Cooling System Diagram - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Heating/Cooling/HVAC
Thread Tools Display Modes
  #1
Old 04-30-2011, 12:10 AM
HUF's Avatar
HUF HUF is offline
HUF is on a distinguished road
Default Cooling System Diagram
Does anybody have the diagram of the cooling system? Could not find it in the FSM. Thanks.
__________________
1995 Cadillac Fleetwood Brougham 105,XXX miles.
Old 04-30-2011, 12:18 AM
SimplyTheBeSS's Avatar
SimplyTheBeSS SimplyTheBeSS is offline
SimplyTheBeSS is on a distinguished road
Default
http://www.compnine.com/index.php?s=...256&makecode=C
__________________
1994 SS
- GRAIL Webmaster, St. Louis, MO
View our Tech/Guide page for everything from your basic oil change to Manual transmission swaps!
  #3
Old 04-30-2011, 12:22 AM
HUF's Avatar
HUF HUF is offline
Default
Thank you, Symply!
__________________
  #4
Old 04-30-2011, 02:41 PM
HUF's Avatar
HUF HUF is offline
Default
Originally Posted by Marky Dissod View Post
If it makes any difference
As designed,
Coolant flows from top to bottom through the Gen2 engine and radiator.
Coolant flows from bottom to top through the heatercore.
Thank you. Mine is 1995 Fleetwood. It does not have a hose from the reservoir to the top of radiator outlet tank.
I have noticed traces of dirty liquid on the side of the coolant reservoir. The location looks like a projection of serpentine belt. I am a little bit concerned that the water pump started leaking and the belt sprayed some coolant at the reservoir. The pump was replaced by a dealer 20,000 miles/5 years ago... ACDelco part. Do they fail THAT often?
__________________
  #5
Old 04-30-2011, 04:49 PM
grandpas wagon grandpas wagon is offline
grandpas wagon is an unknown quantity at this point
Default
That oil spray is likely being thrown up from the AC compressor.
__________________
grandpas wagon
1994 RMW 69K, clear corners, Gary's cables - battery, headlight, mech fan delete, air pump delete, home plate/first base delete, Bill Harper wiper arm mod, Corvette starter, 1LE elbow, Team SS pipe, K&N filter swiss cheese airbox, throttle body bypass, AutoMod Atlanta headlights.
All my posts contain 100% recycled electrons.
  #6
Old 04-30-2011, 04:53 PM
HUF's Avatar
HUF HUF is offline
Default
Thank you. Did not really think of the compressor. If it is indeed the compressor, is it on its way?
__________________
  #7
Old 05-01-2011, 08:58 PM
ghetto wagon's Avatar
ghetto wagon ghetto wagon is offline
ghetto wagon is an unknown quantity at this point
Default
You can reseal it. The front shaft seal is easy to do if the compressor is not rusted. Check if around the AC compressor clutch is wet.. Its sealed in the front so oil will spray out the sides (you will see a small air gap) My car has been wet in a similar area forever.. I replaced hoses, a PS pump (shaft seal was leaking) PS feed hose( was leaking) Now. I have alot less of a leak but something still makes slime. I'm about to just get rid of this car. (especially if I find that the compressor is leaking) My leak is usally only tossed up to the lower heater core hose off the water pump, idler arm and transmission lines.... But mine reeks like coolant.
With an compressor leak usually they will ONLY leak when the compressor clutch is activated (AC on or Defroster) and the compressor is spinning
  #8
Old 05-01-2011, 09:03 PM
HUF's Avatar
HUF HUF is offline
Default
Thanks. I checked everything up today and could not find anything wet or dripping even with engine revved up... Hopefully, it was rain somehow getting into the engine bay and wetting the serpentine belt. I will keep an eye on it.
__________________
  #9
Old 05-01-2011, 09:08 PM
Default
You could have a small leak too that only leaks when the engine bay is REAL HOT and under pressure like I think mine is.. The heads can always leak too. I would clean it up, run it around w/o using the AC and see if the leak disappears If it does, Then run the AC and see if it comes back to rule that out.
  #10
Old 05-01-2011, 09:10 PM
HUF's Avatar
HUF HUF is offline
Default
That's a possibility as well. What really bothers me is that I felt that faint sweet smell in the cabin you cannot confuse with anything else - coolant smell... Could be heater core slowly failing. W&W - wait and watch, I guess.
__________________
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
