bleeding cooling system - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Heating/Cooling/HVAC
Thread Tools Display Modes
  #1
Old 02-16-2011, 07:21 PM
allwestss allwestss is offline
allwestss is on a distinguished road
Default bleeding cooling system
what is the proper way to bleed a cooling system?
__________________
96 Impala BBB
Old 02-16-2011, 07:46 PM
yippeekyaa yippeekyaa is offline
yippeekyaa is on a distinguished road
Default
I don't know about "proper" but here is my method. With the cooling system cold and full I open the bleeder screw and let gravity work to remove some air. Top off the system if needed, seal it up and crank engine. While waiting on it to heat up I jack up the front of car and put on stands. If you are impatient stick a dime in the throttle stop to hold the rev's up. When it's up to normal operating temps I turn off engine and open the bleeder to purge more air. A lot will come out now. Let the car cool, top off coolant level. Repeat. A third run of this never gets anymore air out for me. But it's nice to do just to be certain.
  #3
Old 02-16-2011, 08:06 PM
Nick Danger's Avatar
Nick Danger Nick Danger is offline
Nick Danger is on a distinguished road
Default
Buy the enhanced bleeder valve from BigBlackBeaSSt. Attach a transparent hose to the nozzle and put the other end in a bottle. Pour the coolant from the bottle back into the reservior. No mess.
http://www.impalassforum.com/vBullet...d.php?t=255705
__________________
1994 Roadmaster Wagon.
Mrs Danger's site: www.unseengallery.com
  #4
Old 02-16-2011, 10:20 PM
Default
thanks for all the help fellas you got me through,, i will be getting that enhanced bleeder valve asap
__________________
96 Impala BBB
  #5
Old 02-28-2011, 08:18 AM
96WAGON's Avatar
96WAGON 96WAGON is offline
96WAGON is on a distinguished road
Default
Are the LT1 Corvettes & Camaros any different in the same years? The reason I ask is because when you do a search on bleeding an LT1 cooling system it appears all they do is open the reservoir cap, start the motor, let it warm to operating temp, check to make sure their are no air bubbles in reservoir, top off if needed. The reason I ask is because I'll be replacing an upper hose soon. Thanks!!
  #6
Old 02-28-2011, 10:52 AM
96SSbbb's Avatar
96SSbbb 96SSbbb is offline
96SSbbb is an unknown quantity at this point
Default
Lowes Bleeder Valves.
http://www.impalaclub.com/naisso/For...TOPIC_ID=48233
__________________
ISSCA# 930
  #7
Old 03-01-2011, 06:39 PM
bighom20's Avatar
bighom20 bighom20 is offline
bighom20 is on a distinguished road
Default
Originally Posted by 96SSbbb View Post
Thats a nice bleeder valve, question tho in that link where does that clear tubing end at? do you let it jus dangle while driving?
__________________
94 Impala SS BBB-135k-Bagged on 20'' oasis-Sold
95 Impala SS DCM-Mostly Stock
ISSCA#2418
  #8
Old 03-01-2011, 07:40 PM
96SSbbb's Avatar
Default
I ran the hose behind the water pump and attached it to a bracket under the car. But you could run the hose where ever you wanted. I'll put up some pics later.
  #9
Old 03-01-2011, 07:58 PM
bighom20's Avatar
Default
ok i defintly would like to see the set up... also the bleeder valves they sale at lowes, they just screw right in no prob?
__________________
ISSCA#2418
  #10
Old 03-01-2011, 08:18 PM
96SSbbb's Avatar
Default
Just screw it in, the threads are a perfect match.
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
