replaced rear turn signal bulbs and now they dont blink........ - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Electrical
Thread Tools Display Modes
  #1
Old 01-14-2011, 08:20 PM
9SEA1's Avatar
9SEA1 9SEA1 is offline
9SEA1 is an unknown quantity at this point
Default replaced rear turn signal bulbs and now they dont blink........
so i replaced the rear turn signal bulbs in my 96 caprice with LED bulbs. now my front turn signals will come on when i hit the blinker but not blink and i see no change in my rears when i hit the blinker or hit the brakes. any suggestions??? blown fuse?? i have no idea. where is the fuse location for the turn signals?
__________________
Adrian's Auto Upholstery
www.facebook.com/INCWA
www.facebook.com/AdriansUpholstery
Old 01-14-2011, 09:48 PM
94MI9C1's Avatar
94MI9C1 94MI9C1 is offline
94MI9C1 is on a distinguished road
Default
Typical problem with LED's, you need to install a "no Load" flasher for them to work. Typical flashers are thermal flashers and require a load to make the internals work, if you don't have the resistance of the bulbs there it won't work. I do believe this one will work for you but can't be certain
http://shop.advanceautoparts.com/web...S_612665743___
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
1994 Chevy Caprice 9C1, 126,000 miles, T56, 4.10's
C6 Grandsport Brake Install C6 Z06 Wheels T56 Installation Manual
  #3
Old 01-14-2011, 10:26 PM
Mr pogo's Avatar
Mr pogo Mr pogo is offline
Mr pogo is on a distinguished road
Default
that one wont work. you need the led flasher like grote makes, 2 terminal with separate ground wire.
plus a second flasher for the four ways.
if you just do the rears thats all you need.
if you do the fronts also you'll have to add load resistors to the fronts as 100% leds arent enough even for a led flasher.
also the front outer turn signal/parking light bulb is not convertible to leds without further mods.
I just finished the outside lights to 100% led, might do a thread on whats required.
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
  #4
Old 01-14-2011, 10:28 PM
9SEA1's Avatar
Default
How do they work/what do they do? Where does it go? And where can I get them? Sorry for so many questions.hahaha
__________________
  #5
Old 01-14-2011, 10:31 PM
9SEA1's Avatar
Default
I replaced the 1156 bulbs for the rears only. The inner and outer ones on the top.
__________________
  #6
Old 01-14-2011, 10:43 PM
Mr pogo's Avatar
Default
well Im at work and info is at home.
Ill see about pics too.
__________________
  #7
Old 01-15-2011, 01:50 AM
9SEA1's Avatar
Default
Coo thanks man
__________________
  #8
Old 01-15-2011, 05:26 AM
Mr pogo's Avatar
Default
ok Im having a brain fart cause its late but heres what I remember when I just had the rears changed to leds.
I only ran that for a week or two before changing everything to led which opened more cans of worms but thats another story.
the led flasher that fits a b body is the grote 44891, two terminal with a third wire that is attached to ground.
under the fuse box where the flashers are there is a predrilled hole perfect for ground using a sheet metal screw.
napa sells them, not sure if az does.
I believe I used one led flasher for the turn signals and one of the leftover stock flashers for the four ways.
the two stock flashers are different from each other because of more amp draw with the four ways so try each of them to see which one works.
hope this helps
__________________
  #9
Old 01-15-2011, 03:44 PM
9SEA1's Avatar
Default
Awesome! Thank you, Ive never put these in before and was lost. The autoparts stores we got up here are O'Reilly autoparts. I'll have to check otherwise I'll have to order them. Thanks again!
__________________
  #10
Old 01-18-2011, 10:01 AM
jonhpc's Avatar
jonhpc jonhpc is offline
jonhpc is on a distinguished road
Default
walmart carrys an electronic flasher as well
__________________
-92 ltz, T5 trans, R.I.P. 4/19/13
-94 9c1, sprints with 22's
-96 civi, the "behemoth"SOLD
-93 Fleetwood, SOLD
............FLA INC..............
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
