Replacing the 1-2 Accumulator Spring/Piston - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Drivetrain
Thread Tools Display Modes
  #1
Old 08-19-2011, 09:46 AM
QwkWx3's Avatar
QwkWx3 QwkWx3 is offline
QwkWx3 is on a distinguished road
Default Replacing the 1-2 Accumulator Spring/Piston
Early last month my transmission sprung a leak at the cooler line and I ended up running it low on fluid. I fixed the leak, flushed the fluid and all seemed well.
I've put about a thousand miles on the trans since then and over the last couple weeks I started noticing a delayed and soft 1-2 shift. This symptom was especially noticeable after i flushed the trans a second time earlier this week. All other shifts are relatively firm and quick, the 1-2 upshift seems to be the only problem.
All my research points to the 1-2 accumulator spring/piston assembly as the culprit. I found the following replacements from the Sonnax catalog.
Sonnax Pinless Accumulator Piston and Sonnax 1-2 Accumulator Spring
Are there any other parts needed?
From the diagrams it looks like an easy fix but I am a noob when it comes to transmissions so i gotta ask a few questions. I'm more worried about putting it back together than taking it apart. It looks like just two bolts holding the cover to the valve body. I don't have a tq wrench, can i just snug them and be safe?
Are there one or two springs in the piston assembly, the pic in the link looks like it has two springs on top of the piston?
The Sonnax instructions mention something about driving a checkball into the piston pinhole because the new one doesnt use a pin. Can someone elaborate on this?
All tips, comments, questions are welcome. Remember I've only been in the pan twice so I'm somewhat familiar, just need a little guidance.
Thanks in advance
__________________
96 BBB SS
Bolt-Ons, Superior Racing 4L60E, Edge 2800, MADTUNER Reflash....Still Slow
Old 08-19-2011, 07:35 PM
CapSS9C1 CapSS9C1 is offline
CapSS9C1
Default
The pinless pistons are good units but I recomment getting a replacement stock piston because they are known for wearing out where the pin goes thru them, transgo sells a good replacement piston, instead of using the stock piston seals get a set of viton seals, it includes all the piston seals and servo seals. Its a good idea also to replace the servo seals with these viton seals. ive seen a few trannies already having the same symptoms as yours and it turned out to be bad servo seals. The checkball theyre talking about replaces the pin in the accumulator housing so fluid dont piss out of the top of it. its simple just use a punch to pop out the pin thru the top, and press the ball in and stake the housing around the ball to hold it in. Transgo sells a sk4l60e or 4l60e hd2 shift kits that i highly recommend doing if your gonna go that far. providing your mechanical know how. its not bad to do. the hd2 kit comes with vb gaskets and all the springs and valves necessary to do the job. you will be very happy with it. how many miles on the tranny? feel free to ask more questions.
Ive come to learn a lot about the 4l60e lately because i went thru 3 trannies from an old vendor on this forum in 1 year, and decided to rebuild my own with a lot of upgraded parts and electronics, and so far so good with it.
__________________
Caprice 9c1, EFI Connection 24x conversion tuned with HP Tuners by me. TFS 185cc heads, 58mm BBK tb, 1 7/8 pro series stainless headers and 3 inch CIA Spintech exhaust, 3:73 gears, Eaton posi, 1.6rr Ultra pro Magnum rockers, GM 847 cam, Racetronix fuel pump and relay harness. #30lb injectors, Aeromotive FPR, Meziere electric wp, Magnecore 10mm wires, Garys cables and harnesses. Black Cloud Transmissions build 4l60e, 3400 converter.
  #3
Old 08-21-2011, 09:08 PM
sherlock9c1 sherlock9c1 is offline
Sophomore Member
sherlock9c1 can only hope to improve
Send a message via AIM to sherlock9c1
Default
Those two will likely be all you need. That said, what I've often seen is the yellow spring in the 1-2 accumulator cracks, unevenly loads the piston, then the piston cracks where the pin goes through and gets lodged in the bore. If the bore is scraped up, you'll need to buy another housing, but you can usually find those for $15 on ebay or at a local trans shop. A good used part is fine.
