Loose steering - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Suspension
Thread Tools Display Modes
  #1
Old 02-24-2011, 07:03 PM
ergoman ergoman is offline
ergoman is on a distinguished road
Default Loose steering
I'm trying to figure this out currently. I just purchased a 94 SS and at slow speed it feels like it wanders (below 40mph) at 60 not nearly so much. I turned the key and the steering wheel has about 4-5" of travel. The telescoping shaft clicks at the top and the top joint can be wiggled up/down by hand (not linear with the shaft but perpendicular to it). When the steering wheel is turned hard L/R the pitman will barely move and it appears that it moves about 1/8" side to side and pulls down on the joint about 1/16th or so, (only when the steering will is turned hard to the L/R). Do you think its the upper bushing? shaft? box? pitman joint? Any suggestions on how to diagnose? I've searched for similar posts and thats what lead me to do the things above. Not sure what to do to isolate the issue. The car has 135k miles, very clean outside. One owner. Just had it at the dealer specifically asked them to check the front end components, all they found were bad shocks and loose wheel bearings. They stated none of the components were loose. Shocks were replaced with the recommended severe duty Monroe's I read about on here. Sorry for the long first post, thank you for your thoughts.
Ron
Old 02-24-2011, 08:04 PM
Crime Scene 96's Avatar
Crime Scene 96 Crime Scene 96 is offline
Crime Scene 96 is on a distinguished road
Default
Welcome to the forum guy...
I've been having similar issues as well with steering rattle. I had a alignment done yesterday, new front end, and tie rods recently. With the alignment alone (to me) kinda stiffed things up a little bit. The steering and rattling is at a descent minimal. So I would recommend this if you haven't all ready. I see you are from Michigan. And my car (96 SS) has spent most of its years there also until I purchased it from the last owner here in GA.
So all that to say, the salt life might have a factor into some things as well. Do you have any rusting parts? I would check your upper and lower control arms. And replace any bushings which might be the overall problem.
__________________
1996 Chevy Impala SS BBB -
R.I.P. 4/15/2012
1996 Chevy Impala SS DGGM -
Replaced BBB on 4/30/2012
  #3
Old 02-24-2011, 08:19 PM
mega's Avatar
mega mega is offline
mega is on a distinguished road
Default
when i got my caprice it had about 4-5 in as well i replaced the idler arm, helped a little so i did all four tie rods including the adjusting sleeves and it did almost correct it but after i replaced all four shocks is when i noticed the biggest difference. it is nice and smooth no wander drives staight as an arrow. all i got to do left is ball joins only uppers are alittle worn but if i got it apart why not do lowers as well. i would jack the front up so tires are free grab em and wiggle if you have any play u got a problem. top and bottom play is balljoints and left and right is tierods but not limited to idler arm. all of em are very easy to replace and if ya need pics or info just ask me.also goood point on the bushings on the a arms.
__________________
94 Caprice 4.3l flat black, red wheels, trim rings
air pump delete, a/c delete, washer tank moved to trunk, resonator delete, swiss cheese airbox, home made cai, And more, more to come.
  #4
Old 02-24-2011, 08:54 PM
cletus284 cletus284 is offline
cletus284 is an unknown quantity at this point
Default
There should be NO slop from the intermediate shaft to the wheels. Sounds like your intermediate shaft and center link are bad (Pitman arm is not a wear item on these cars). You should jack the car up and check the idler arm and tie rods for play as well. After replacing these parts, an alignment is absolutely necessary.
__________________
2005 Pontiac GTO
  #5
Old 02-24-2011, 08:59 PM
mega's Avatar
Default
i completely agree after reading more of the post carefully lol nobody everdoes that huh. but as it sounds i wouldn't drive it
__________________
  #6
Old 02-24-2011, 09:27 PM
allwestss allwestss is offline
allwestss is on a distinguished road
Default
i was dealing with the same issue about a month ago and almost replaced the pitman and other parts but thanks to the guys on this site i found it was just the center link,, fixxed it right up
__________________
96 Impala BBB
  #7
Old 02-24-2011, 09:28 PM
harriSScutty's Avatar
harriSScutty harriSScutty is offline
harriSScutty is on a distinguished road
Default
I had the same problem when I purchased my car and I replaced everything in that post. For extra stiffness I also added the jeep shaft mod.
__________________
BlueGraSS KENTUCKY
95 BBB 11,264 of 18,365
96DGGM PARTS CAR 80K
94BBB PARTING OUT NOW 183K
95BBB PARTS-USED FOR 231K STILL RUNNING STRONG!!!!!!!!
  #8
Old 02-24-2011, 10:18 PM
KW Baraka's Avatar
KW Baraka KW Baraka is offline
Location: South Central Texas....By Way of the South Side of Chicago!!!!!
KW Baraka has a little shameless behaviour in the past
Default
Originally Posted by harriSScutty View Post
.........For extra stiffness I also added the jeep shaft mod.
Huh ?
KW
__________________
1996 BBB SS, 398ci Solid Roller LT4
1995 DCM SS, Heads/Cam LS3
2014 Chevy SS; 429ci LS3 -- 508HP, 455TQ @ the wheels....track results pending
  #9
Old 02-24-2011, 10:25 PM
Default
Originally Posted by KW Baraka View Post
Huh ?
KW
To improve the durabilty
Is that better?
__________________
BlueGraSS KENTUCKY
  #10
Old 02-24-2011, 11:14 PM
305classic's Avatar
305classic 305classic is offline
305classic
Default
Is that better?
yes, I don't have one on my car but the jeep steering shaft is just an all around better design than GM's crappy design.
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
