Running 10 inch wide wheels up front back spacing? - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Wheels & Tires
Thread Tools Display Modes
  #1
Old 06-16-2011, 08:58 AM
Stoney's Avatar
Stoney Stoney is offline
Stoney is on a distinguished road
Default Running 10 inch wide wheels up front back spacing?
What back spacing do you run while 10 wide wheels that would tuck and not rub? Any help would be great. Yes I've searched the forum but still want some fresh input. Running 2.5 inch drop up front. Thanks
Old 06-16-2011, 10:42 AM
94MI9C1's Avatar
94MI9C1 94MI9C1 is offline
94MI9C1 is on a distinguished road
Default
I think that the magic number that you will find is if you hover the offset around the +13 to +15 mark more towards the +15 mark. The height of the wheel and tire is going to be relative to this as well. But I have seen on here that say 22 inch rim for instance with say 9.5 inch width running +13 with no issues, going to a 10 inch rim you are only gaining .25 of an inch on the inside and outside as compared to a 9.5 inch rim.
Example:
22X9.5 inch rim with +13 offset is going to be about 5.8 inches of backspacing
22X10 inch rim with +13 offset is going to be about 6.0 inches of backspacing<<<<<right as a .25 of an inch as noted above. Hope that makes sense.
If you look at an SS rim which is 17X8.5 with about 5.05 inches of backspacing, we will just say 5 inches for a round number. Now bead to bead generally speaking on an 8.5 inch rim it is going to be 9.5 inches wide (an SS rim is beefier and is a tad wider).
So if you go with a 22X9.5 rim the relative actual width is going to be 10.5 inches, so in theory if you wanted the front face of the rim to match where an SS rim sat on the car then you would need to add 1 inch to the backspacing number which comes out to 6 inches. (I am sure that Firewood has explained all this before just reiterating).
I think that 6 inches is going to be the magic number as in the maximum that you would want to go for backspacing as going further in, you will start to run into rubbing on turns and stuff like that, which generally speaking our cars do anyway with most rims even in SS spec.
So if you had a 22X10 that is going to be 11 inches total width, so in theory to make the front face sit where an SS rim would you would need 6.5 inches of backspacing, but that would put you over the magic happy number that I think that most have found of 6 inches backspacing. Now I have seen guys run, +15 offset on a 10 inch rim with no issues and that comes out to 6.1 inches of backspacing.
Hope that wasn't over said or over worded, just trying to make it easy to understand. For you to tuck a 10 inch rim, I still think that you will end up rubbing the sway bar in a tight turn at the very least, that is just the nature of the beast, no way around it. I know the 18X9.5's that I run on the front of my car are VERY close to hitting the sway bar in a turn and that is with only 5 inches of backspacing on them right now.
Hope this helps.
***results may vary, measuring will be necessary and some minor weight loss maybe needed as well LOL
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
1994 Chevy Caprice 9C1, 126,000 miles, T56, 4.10's
C6 Grandsport Brake Install C6 Z06 Wheels T56 Installation Manual
  #3
Old 06-16-2011, 12:29 PM
Firewood's Avatar
Firewood Firewood is offline
Moderator
Firewood is an unknown quantity at this point
Default
What he said!
Good job 94MI9C1.
Remember... Your results may vary.
__________________
_______________________
My S10 gave its life to bring me back home to a B body!
91 Caprice with 108, 800 miles!
Almost every wheel and tire can be answered by clicking here!
  #4
Old 06-16-2011, 12:55 PM
94MI9C1's Avatar
Default
Originally Posted by Firewood View Post
What he said!
Good job 94MI9C1.
Thanks!!
And I updated my post with a disclaimer.
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
  #5
Old 06-16-2011, 01:37 PM
Stoney's Avatar
Default Thanks
Thanks again for your feedback....So my Enkei's are at Eric's in Monrovia and he is super backed up...He may have a problem widening my wheels to where I want them...Anyways I'm thinking about buying a set from Raceline and doing the 18x12 and 18x10 combo...I just really dislike rubbing..maybe go with 9's....Thanks
  #6
Old 06-16-2011, 02:48 PM
lotsacars lotsacars is offline
lotsacars
Default
I run very similar Enkei's in 17x10 (with 285/40's) on all four corners. They are all -13 so in essence the backspacing is the same as the stock SS rims and the 1.5" of extra width is all to the outside. I run stock SS springs (with ~150K now) and it will rub only on the front on the nastiest of dips (like a storm drain in a parking lot). I've only had them rub twice and both were dips that I wouldn't have hit on purpose. In normal driving they're fine. FWIW, I don't have wheel well moldings on my car, either. The rears would be awfully close.
Since you're lowered (though likely with stiffer springs) they would likely rub at that offset.
__________________
Luc
94 WX3 MM6
  #7
Old 06-16-2011, 04:07 PM
94MI9C1's Avatar
Default
I think that you would be happier with the 9's in the front IMHO.
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
  #8
Old 06-16-2011, 05:56 PM
Stoney's Avatar
Default !
Ya, I think you are right..Thanks so much.
  #9
Old 06-16-2011, 07:21 PM
Stoney's Avatar
Default Back spacing
I'll probably going with 18x9 and 5'' B.S. I liked how my Eagle 225's 20x8.5's looked in the front and I think it was 4.5 B.S. It shouldn't rub!
  #10
Old 06-16-2011, 11:07 PM
94MI9C1's Avatar
Default
No problem, glad to help. Click on the Z06 Wheel install link in my sig and in the last pages I show my car on the ground with some tester spacers/adapters on the front that are to large, the wheels are 18X9.5 and the backspacing with the wrong spacers is 4.8 right now and the edge of the tire and wheel is right and the outer fender lip. Just to give you an idea as I think with a 9 inch rim you will be about .5 inches in from the outer edge of the fender. but like you said should be right about where your 20's were.
__________________
Mike
ISSCA member # 2344
Hoosier INC Member
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
