trans pan bolt torque - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Drivetrain
Thread Tools Display Modes
  #1
Old 04-08-2011, 01:09 AM
BareProductions's Avatar
BareProductions BareProductions is offline
BareProductions
Send a message via AIM to BareProductions
Default trans pan bolt torque
Dumb question: left my shop manual elsewhere...I forget the torque for the trans pan bolts...anyone know it?
Thanks!
__________________
95 Caprice Wagon: All the basic mods, Tri-Y headers, SpinTech Exhaust, 52MM TB, Bryan H Tune, Rustic control arms, AirLift Bags.
95 9C1: LE218/224 .571/.566, "561" alum heads, 1.6 RR, beehives, 54MM TB, ported intake, 2.5 catback, Hooker Aero Chambers
73 Nova: Yellow hole where I throw the rest of my $$$
83 Wife: Stock
Old 04-08-2011, 08:58 AM
Navy Lifer's Avatar
Navy Lifer Navy Lifer is offline
Navy Lifer is an unknown quantity at this point
Default
12 lb-ft
There is a note (Fig 10 on pg 7A-15 of my 96 FSM) that shows 2 conditions for the pan bolts, which have a conical (cupped) washer under the head. If the conical washer is collapsed and pushed up flush to the underside of the bolt head, it should be replaced.
If you find all of the bolts are out of spec, the pan uses 16 of them. Also (if using a used stock pan) check the pan rails to make sure they are straight. If the pan bolts were over-tightened and collapsed the conical washers, the pan could have been deformed as well, which would affect the overall gasket clamping pressure when the bolts are installed to proper torque spec.
The bolt PN is 24226008, which has been changed to 24231519, sold as a 5-pack.
__________________
Bill Harper
ISSCA #127
inov8r@windstream.net
  #3
Old 04-08-2011, 09:07 AM
sherlock9c1 sherlock9c1 is offline
Sophomore Member
sherlock9c1 can only hope to improve
Send a message via AIM to sherlock9c1
Default
I torque mine to 9 ft lbs.
__________________
"As I have gotten older, I have become much more patient with some things, and much less patient with other things." - sherlock9c1
  #4
Old 04-08-2011, 09:32 AM
juniorwatson's Avatar
juniorwatson juniorwatson is offline
juniorwatson is on a distinguished road
Send a message via ICQ to juniorwatson
Default
Typically what I use for valve covers, oil pans, transmission pans...etc is to use a 1/4" drive ratchet, socket & extension.
It only requires a small amount of torque and using the smaller drive really help prevent over torquing.
__________________
'96 - W/'96 9C1 Rear. Blah, Blah, Blah....
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
