Foot on gas pedal to start - Chevy Impala SS Forum
Impala SS Forum
Thread Tools Display Modes
  #1
Old 02-06-2011, 12:51 AM
Young Steph's Avatar
Young Steph Young Steph is offline
Young Steph is on a distinguished road
Unhappy Foot on gas pedal to start
I have a 96 RMS with an OBD1 pcm an here lately I have to hold my foot on the throttle slightly an turn the key to start the car otherwise it will just crank an not start at all. I have a fresh tune up, MSD coil, MSD 6A Box and a fresh pcm tune by a reputable tuner. It just started out of no where. Once the car is started you're fine to go. I talked to my Programmer an he said something about the IAC could be clogged or it could be the weather conditions making it stick either way I'm open for advice. Almost forgot No Service Engine Light has came on at all.
__________________
96 Roadmaster fresh rebuilt lt1 with a cc503, f-body aluminum heads (slight port work), cc 1.6 pro magnums, cc valve springs, msd coil, march undrive, summit headers, mech fan delete, blah blah blah, ect
Old 02-06-2011, 01:32 AM
grandpas wagon grandpas wagon is offline
grandpas wagon is an unknown quantity at this point
Default
Even though you say it runs well, I would do a fuel pressure test. You should not have to press gas pedal to start.
__________________
grandpas wagon
1994 RMW 69K, clear corners, Gary's cables - battery, headlight, mech fan delete, air pump delete, home plate/first base delete, Bill Harper wiper arm mod, Corvette starter, 1LE elbow, Team SS pipe, K&N filter swiss cheese airbox, throttle body bypass, AutoMod Atlanta headlights.
All my posts contain 100% recycled electrons.
  #3
Old 02-06-2011, 02:14 AM
Default
I'll do a fuel pressure test asap. Thank you. My gas mileage is terrible too, I'm getting roughly 9-10mpg city. NOT GOOD
__________________
  #4
Old 02-06-2011, 03:45 AM
coppcarz coppcarz is offline
coppcarz
Default
Had that problem for 3 years, but finally replaced the Idle air control valve, and it solved the problem, and the car wouldn't stop shutting off during idling anymore....
  #5
Old 02-06-2011, 09:20 AM
RatSSled's Avatar
RatSSled RatSSled is offline
RatSSled has a little shameless behaviour in the past
Default
Sounds like a bad sensor, connection or ground for the ECT sensor up at the water pump. If the PCM doesn't get an accurate reading for coolant temp, it defaults to -40f (or something like that) and it goes pig rich. It will make it hard to start unless you floor the gas pedal, and it will give you crappy gas mileage.
__________________
______________________________________________
96 BBB Impala SS - Stock with bolt-ons 12.82 @ 106
96 DGGM Impala SS - 496 BBC 10.13 @ 134 all natural, 9.69 @ 143 on the gun
  #6
Old 02-06-2011, 10:06 AM
94MI9C1's Avatar
94MI9C1 94MI9C1 is offline
94MI9C1 is on a distinguished road
Default
Yeah what Rat said, usually is the water pump sensor is AFU both the fans will run after a certain time, I think it is 10 or 20 seconds or something. Also another thing to think about is a stuck injector, flooding the cylinder with the throttle blades closed there isn't enough air to fire it. Does it smell like it is running really rich?
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
1994 Chevy Caprice 9C1, 126,000 miles, T56, 4.10's
C6 Grandsport Brake Install C6 Z06 Wheels T56 Installation Manual
  #7
Old 02-06-2011, 04:22 PM
Default
It doesnt smell rich unless you let it crank a whilr then put your foot down to start it. You get a nice little cloud after that but if you just start with about 1/4 throttle your fine. The gas mileage is killing me though.
__________________
  #8
Old 02-07-2011, 12:01 AM
Choose1's Avatar
Choose1 Choose1 is offline
Choose1 is on a distinguished road
Default
You may have a stuck/leaky fuel injector. I recently had similar issues; very poor fuel economy (8-10 mpg), I also had to hold the gas pedal to start the car. Turned out I had a leaking fuel injector, replaced the injector and now it starts 1st crank without pedal. As for fuel economy I'll have to go through another tank before I can verify improvement.
__________________
Originally Posted by 350 View Post
Is that a blunt?
Sgt Guster
96 SS- CC 503, P&P AL Heads, CIA Tri-Y's, 58mmTB, Yank SC3000
C5 Corvette Vert- Forged Stroker 408, Custom Comp Turbo Cam, Stg 2.5 Patriot 317 Heads, C6Z06 Exhaust, Lambo's, STS Twin Turbo>>>>> No dyno or tune yet, expecting........ 700+RWHP
  #9
Old 02-07-2011, 12:37 PM
Default
The weird thing is once the car has ran an is warm it starts up immediately with no throttle at all. I hope its not an injector issue my budget is tight right now but with my luck that will be the problem
__________________
  #10
Old 02-07-2011, 12:44 PM
Terry #585 Terry #585 is offline
Terry #585
Default
I recently had the foot to the floor issue and it turned out to be the ETS (Engine Temperature Sensor) in the water pump. Dumb computer thought it was -40*. The carbon from running rich fouled an intake valve and I had to take off the head and get a valve job to fix it. I was throwing parts at it, and it wasn't until I got a scan tool on it that we (I needed help) found the problem. Test and diagnose before throwing parts at it.
Donít do as I do, do as I say.
__________________
Terry
2 1995 9C1s
30U Huet Silver Metallic built 5/26/95
36U Bonnat Silver Metallic built 7/19/95
1 1995 1A2
2001 Camaro B4C SOB -- one of 288
2008 Z06 Jetstream Blue built 10/11/07
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
