How to Remove Varnish Deposits from a Carb? - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > General Topics > Misc.
Thread Tools Display Modes
  #1
Old 01-02-2011, 06:00 PM
Erik's Avatar
Erik Erik is offline
Erik is an unknown quantity at this point
Default How to Remove Varnish Deposits from a Carb?
I have to rebuild the carburetor for my snow blower and it has a fair amount of what looks like varnish buildup in the bowl and on the float. What's the best way to clean it up? Regular old carb cleaner? Something else? Thanks.
__________________
Nodding Tiger Mod
http://www.impalassforum.com/vBulletin/image.php?type=sigpic&userid=15034&dateline=1214775786
Old 01-02-2011, 06:19 PM
JZ9C1LT1's Avatar
JZ9C1LT1 JZ9C1LT1 is offline
JZ9C1LT1
Default
Brake cleaner is good. Gasoline or Acetone is also good.
__________________
96 9C1 LT1 with all the bolt on crap (Gone 1/08 to 9C1 heaven aka junkyard!)
95 9C1 LT1 New toy as of 6/09 (this one is now heading same direction as the 96)
95 9C1 LT1 The new black mariah! SOLD
95 9C1 LT1 Will be my 13/14 winter project
04 GTO SOLD
Originally Posted by BewbZowt(+ Y +)
Here's how it works: If I can see them, they are real.
  #3
Old 01-02-2011, 06:25 PM
LTwon's Avatar
LTwon LTwon is offline
LTwon is an unknown quantity at this point
Default
Hmmmm tough question!
__________________
May your worse day of 2016 be equal to your best day of 2015.
  #4
Old 01-02-2011, 06:42 PM
Mr pogo's Avatar
Mr pogo Mr pogo is offline
Mr pogo is on a distinguished road
Default
for varnish you want a dip type carb cleaner you can soak the parts in, not the spray stuff.
http://berrymanproducts.com/Products...sCleaners.aspx
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
  #5
Old 01-02-2011, 07:25 PM
Heavy_SS's Avatar
Heavy_SS Heavy_SS is offline
Heavy_SS is on a distinguished road
Default
Yep, this is the stuff my buddy uses for gummed up carbs when he buys a used motorcycle, typically the carbs are all 'effed up.
__________________
Originally Posted by Buford T. JuSStice View Post
Nobody is born into the Fat, Wise-Arse sitting in a paid house with a Camaro outside... you have to work for that.
Originally Posted by Big Kahuna View Post
Yolo!
Eric
'96 BBB-WX3 w/52k
Cam, heads, gears, exhaust!
  #6
Old 01-02-2011, 08:33 PM
SixSpd95's Avatar
SixSpd95 SixSpd95 is offline
SixSpd95 has a little shameless behaviour in the past
Default
Gasoline works great since it's usaully handy. The other stuff I am sure works well, but I never have any around. Cut a plasic coffee can or a gallon jug in half and let the parts sit for about 30 minutes and then just get a stainless or brass brush and finally just use compressed air to get the parts dry.
__________________
Norm Anderson
1996 DGGM......all stock, but back in the game!!
1996 BBHP#2/383.....SOLD!!
1994 DGGM Woody wagon.....mostly stock.....SOLD!!
1968 Impala Sport Coupe.....383/700R4.....SOLD!!
1995 DCM BBHP #97.....SOLD!!
1995 LAB Caprice wagon.....SOLD!!
  #7
Old 01-02-2011, 09:40 PM
Rocko350's Avatar
Rocko350 Rocko350 is offline
Rocko350 is on a distinguished road
Default
Definitely buy a new needle and seat. If the carb is varnished, disassemble it before dipping it in cleaner. The needle and seat will have some wear and will make the carb flood the engine if reused. Make sure not to submerge anything that isn't metal. Including the float.
Chris
__________________
94-95 Scan. Free, well written diagnostic software
http://www.mediafire.com/?0elo4c935uc5s
  #8
Old 01-02-2011, 10:10 PM
Erik's Avatar
Default
Thanks. I have a rebuild kit that includes new needle, seat, welch plugs and various gaskets and seals, so that should be good. I may try the gasoline first since I have that, and see what happens. Thanks for the tip on the Berrymans product too.
The float looks to be brass. Why not submerge it?
__________________
Nodding Tiger Mod
  #9
Old 01-03-2011, 02:15 AM
BewbZowt ( + Y + )'s Avatar
BewbZowt ( + Y + ) BewbZowt ( + Y + ) is offline
BewbZowt ( + Y + ) is an unknown quantity at this point
Default
Soak it in Pine-Sol.
__________________
Midwives help people out.
  #10
Old 01-03-2011, 05:48 AM
wood95sslr's Avatar
wood95sslr wood95sslr is offline
wood95sslr is an unknown quantity at this point
Default
Ditto what Pogo said Erik, get a gallon of carb dip. [I couldn't locate my gallon can for the product brand - it's outdoors in the petroleum locker in a freezing shed. Hotlanta NOT right now].
It won't hurt the brass seat or other brass parts; put them in a very small tin can and submerge it too - overnight for all.
Squeaky clean when done and can be douched with water to neutralize. Then hit everything with compressed air; parts and passages.
With carb clean, strain the carb dip to remove any carb crap and return it to its can for future use. Lasts long time in sealed container.
__________________
dw
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
