1994 Caprice PCM changes for 3.08 to 4.11 gear swap - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > PCM Programming/Engine Management
Thread Tools Display Modes
  #1
Old 05-24-2011, 01:34 PM
jeffd jeffd is offline
jeffd
Default 1994 Caprice PCM changes for 3.08 to 4.11 gear swap
What needs to change in the tune when changing from 3.08 to 4.11 gears for a 1994 9C1 LT1 caprice? I changed the gear ratio for the speedometer to work correctly. The trans is taking a long time to shift from 1st to 2nd. The rpm's are higher than I want. I want to drive a couple of hundred miles with the new rear gears before the T56 swap.
__________________
1996 DCM Impala SS
1994 DCM 9C1 Caprice
1981 LQ9 4L80E Trans Am
Old 05-27-2011, 12:41 PM
Rocko350's Avatar
Rocko350 Rocko350 is offline
Rocko350 is on a distinguished road
Default
What software are you using?
Chris
__________________
94-95 Scan. Free, well written diagnostic software
http://www.mediafire.com/?0elo4c935uc5s
  #3
Old 05-31-2011, 01:19 PM
jeffd
Default
Tunercats OBD-I.
__________________
1996 DCM Impala SS
  #4
Old 05-31-2011, 09:54 PM
Rocko350's Avatar
Default
there is a tool built in to the software that makes corrections to all the tables at once. its in the drop down menu at the top of the software screen. fill out the data and select apply, then ok when the little screen says"hey buddy your gonna change a sh*tload of tables" then save and upload. Its possible the rpm and mph wot(kickdown) settings might let you hit the rpm limiter before you upshift at WOT, so change at your own risk.
Chris
__________________
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
