95 Caprice LT1 dist, cap, rotor, water pump and belt replacement - Chevy Impala SS Forum
Impala SS Forum
Thread Tools Display Modes
  #1
Old 04-30-2011, 01:32 AM
SrtBrad SrtBrad is offline
SrtBrad is on a distinguished road
Default 95 Caprice LT1 dist, cap, rotor, water pump and belt replacement
This is my first Opti Spark distributer, cap, rotor, and waterpump replacement job. What a day!! Thought I's be able to finish in a few hours but ended up looking for the damn E4 and T8 sockets for half the day. Have all the parts and tools now that I need for the job.
I hope I don't have any other surprises!!!!!!!
__________________
www.vipersoftheworld.com
Old 05-01-2011, 12:29 AM
Default
Finished the Install of the new dist, old cap, old rotor, new waterpump, thermostat, belt, and vacuum hose to distributor. Started right up and died after a few seconds.
My fuel pressure is really low. I get to do a fuel pump, screen, and fuel filter tomorrow. Any advise on this job would be helpful.
Here are the before and after pics of the distributor job:
__________________
  #3
Old 05-01-2011, 01:28 AM
SimplyTheBeSS's Avatar
SimplyTheBeSS SimplyTheBeSS is offline
SimplyTheBeSS is on a distinguished road
Default
was the car not starting before? only thing I can tell you about the fuel filter is to make sure you get rid of the pressure in the line by pulling the fuse for the pump.
__________________
1994 SS
- GRAIL Webmaster, St. Louis, MO
View our Tech/Guide page for everything from your basic oil change to Manual transmission swaps!
  #4
Old 05-01-2011, 01:32 AM
Crime Scene 96's Avatar
Crime Scene 96 Crime Scene 96 is offline
Crime Scene 96 is on a distinguished road
Default
If you are refering to the fuel pump. Nothing to it really. Just make sure you have the fuel disconnect tool. and everything should be fine... It helps to have a nice size jack close by in case your tank has an good amount of gas left. That darn thing is heavy empty, so its really heavy when its full.
__________________
1996 Chevy Impala SS BBB -
R.I.P. 4/15/2012
1996 Chevy Impala SS DGGM -
Replaced BBB on 4/30/2012
  #5
Old 05-01-2011, 01:33 AM
Default
Make sure you get the metal disconnect tool. The plastic ones are junk.
__________________
R.I.P. 4/15/2012
  #6
Old 05-01-2011, 02:55 AM
Default
The car was stalling out and then it just died before this job was done. I had a leaking waterpump, a cracked distributer cap, very low fuel pressure, vacuum leaks, clogged radiator, stripped thermostat bolts and no thermostat. The car also had what seemed to be an extra few hundred pounds of grease and dirt under the hood. This car is undergoing some well deserved care after years of abuse by former owners.
I have the metal fuel line disconnect tool. I need more metal brushes since I went thru 4 of them today with the distributor job. I have a siphon kit to get the full tank of gas drained.
Any SoCal members want to drop by to help?
__________________
  #7
Old 05-01-2011, 12:25 PM
Goldmaster's Avatar
Goldmaster Goldmaster is offline
Moderator
Goldmaster is on a distinguished road
Default
What brand opti did you use? If it was a cheap $100 one off ebay, get ready to do the job over again...
  #8
Old 05-01-2011, 01:56 PM
Default
I just got the OEM brand from Pep Boys since I didn't have an extra $300 more for the other one. I hope this opti will last for at least a year.
__________________
  #9
Old 05-02-2011, 06:36 AM
Goldmaster's Avatar
Moderator
Default
Not sure what brand pepboys carries, but if it was the A1 Cardone remanned one, those are junk too. I went through several of those within a year and a half before giving up and buying a Delco. That taught me you can buy a cheap one with a lifetime warranty and replace it 5 times, or buy a Delco and replace it once.
If it runs great most of the time, but starts doing the random shut down, starts when it feels like it thing, it's time for another opti...
  #10
Old 05-10-2011, 08:43 PM
Default
Update...............
The car is running great other than a slow transmission leak from the front by the converter. No water or engine oil leaks at all now!!!!
The fuel pump from Pep Boys (Carter) was a bit shorter than the original presenting a couple of problems. Exact same pump only an inch and a half shorter. The cap of the fuel pump assembly could not be used due to the height issues. Anybody else have this same problem? I just used a fuel line hose to make the height difference and tossed the cap.
__________________
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
