#1
I finally managed to get my P0300 taken care of with my car, now I have another problem. It sounds like I've spun a rod bearing in my 96 stock LT1. I do have a 94 spare LT1 and I know that they're different but its all stuff I can change over. Just know that this car isn't a driver right now as I've been fixing problems and doing bodywork.
Now my question is... Should I pull the oil pan and replace the bearings and oil pump while in the car and be done with it? OR Should I do a complete tear down of the spare then do an engine swap?
__________________
Ash Click here to read about updating the "QaloSS' Impala SS Handbook" ![]() >>Undergoing ReSSurrection<< Current MODS: Herter Tune, shaved antenna, shaved handles and smoothies. CarPC Design 70% [■■■■■■■■■■■■■■■■■■■■] CarPC Fabrication 10% [■■■■■■■■■■■■■■■■■■■■] Member of CARISSMA ISSCA Member #2506 |
| Sponsored Links | ||
Advertisement | ||
#2
Tear down! Make it a stroker! STROKER! STROKER!
__________________
1995 Chevrolet Caprice 9C1 - Mostly stock, minor mods. Daily Driver. 1980 Buick Century Wagon - Parts Getter, Back-up car. 1984 Pontiac Firebird TRANS AM - Screamin' Chicken! LIBERTY OR DEATH, DON'T TREAD ON ME!
#3
This car will be a daily driver when I'm finished. Wouldn't making a stroker out of it shorten its life span?
__________________
#4
making it a stroker won't decrease it's lifespan "IF" you stay on the mild side of cams and don't beat the F out of it. That really would apply to any engine. It will cost more $ since you need larger pistons and a stroker crank & rods + machine work on block
My $02 would be to "refresh" your spare motor and transfer the OBD2 (96) specific stuff over to the older LT1. If you know the current motor has a knock AND it is a rod bearing you could do those with motor in the car but it is a huge PIA and you would not be able to polish the crank (assume it would need that at the very least). If it was a main crank braring than you would be hosed in swaping that with motor in car. You can buy a re-ring/bearing kit and gaskets for the LT1 for not much from places like Summit. Send your crank out for a polish and the block for rehone and new cam bearings. That would give you a very good motor for DD. If you want to add a small cam like a 227, 845 or LE211 that would be good to. Suggest you upgrade valve springs also.
__________________
\'96 BBB 383/T-56 |
#5
In fact, if you use a good cam, and watch how you drive, you may even notice fuel economy gains since the motor won't have to work as hard to move along. There is always a happy medium to be found, and the best thing to do is sit down and think about what you want out of your car, set a goal, then do the research and ask questions on the best way to achieve that goal. BALLSS also made a good point of refreshing the older LT1 with the newer OBDII components. Then you'll be free to do whatever you wish with the current LT1 whether it be building it up into a good solid stroker, or just rebuilding it to stock specifications.
__________________
#6
I'm trying to find answers with search and not having a lot of luck. For a daily driver with a mild 383 build will I need headers, larger injectors, throttle body, etc.? I plan on getting some headers but trying to decide if I get them before even touching the engine.
__________________
#7
Why bother with a 'mild' 383, in that case you might as well just build a good 355. You have to set some goals here before you waste a bunch of $$$ and not get what you want.
__________________
"A true lady takes off her dignity with her clothes and does her whorish best. At other times she can be as modest and dignified as her persona requires." \'96 IMP SS BBB ,Stock, airbox is swiss cheese, K&N filter, Ultra Flows. |
#8
If your going to do it do it right rebuilt your motor so you hopefully won't run into any problems later. What was causing the PO300?
__________________
96 BBB SS (#40,269 of 41,934) Cats, Flowmaster Exhaust, Drilled and Slotted Rotors, Eibach Springs, Corvette Fuel Rail Covers, new AC delco opti, msd wires, msd coil, K&N intake, grand prix gtp HUD 94 SS garage queen (#240 of 6303) 86 C10 Silverado 93 Caprice Classic SDN 2-tone (Sold)
#9
YAY! Taylor ThunderVolt 50's!!!
__________________
#10
Larger injectors come more ino play with ported heads/cam not necessairly just more CI. If you do head work than yes 30 lb min would be recommended. All this needing a tune. Quote:
In my case smog is a problem so I had to stay with a smaller cam that yields less "performance" than possible. CARB certified shorty headers also. Least exspensive path would be for the OP to stay 350 or 355 if he needs a .030 over bore which means new pistons but he could re-use stock rods & crank. Summit, and others, hace a complete "rebuild" kit with decent parts for a daily driver.
__________________
\'96 BBB 383/T-56 Last edited by BALLSS; 07-27-2011 at 02:53 PM. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
