Do I really have a December 13, 1996 build date B4U caprice? - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Concerns
Thread Tools Display Modes
  #1
Old 08-02-2011, 07:31 PM
Smith Chassis & Metalworks Smith Chassis & Metalworks is offline
Default Do I really have a December 13, 1996 build date B4U caprice?
I was curious and wanted to see the build month on my newley aquired caprice, to find out it was built in 12/96... upon running my vin with Compnine(not sure on accuracy of their service) it says that 94,594 caprices were built in 96, only 2 of them being optioned as is mine, but the biggest thing that jumped out to me was the build date of december 13, 1996... my vin sequence is 195005 sooo how does this add up if there were 94,594 made? Any insight would be appreciated, I think this is pretty neat!
__________________
ProBuilt suspension-manufacturer and distributor of quality air and hydraulic suspension components. Facebook.com/probuiltsuspension
Josh Jenkins coolcarsengineering@gmail.com
Smith Chassis & Metalworks-facebook.com/smithchassis 502-224-1384 cell
Old 08-03-2011, 04:23 PM
IGGY 96's Avatar
IGGY 96 IGGY 96 is offline
IGGY 96
Default
GM ran the 96 B-body lines at Arlington TX into 1997 to use up all inventory and fill all orders. The plant was switched over to truck production. Normally the model run would end in June or July.
__________________
96 DGGM 383 Stroker, Eagle rods and crank, Comp 503, Comp Pro Mags 1.6 rockers, iron ported heads, Weisco pistons, SLP headers, TPIS 52MM throttle body, Motive 373's, 4L60E Trans. by Performance Trans.,3400 stall, 2.5 Exhaust w/Hooker Aeros and Magnaflow hi-flo cats, Herter programming, Custom two tone Bonnies, custom trunk by Rawcustumz, Hifonics audio, rollin on 18" Enkei Infinitys with 275/40/18's and lots of other SStuff
  #3
Old 08-03-2011, 05:28 PM
Barbarossa's Avatar
Barbarossa Barbarossa is offline
Barbarossa is an unknown quantity at this point
Send a message via AIM to Barbarossa Send a message via Yahoo to Barbarossa
Default
read here: http://www.impalassforum.com/vBullet....php?p=2543253
12/13/96 was the last Impala SS.
I'm not convinced on the validity of the above post.
__________________
1996 DCM Impala SS
14.38 @ 93.48
Build Date: 1996-12-05
ISSCA # 2360
  #4
Old 08-03-2011, 10:39 PM
Default
I don't understand, does anyone have the true prodcutions numbers of the 96 caprice?
Its wild that my car was made after the last impala ss
__________________
  #5
Old 08-03-2011, 10:49 PM
impala79's Avatar
impala79 impala79 is offline
impala79 is an unknown quantity at this point
Thumbs up Last Caprices
I remember reading daily reports in 1996 from someone who reported daily on cars shipping from the plant; what was on the haulers...I remember the anticipation hoping that B-Bodies would somehow continue, and I sat on the edge of my chair reading the text only reports on the internet of old...The reports as I recall usually referenced Impalas and white 9C1's.
Alway wanted an Impala...I'm lucky I was finally able to get an LT1 wagon, but I had to wait a few years (2003, lol).
__________________
Greg
\'96 DGGM B4U, 147k - PMCAIS, Impala grille, wheels, and tail lights, SEO p/s cooler, slotted rotors, Hawk pads, Scott Mueller body bushing mounts, Bilstiens
\'95 Caprice Classic Wagon, MGR, 218k - PMCAIS, TB Bypass, SEO ps cooler, SEO hoses, WX3 wheels (in the summer) - Rest In Pieces 6/13/12 1630
\'83 Caprice Classic Wagon, 117k Rest in Pieces 10/23/05 1306
\'75 Caprice Classic Convt, 61K The original LT4 (400 SBC)
  #6
Old 08-04-2011, 08:42 AM
Navy Lifer's Avatar
Navy Lifer Navy Lifer is online now
Navy Lifer is an unknown quantity at this point
Default
Josh, you pose an interesting question, which it may be pretty difficult to get an accurate answer for.
Model sequence numbers generally follow a format of year (TR = 1996 Arlington production) followed by the 6-digit "VIN" assigned to a particular vehicle, which would NORMALLY start with (1)00001--early numbers for a model are generally pilot build and media use cars that are not sold to the public. Compnine says a total of 94594 Chevy B-body cars were built, so it's most curious that a car with VIN (1)95005 exists--that's another 411 VIN's, at least, that would seem to be "un-accounted" for, even though it's in the Compnine data base.
Even the celebrated "Last Built" Impala SS has a VIN of (1)94809--215 VIN's beyond the data supplied in Compnine--and I do believe more cars were assembled after the final Impala, even if they were not WX3's. It isn't clear whether (or how many) more B-body Chevy's were built past Dec 13 1996, but it is safe to say that the vehicle with VIN 95005 was one of the very last built in the production run. The declaration at the time that celebrated the "last Impala SS" built on the same day as you car was not to declare the production line closed, to my knowledge--there are people on this Forum that were there, and they may have more to add on the subject.
There's a couple of other possible/plausible explanations--the Compnine database in incomplete and/or erroneous, or, for some unknown reason, a significant number of VIN's were "skipped" through the 96 production run.
__________________
Bill Harper
ISSCA #127
inov8r@windstream.net
  #7
Old 08-04-2011, 02:19 PM
Louich's Avatar
Louich Louich is offline
Canadian Member
Louich is an unknown quantity at this point
Default
go to your car passenger side. Remove upholstery under the cushin you should find your build sheet that will specify build date, option specification and hour of order!
hopes this helps !
__________________
Louich
05 Tacoma TRD sport (daily beater!)
95 BBB WX3 (black widow eats engines like I drink beer)
3.73 w/ Eaton(400), H&R springs, Belltech Shocks, ZQ8 bump stops,CAI, CIA Tri-Y headers, Hi-flow, cats, 2.5 Spintech Pro Street Cat Back, PCM4less
born feb 23 at 7h58
  #8
Old 08-04-2011, 09:00 PM
MightyCaprice's Avatar
MightyCaprice MightyCaprice is offline
MightyCaprice is an unknown quantity at this point
Default
Just curious, what's the color combo on your car, as well?
Sean
__________________
Originally Posted by White Trash With Money aka 'Hugger View Post
i had a friend hold my nuts uptop. his hands were smaller.
Sean Collins
96 Civilian Caprice. Mostly suspension mods w/Home Depot CAI and Summit turbo muffs
95 Impala SS DGGM. K&N Intake, 2.5" Pypes catback with X-pipe. 92K miles purchased from original family
95 Caprice wagon DGGM. Homemade CAI, 2.5" catback with X-pipe. 3.73 rear end with Eaton posi. Bilstein 1104/0929's. "Street/strip" trans with 2500 stall torque converter. FOR SALE.
  #9
Old 08-06-2011, 08:19 PM
Default
Remove upholstery under what cushion?
Also the car is bright white with bright white trim, and tan leather interior
__________________
  #10
Old 08-08-2011, 12:38 AM
SIMPSON's Avatar
SIMPSON SIMPSON is offline
SIMPSON is an unknown quantity at this point
Send a message via AIM to SIMPSON
Default
post some pics
__________________
-1996 BBB
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
