automoter water temp!!! - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Electrical
Thread Tools Display Modes
  #1
Old 02-20-2011, 11:21 PM
1real95SS's Avatar
1real95SS 1real95SS is offline
1real95SS is on a distinguished road
Exclamation automoter water temp!!!
as i read all water gauges go bad in the impala and the sensor on the front by the water pump is for the pcm. i have a auto-meter gauge ready to install but need to know if i tap into the wire on the RH side of the block will my gauge read??
Old 02-21-2011, 12:23 AM
1real95SS's Avatar
Default
anybody? Ive ran everything but the sender wire and ground. where can i tap into??
  #3
Old 02-21-2011, 12:30 AM
1real95SS's Avatar
Default
or do i have to use the sending unit that came with the gauge?
  #4
Old 02-21-2011, 02:13 AM
BigB9000 BigB9000 is offline
BigB9000 is an unknown quantity at this point
Send a message via ICQ to BigB9000 Send a message via AIM to BigB9000
Default
Pretty sure you have to use the unit that came with the gauge.
Maybe remove the pipe plug from the driver side head and tap into it there?
I wouldn't mess with the WP sender though.
__________________
1996 9c1 L99, now w/ LT1. 208k and counting.
1996 SS BBB
  #5
Old 02-21-2011, 07:52 AM
94MI9C1's Avatar
94MI9C1 94MI9C1 is offline
94MI9C1 is on a distinguished road
Default
I don't know where you read that all temp gauges go bad, they are no more prone to failure over an Autometer gauge to be honest, most from what I can gather put one in for better accuracy.
As stated above DO NOT splice off the temp sender on the water pump, leave it alone.
If you aren't going to use the factory gauge just takeout the original sender on the passenger side and put in the new gauge sender. I really don't think that there is any difference in the senders to be honest, pretty sure all manufacturers use the same sender specifics.
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
1994 Chevy Caprice 9C1, 126,000 miles, T56, 4.10's
C6 Grandsport Brake Install C6 Z06 Wheels T56 Installation Manual
  #6
Old 02-21-2011, 08:18 AM
1real95SS's Avatar
Default
NOOOO i wasnt talking about tapping into the WP sensor i was reffering to the one on the passanger side.
as far as the gauges going bad, ive read countless threads of people saying they have been thru the same issue weather it was the sensor, gauge etc... seems common in these cars to have temp fail.
but as u stated ...
i should unplug the one wire sensor on the passanger side of the block... and replace the new sender there?
  #7
Old 02-21-2011, 08:39 AM
1real95SS's Avatar
Default
DID I MENTION I HAVE THE ELECTRIC GAUGE AUTO METER ... it came with two fittings such as these
  #8
Old 02-21-2011, 09:53 AM
1real95SS's Avatar
Default
anybody??
  #9
Old 02-21-2011, 11:38 AM
94MI9C1's Avatar
Default
Yes
remove old put in new, I still think that you can use the old sender, but I am not entirely sure on that one.
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
  #10
Old 02-21-2011, 01:21 PM
1real95SS's Avatar
Default
Originally Posted by 94MI9C1 View Post
Yes
i figured it out. was fairly easy. thanks!
Forum Jump
(c) 2007-2011 Impala SS Forum
