code P1371 along with 4 more... - Chevy Impala SS Forum
Impala SS Forum
Thread Tools Display Modes
  #1
Old 05-09-2011, 04:24 PM
Forbes's Avatar
Forbes Forbes is offline
Forbes is on a distinguished road
Default code P1371 along with 4 more...
i have this code on my car along with like 4 others.... help me i have to do emissions!!! do i need a new optispark!???!?
P1441:
P0137:
P0153:
P0161:
P1371:
http://www.firebirdnation.com/forums...rebird-formula
P1371 is telling you the PCM can not find the low resolution pulse signal. When this happens, the PCM can not time the ignition or the fuel injection, so it shuts down the fuel system.If the engine is running, P1371 is a "stored" code. It is not active, so the PCM is still running the fuel system. If this is the case, clear the code (pull the "PCM BAT" fuse for 30 seconds), and see how often it comes back. If it comes back frequently, or sets when the engine stalls, its an indication that the cam position sensor in the distributor is failing, or there is a problem with the wire harness or connector. If your engine isn't starting at all, it's an "active" code, and could be a failed sensor or damaged harness/connector.
__________________
'96 SS 126K
Old 05-09-2011, 09:42 PM
cletus284 cletus284 is offline
cletus284 is an unknown quantity at this point
Default
P1371 is almost always an Opti issue.
__________________
2005 Pontiac GTO
  #3
Old 05-09-2011, 11:22 PM
Gregg-O's Avatar
Gregg-O Gregg-O is offline
Gregg-O is an unknown quantity at this point
Default
Myself, I would get a new Opti harness first...way cheaper & easier, but that's just me. If it will run, reach down and wiggle the harness and see what happen's.
__________________
Taxes are not levied for the benefit of the taxed.
\'96 IMP SS BBB ,Stock, airbox is swiss cheese, K&N filter, Ultra Flows.
  #4
Old 05-10-2011, 06:09 AM
Forbes's Avatar
Default
yeah the car runs fine but i feel a big power loss and bad throttle response.
__________________
'96 SS 126K
  #5
Old 05-24-2011, 07:42 PM
Forbes's Avatar
Default
i removed the negative battery terminal to clear the codes, then wiggled the opti harness and tried to start the car and now it won't start...
__________________
'96 SS 126K
  #6
Old 05-24-2011, 10:22 PM
Rocko350's Avatar
Rocko350 Rocko350 is offline
Rocko350 is on a distinguished road
Default
Then that confirms the bad connection with the opti harness. I would renew the opti harness and the vacuum harness to start (no pun intended).
Chris
__________________
94-95 Scan. Free, well written diagnostic software
http://www.mediafire.com/?0elo4c935uc5s
  #7
Old 05-24-2011, 10:32 PM
Forbes's Avatar
Default
Chris
this good enough for a replacement?
http://www.eficonnection.com/eficonn...spx?ItemId=841
__________________
'96 SS 126K
  #8
Old 05-24-2011, 10:38 PM
94MI9C1's Avatar
94MI9C1 94MI9C1 is offline
94MI9C1 is on a distinguished road
Default
Yes it is, sounds like I knew what I was talking about huh LOL. Just kidding man. Offer is still open to borrow the opti that I have to test it out with. Also read over all of the p code descriptions and diagnostic help that I sent you. It will help you more than you know
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
1994 Chevy Caprice 9C1, 126,000 miles, T56, 4.10's
C6 Grandsport Brake Install C6 Z06 Wheels T56 Installation Manual
  #9
Old 05-24-2011, 10:52 PM
Forbes's Avatar
Default
my buddy thinks it's fuel related, either my fuel pump **** on me or it's my fuel pressure? i had a fuel problem before like this but it was a problem with my pump not priming and it's still priming fine.
__________________
'96 SS 126K
  #10
Old 05-25-2011, 04:17 PM
Forbes's Avatar
Default
tried to start her up this morning, first attempt it died right after start. second time it started right up perfectly fine, let it run for about 5-10 minutes shut it off and started it back up fine. also my vent hose for my opti that sticks in my intake has no suction at all.
i'm getting suction from the line with the filter on it going to my intake manifold on the side perfect.
but not the one with the blue elbow, no suction at all.
__________________
'96 SS 126K
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
