Whats the best way to drain fuel tank? - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91 thru 96 B-body Model Specific > Wagons
Thread Tools Display Modes
  #1
Old 03-07-2011, 05:51 PM
Deadman's Avatar
Deadman Deadman is offline
Deadman
Default Whats the best way to drain fuel tank?
I bought a 95 Caprice wagon thats been sitting for about 5-8 years, and the fuel tank is mostly full. Whats the easiest way to drain the Gas out without dropping the tank?
I'm tempted to go buy some small hose and use shop vac to get Siphon going, but is there a better/easier way? Years ago, I've bought some of those cheap siphon kits from hardware stores, and most of them are junk and never worked from day one.
Is there a way to drain it by using the fuel pump? I already pulled the fuel filter and ran the fuel pump as I cycled the Ignition, but that was a slow boat to China. Is there a way to run the pump steady maybe?
__________________
95 Caprice Wagon
Old 03-07-2011, 06:03 PM
sherlock9c1 sherlock9c1 is offline
Sophomore Member
sherlock9c1 can only hope to improve
Send a message via AIM to sherlock9c1
Default
I just have to say that this is a sure-fire way to cause an explosion. You would be pumping gasoline vapors through a sparking electric motor and then blowing them all around your garage. You really would be a deadman.
Look next to your AC accumulator - there's a little connector. Disconnect the fuel line like you said, aim it into a gas can, then put 12V on that connnector. Done.
__________________
"As I have gotten older, I have become much more patient with some things, and much less patient with other things." - sherlock9c1
  #3
Old 03-07-2011, 06:46 PM
sprocket's Avatar
sprocket sprocket is offline
sprocket is an unknown quantity at this point
Default
Disconnect at the fuel filter and get a GOOD connection (no sparks) to run your voltage to the pump and let the pump do the work.
The LT1 tanks have baffles, you'll only get about half out with a siphon anyway. Trust me I know from experience and a few mouth fulls of 87 octane
__________________
  #4
Old 03-07-2011, 06:54 PM
Deadman's Avatar
Deadman
Default
Dang it, that sure would have made for a good story tho!
Thanks, I'll try that tomorrow!
__________________
95 Caprice Wagon
  #5
Old 03-08-2011, 07:59 AM
lakeffect's Avatar
lakeffect lakeffect is offline
lakeffect
Default
Someone else would have been writing it though. You'd be filed under "Crispy Critters" over at the local Burn Treatment Center.
Do yourself a favor, Assuming you are dropping the tank as part of this project,go get a drain plug from NAPA, Advance Auto etc. They run about five bucks. Put in in. IF you ever drop the tank a second time, you'll be really happy you spend the five bucks. Mine's been out four or five times now. Easiest way to drain the tank when the System is inoperative.
__________________
1993 Caprice wagon "SHAMMOO" Kicker demo car. 406ci, TPI'd SBC, 58mm TB, SLP siamesed runners, Comp Cam 230/236, AFR 195 heads, headers. Accel 300+system, remote fan cooled ignition module. Highly modded "4L65" Trans-Go kit, beast sunshell, 5 gear planetaries, B&M megashifter. Shaved roof and tailgate, debadged, billet grill, Front spoiler and rear pan. Custom four bucket interior, Nordskog digital dash. (Reworking current center console) 2" dropped spindles, Bell shocks, BFG's Weld Tomahawks
  #6
Old 03-08-2011, 06:16 PM
Man From Knobstock's Avatar
Man From Knobstock Man From Knobstock is offline
Man From Knobstock is on a distinguished road
Default Best Way to Empty a Gas Tank? Are You Kidding...?
OK, I'll say it, because this is as much of a set up line as I've seen on these boards: The easiest way to drain the gas is to stomp your foot to the floor!
__________________
Knobby,
Port Orchard, Washington
1995 Buick Longroof GS Clone Project Car
http://longroofgransport.wordpress.com/
B-Body and Wagon Cruise on the Western Shore of Puget Sound this coming May! Stay tuned.
  #7
Old 03-08-2011, 06:31 PM
Deadman's Avatar
Deadman
Default
Fuel pump worked great, thanks for info! Stinks bad, it could be 8 yrs old!
__________________
95 Caprice Wagon
  #8
Old 03-21-2012, 11:31 PM
Phantom59's Avatar
Phantom59 Phantom59 is offline
Phantom59 is on a distinguished road
Default
I just went through this had a full tank of gas and a dead fuel pump. You can get about 5 gallons from the fill tube before the baffle stops you. After that if you jack the car up and disconnect the vent line beside the fill neck you can snake a line through there to the center of the tank. I was able to remove about 18 gallons this way and the tank came down very easy.
  #9
Old 03-22-2012, 06:04 PM
VacFink VacFink is offline
VacFink is on a distinguished road
Default
HA. I was going to go with 'Insert Key, first but great minds think a like!
__________________
"You guys wanna make jokes, or watch me haul ass?" - rut
  #10
Old 03-22-2012, 07:19 PM
nomrlz's Avatar
nomrlz nomrlz is offline
nomrlz is an unknown quantity at this point
Default
just drill a hole in the bottom. hands down the easiest
__________________
1995 bolt-on RMW (thanks fred)
14.174/94.07 motor stock TB
13.946/96.44 motor 52mm TB
12.365/107.74 150 shot
9.377/152.69 '00 Hayabusa with 270lb rider
8.72/162 99 Hayabusa same fat rider
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
