Front end alignment issues/93 Buick roadmaster wagon - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91 thru 96 B-body Model Specific > Wagons
Thread Tools Display Modes
  #1
Old 12-12-2010, 08:08 PM
Big Sexy 93 Big Sexy 93 is offline
Junior Member
Big Sexy 93 is on a distinguished road
Default Front end alignment issues/93 Buick roadmaster wagon
  • Hi, we have front end alignment issues with our 93 Buick Roadmaster wagon. Has been wearing down the front passenger side tire. What can we do to change the alignment?
  • Thank you.
Old 12-12-2010, 09:37 PM
Nick Danger's Avatar
Nick Danger Nick Danger is offline
Nick Danger is on a distinguished road
Default
Alignments are difficult to do without the proper equipment. I just take my car to a mechanic and ask him to align it.
The first time he told me that the idler arm was bad. I paid him for the time spent troubleshooting, replaced the idler arm, and brought it back for an alignment.
__________________
1994 Roadmaster Wagon.
Mrs Danger's site: www.unseengallery.com
  #3
Old 12-12-2010, 09:43 PM
94MI9C1's Avatar
94MI9C1 94MI9C1 is offline
94MI9C1 is on a distinguished road
Default
You only have one tire wearing? Odd scenario but I guess not uncommon, as Nick stated take it to a shop and have it aligned, easy enough. Make sure when they are done aligning it that you get a full print out and if anything is in red question it. Alot of shops charge about 60 bucks these days and do a toe and go and call it a day. If you are having one tire wear more than the other then this would indicate that you have a camber/caster issue on that side more than the other and it will need to be changed. Good luck
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
1994 Chevy Caprice 9C1, 126,000 miles, T56, 4.10's
C6 Grandsport Brake Install C6 Z06 Wheels T56 Installation Manual
  #4
Old 12-12-2010, 10:23 PM
Junior Member
Default Alignment issues
Thank you both for the help! Will post the outcome.
  #5
Old 12-13-2010, 06:29 AM
96 Black 96 Black is offline
96 Black is an unknown quantity at this point
Default
There is either a dedicated Stickie on tire wear indications, or you can search for the thread on the topic within the past 1-2 months in Tire/Wheels Section. I believe it was started by username "Firewood Will Rise Again".
Welcome to the forum.
EDIT: Here 'tis, http://www.impalassforum.com/vBullet...d.php?t=241292
8th one down, plus scads other good intel to take advantage of. Good luck.
__________________
. . . . . . . . . . . . . . . . . . . . . . . . "Oh Bob, It's So Big And Long!" . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
\'96 BBB: SSRI, Herter Tune, Tri-Y II, SLP SS, 3000 Edge, F/HO bars, METCO extendeds, Bilsteins, currently Vredestein Ultrac Sessanta (315/35 rear)
\'95 FTSS: total mono gray, SSRI, Anthony tune, Aero catback/H/resonators, SS bars and coils, Hotchkis LCAs, Bilsteins/Airlift 1000, NL rear discs
  #6
Old 12-14-2010, 12:06 AM
Fred Kiehl's Avatar
Fred Kiehl Fred Kiehl is offline
Fred Kiehl is on a distinguished road
Default
You may have lost the shims from the PS. You could also have a broken belt.
The way you can check it at home, is to use a small carpenter's level that will fit inside your rim, and a protractor. The top of the wheel should be slightly further out than the bottom. You can use a straight edge, the protractor and level to determine what the angle is. It should be about .8 degrees. You have to make the measurement on level ground.
Straight edge vertically on the lip, protractor center, and end of the level matched. read the bottom of the protractor. Actual specs are in the FSM.
__________________
1991 OCC upgraded LO5, LT1 cam, 46mm TBI, bored intake manifold, wrapped headers, true duals w/Flowmasters, 3.23 posi, flash to pass, drop spindles & springs, custom fender skirts, stainless full moons, Recaros, Blazer console, Nardi/wood SW w/QR, custom wood shift knob, Pioneer DEH P77DH
1992 OCC now with 5.7 tbi, DEH P77DH
For a parts list, check http://www.impalassforum.com/vBullet...1#post11691762
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
