is swiss cheese, K&N filter, Ultra Flows.
  #7
Old 11-21-2010, 11:18 PM
CoupeDTS's Avatar
Default
first of all it doesnt even get hot enough to melt solder. And its not exposed to the "padding" of the seat, the heating element has a fabric layer between it and the padding or leather. The only way it gets hot enough to burn like it did to begin with is when some of those strands of wire break and then you have all that amperage passing through just a couple little strands instead of a bunch, so it burns up.
I wouldve put something over the connections if I had something, but what would you use? I thought maybe heat shrink tube? Definately not electrical tape. Either way it doesnt get hot enough to harm anything on these particular heating elements.
__________________
  #8
Old 11-22-2010, 04:07 AM
MH-PALA MH-PALA is offline
MH-PALA is on a distinguished road
Default
thanks for making the threat stupid ol me didnt know they had heated seats
__________________
1998 Jeep Grand Cherokee
1991 Lincoln Mark Vii 60xxx miles but interior is crappy from the sun
Soon to have a 96 ss
  #9
Old 11-22-2010, 05:31 AM
Gregg-O's Avatar
Default
I was thinking heat shrink...I've never dealt with heated seat's so what do I know, seeing the burn mark just had me a little worried is all.
__________________
  #10
Old 11-22-2010, 09:26 AM
CoupeDTS's Avatar
Default
Newer heated seats (98+) get VERY hot. I dont know if solder would even keep on those.
__________________
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
