Draining gas tank? - Chevy Impala SS Forum
Impala SS Forum
Thread Tools Display Modes
  #1
Old 04-14-2011, 10:40 PM
fast lt1 fast lt1 is offline
fast lt1
Send a message via AIM to fast lt1
Default Draining gas tank?
My 96 SS is going to be sitting for a while and i want to drain the fuel tank, i bought a transfer pump, but can't seem to get the tube into the tank. What is the easiest way to do this without making a huge mess?
Old 04-15-2011, 06:55 AM
Goldmaster's Avatar
Goldmaster Goldmaster is offline
Moderator
Goldmaster is on a distinguished road
Default
Well on my parts cars, I usually just disconnect the fuel filter, clamp a piece of rubber hose to the end and point it into a fuel container. Then I jump the fuel pump test lead (lone red wire not connected to anything) up by the underhood fuse/relay box. This will cause the pump to stay running with the car off and it'll pump all the gas out for you. Don't let it run completely dry though, as it's not good for the pump. But I usually don't worried about running it completely out, since the cars usually get scrapped.
  #3
Old 04-15-2011, 10:18 AM
fast lt1
Default
Thanks, this is perfect!
  #4
Old 04-15-2011, 11:21 AM
juniorwatson's Avatar
juniorwatson juniorwatson is offline
juniorwatson is on a distinguished road
Send a message via ICQ to juniorwatson
Default
When I had to replace my fuel pump and siphon out the 18 or so gallons, I found it easiest to remove the filler neck from the tank itself. That made it REAL EASY to get the hose into the tank and start the process.
I wasn't able to get the tubing I used to siphon going down thru the fill spout into the tank to work, so like I wrote removing the neck where it attaches to the tank was the best process.
__________________
'96 - W/'96 9C1 Rear. Blah, Blah, Blah....
  #5
Old 04-15-2011, 11:51 AM
fast lt1
Default
I considered that last night, but my car is on a downward slope, and has about 11 gallons in it. I think if i did that it would flow out onto me! I'll probably go with the fuel pump method.
  #6
Old 04-15-2011, 12:14 PM
Sshockr Sshockr is offline
Sshockr is an unknown quantity at this point
Default
A very large funnel and taking your dear sweet time and you can get everything out where the tank meets the fill pipe without making a mess.
-Brian
__________________
'95 B4U LT1/T56 in Purple Pearl. 24x 355 with I believe most of the bolt-ons.
'63 C10 LT1/4L60E from B-Body. Rides like a Cadillac thanks to air bags.
'06 GTO LS2/T56 Torrid Red with CAI and Borla Cat-back thanks to the lady who rear ended me.
Still in Wichita.
  #7
Old 04-15-2011, 12:42 PM
grandpas wagon grandpas wagon is offline
grandpas wagon is an unknown quantity at this point
Default
How long is a while? If it is a year or less and your system is clean, don't worry. I have gone longer than a year (on FI cars) with no problems. I have a neighbor who was abroard for 3 years. He did nothing to his garaged car all that time (I advised otherwise). When he got back, he charged his battery, and drove away like he was never gone - he always likes to boast about that.
I am not suggesting you will be so lucky. But again - what is a while?
__________________
grandpas wagon
1994 RMW 69K, clear corners, Gary's cables - battery, headlight, mech fan delete, air pump delete, home plate/first base delete, Bill Harper wiper arm mod, Corvette starter, 1LE elbow, Team SS pipe, K&N filter swiss cheese airbox, throttle body bypass, AutoMod Atlanta headlights.
All my posts contain 100% recycled electrons.
  #8
Old 04-15-2011, 12:49 PM
fast lt1
Default
Not exactly sure how long, at least a month, anywhere up to a year maybe, i'm not sure at this point so i figure it best to just drain it.
  #9
Old 04-15-2011, 02:49 PM
9c1 lover's Avatar
9c1 lover 9c1 lover is offline
9c1 lover is an unknown quantity at this point
Default
leave it
__________________
DO NOT USE ASPWHOLESALE FOR ALTERNATOR UPGRADES, THEY ARE THIEVES!!!!!
SOON TO BE
  #10
Old 04-15-2011, 04:32 PM
Default
It's your money - like a $100 - that's now. In a year...........???
__________________
grandpas wagon
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
