#1
Has anyone had their digital cluster (speedometer, odometer, fuel gauge) go dark on them? It has just happened to me on my '96 Fleetwood. I took the cluster apart, but it isn't built like the Caprice cluster, the displays are soldered directly to the circuit board. Therefore, the contacts are not an issue. I'm hoping someone knows.
__________________
2005 Pontiac GTO |
| Sponsored Links | ||
Advertisement | ||
#2
Did you check fuses?
Possibly an illumination problem with your dimmer switch for interior lights? On other caddy forums I go to that is a problem with other year caddys that the display will just go out completely. People dont report back their solutions of course but many suggest checking fuses.
__________________
Known for slammin' Cadillac Doors! 1996 - Fleetwood Brougham Black on Black V4P 1983 - Coupe Deville - Street Custom Show Lowrider 1970 - Calais 4dr HT |
#3
Checked all the power fuses for the cluster. Its not the dimmer, either, as those illumination bulbs light up. My next step will be to pull the cluster (again; at least it's pretty simple to do) and make sure I'm getting power at the pins I should. If that doesn't work, the cluster is headed to United Radio for a rebuild.
__________________
2005 Pontiac GTO |
#4
If 93-96 clusters are the same, I have a 93 cluster for sale.
__________________
1991 OCC upgraded LO5, wrapped headers, dual Flowmasters, 3.23 posi, drop spindles & springs, Stainless full moons, 255/60/15 R, 215/70/15 F, Recaros, Nardi/MOMO SW w/QR, Pioneer DEH P77DH 1992 OCC now with 5.7 tbi For a parts list, check Plenty of good parts Old mechanic's saying: If it doesn't work, hit it with a hammer...if it still doesn't work, use a bigger hammer...if it breaks, it needed replaced anyway. |
#5
I'll keep it in mind, but I'm trying not to loose my mileage, so I'm leaning towards the rebuild.
__________________
2005 Pontiac GTO |
#6
Just as a follow-up, I sent my cluster off to United Radio. They diagnosed it as a bad power supply and also swapped out 2 transistors and a capacitor. It now works perfectly again!
__________________
2005 Pontiac GTO |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
