5.3 truck with Impala/Caprice 4L60E - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Impala SS Forum
Go Back   Chevrolet Impala SS Forum : Chevy Impala SS Forums > 91-96 Impala/B-body > Engine Performance
Thread Tools Display Modes
  #1
Old 03-01-2011, 07:06 AM
alfurious's Avatar
alfurious alfurious is offline
alfurious is on a distinguished road
Send a message via ICQ to alfurious
Default 5.3 truck with Impala/Caprice 4L60E
Does any one know if 2001 Tahoe 5.3 engine will work correct with 95 Caprice 4L60E?
I mean what kind of differeces has Caprice 4l60E and 4L60E with separate bellhousing?
I bought my LM7 engine more than a year ago and still unable to find 4L60E with separate bellhousing
__________________
1992 Chevrolet Caprice L03 TBI-POS
Old 03-01-2011, 08:52 AM
GA95DCMSS's Avatar
GA95DCMSS GA95DCMSS is offline
GA95DCMSS
Send a message via Yahoo to GA95DCMSS
Default
Yes, it will. Read my sticky at the top of this sectiono titled "LS Swap Basics"
__________________
Quentin-1995 Impala SS-6.0L LQ4-222/226-L92 Heads.PB: 1.75 60ft 12.70 @ 107.75 so far
  #3
Old 03-01-2011, 09:14 AM
ls1caprice's Avatar
ls1caprice ls1caprice is offline
ls1caprice is on a distinguished road
Default
First you will need to be sure the 4l603 has the later style plug on it, and then theres an adapter that can be purchased from GM or Hughes Performance.
__________________
Staying true to the all mighty BOWTIE. 94'BBB Imp-SS-5.3 bored to 5.7 custom cam, Powerdyne SC, 4L65E, 3.73's; 78' Malibu-396ci LT1/TH400/3.90's and 250hp shot; 80' Caprice Landau Coupe 346ci LS1/4L60E/3.73's; 89' Silverado GM crate 350/330hp Vortec/700R4/4.11's; 96 Express 1500 turtle-top Conv-van stock 5700Vortec/4L60E.
  #4
Old 03-02-2011, 09:08 AM
Beertestr's Avatar
Beertestr Beertestr is online now
Beertestr
Default
Huh?
I have an 01 motor in my 94 Silvy with a 94 trans. Plugged right in.
Motor fits well, intake requries body mods to fit. Run a car intake.
__________________
Michael -1979 Caprice 6.0 - 11.99@112.8
NSHS2 - March 30th 2013, Cecil County Dragway
  #5
Old 03-02-2011, 09:57 PM
alfurious's Avatar
Default
Originally Posted by Beertestr View Post
Huh?
Have you reflashed the ECM? or you just use Silvy's ECM as is?
__________________
  #6
Old 03-03-2011, 07:13 AM
Beertestr's Avatar
Beertestr
Default
Not sure I understand your Q. The connector is the same. If you run a non-PWM trans (pre 95), you need to change the trans cal and shut off ECCC (Electronic Converter Clutch Control) so that the TCC will lock up. The connector physically plugs in, but the 2001 harness will have 2 more wires in the 16 pin connector, there's just nothing to connect to on the internal trans harness.
I used the 2001 Silvy engine harness. When I had the motor in my 93 2WD Sierra, I used an LS trans and could use the ECCC. When I put the motor into my 94 Z71, I kept the stock trans and shut the ECCC function off in the cal. Most tuners can do that for you pretty easy.
__________________
  #7
Old 03-03-2011, 11:43 AM
alfurious's Avatar
Default
Is there any way I could find out if my tranny is PWM or not?
Thanks for the answers guys!!!
__________________
  #8
Old 03-03-2011, 02:32 PM
LT Scholz LT Scholz is offline
Banned
LT Scholz is on a distinguished road
Default
Pull the transmission oil pump off. there should be the letters PWM in raised print on the pump. If it is Pulse Width Modulated, the PWM sign will be on the pump.
  #9
Old 03-03-2011, 04:35 PM
Beertestr's Avatar
Beertestr
Default
Don't need to pull the pump, just need to pull the torque converter. the PWM marking is visible on the front face of the pump.
__________________
  #10
Old 03-03-2011, 10:33 PM
alfurious's Avatar
Default
Do you know if it is possible to convert nonPWM to PWM tranny?
how does it work?
__________________
Forum Jump
(c) 2007-2011 Impala SS Forum