There are three 10mm bolts that hold the 1-2 accumulator housing against the spacer plate. Be very careful not to tear the paper gasket between the spacer plate and the accumulator - if you do, you will need to remove the valvebody to replace that gasket. Again, be very careful on that.
You might also consider doing the Sonnax 4L60E-HP-01 shift kit while you're in there. It's pricey, but it's well engineered and only a year old so the engineering is much more recent than the TransGo kits. I have personally talked with the designer of that kit and I'll just say he knows his stuff. It also includes pinless accumulator pistons and good seals for the servo.
Don't forget to read the sticky on "how to flush your fluid" and it'll show you a much cleaner way to drain your pan than the old "undo the bolts and let it all flow out one side" method.
__________________
"As I have gotten older, I have become much more patient with some things, and much less patient with other things." - sherlock9c1
  #4
Old 08-23-2011, 10:27 PM
QwkWx3's Avatar
Default
Thanks for the info guys. I found a good price on the Sonnax kit and at this point I am seriously considering having a local shop do the shift kit. I'm not scared of the job but at the end of the day if i ****ed something up I don't know that I'd recognize it and I can't afford to be throwing parts at the car.
I'll keep y'all posted.
__________________
96 BBB SS
  #5
Old 08-24-2011, 07:38 PM
QwkWx3's Avatar
Default
Had a local shop drop the pan and pull the 1-2 accumulator for me. For $50 out the door I figured it was well worth it.
Turns out it was NOT the accumulator piston/spring. The technician let me verify this myself. Both springs are intact and the piston is not cracked as Sherlock mentioned. As explained to me, it is likely that when i ran the unit low on fluid I burnt up the bands(apparently it doesn't take much to do this), and while the car is driveable I will eventually lose 2nd and 4th gear.
Looks like the SS will be hard parked until I come up with the money to rebuild it. Gotta pay to play I guess, and I didn't even break 13s lol
Thanks again to Sherlock and CapSS for your help.
__________________
96 BBB SS
  #6
Old 08-25-2011, 07:30 PM
SuperSport's Avatar
SuperSport SuperSport is offline
SuperSport is an unknown quantity at this point
Default
Don't throw in the towel just yet... How's the 3-4 shift? Does it shift softly (nearly too unnoticeable)? Previous suggestions are good ones.
I see you're not overly confident in working on the trans, but you could take time to check the servo assemblies. Make sure the servo seals are in tact. If not, a leaking seal around the 2nd gear servo may result in lack of fluid holding pressure buildup between the 2nd servo & piston housing. Then... I would look at the reverse input drum, along with the 2-4 band. An aged reverse input drum will likely have grooves in it. With that, the 2-4 band will become worn. If memory serves, those drums can be had for ~$70. Just a thought...
__________________
'86 Silverado C10 --- Bolt-on 5.3L/4L65E/Wheatley Tuned... SOLD 07/31/2009
'95 Impala SS (#1,245 of 18,365) --- It's alive, but not quite complete... SLOW PROCESS!
-SuperSport-
ISSCA #2476
  #7
Old 08-26-2011, 06:45 PM
QwkWx3's Avatar
Default
3-4 shift is still firm. What is involved in checking the servo assemblies?
__________________
96 BBB SS
  #8
Old 08-26-2011, 09:32 PM
SuperSport's Avatar
Default
Snap/Retainer ring holding the assembly in needs to come off. From there, the entire setup can be pulled out.
__________________
-SuperSport-
ISSCA #2476
  #9
Old 09-01-2011, 08:10 AM
QwkWx3's Avatar
Default
Just going to take it in for a rebuild, I'll post pics of the damage once its apart.
__________________
96 BBB SS
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
