Fuel pump wiring diagram * Please help * - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Electrical
Thread Tools Display Modes
  #1
Old 11-10-2011, 12:46 PM
Spartus.'s Avatar
Spartus. Spartus. is offline
Spartus. is an unknown quantity at this point
Default Fuel pump wiring diagram * Please help *
Does anyone have the wiring diagram for the fuel pump? I'm trying to figure out what the 3rd wire does. Is it a positive or a negative? Is it a signal wire to the PCM?
My OEM harness melted and I'm trying to re-wire things to get things running again. I have power to the pump, but the car won't start still. So I'm thinking the 3rd wire is a signal of some sort. Thanks.
__________________
-Tom Fish
SOLD to 95BLKSS
Golens Competition 383 Shortblock, Comp 503,Stage II CM heads, 4000 VIG. 4344 lbs.
12.55 @ 108, 1.78 60ft
Old setup: 350 HotCam
BEST 13.00 @ 105.48 NA, 12.00 @ 115.63, N20
Old 11-10-2011, 01:25 PM
RatSSled's Avatar
RatSSled RatSSled is offline
RatSSled has a little shameless behaviour in the past
Default
Black is ground.
Purple is from the Sender to the gauge.
Gray is power from the (fuel Pump Relay in the UEC)
Can't attach the diagram because it's too big. IM me you email and I'll mail it to you.
__________________
______________________________________________
96 BBB Impala SS - Stock with bolt-ons 12.82 @ 106
96 DGGM Impala SS - 496 BBC 10.13 @ 134 all natural, 9.69 @ 143 on the gun
  #3
Old 11-10-2011, 05:32 PM
Beast045's Avatar
Beast045 Beast045 is offline
Beast045 is on a distinguished road
Default
Quick question. When changing the fuel pump do you have to drop the gas tank?
__________________
'95 DGGM ISS - SOLD
'96 BBB ISS - Current
  #4
Old 11-10-2011, 05:40 PM
GoldSSWagon's Avatar
GoldSSWagon GoldSSWagon is offline
GoldSSWagon is an unknown quantity at this point
Default
Yes, you have to drop the tank.
__________________
1995 Gold Caprice Wagon
1991 White Caprice Wagon SOLD
1991 Olds Custom Cruiser Wagon Sold
1995 RMW under construction
2004 Impala SS
2012 Chevy Terrain SL2
1974 BD-5T WIP SOLD
  #5
Old 11-10-2011, 05:49 PM
Beast045's Avatar
Default
Thankss.
__________________
'95 DGGM ISS - SOLD
  #6
Old 11-11-2011, 12:46 PM
Spartus.'s Avatar
Default
I found the diagram in my FSM's. Thanks. It looks like the Fuel Pump fuse power more than the fuel pump. It also powers the PCM and the Oil pressure switch. Talk about a stupid setup. Why name it a fuel pump circuit if it also powers the PCM.
It looks like I'll have to remove the main engine harness from the car and repair it.
__________________
-Tom Fish
SOLD to 95BLKSS
  #7
Old 11-11-2011, 04:48 PM
RatSSled's Avatar
Default
The grey wire that powers the fuel pump goes through the inside pass through and into pos C2 of C204 (Engine to Body Harness), which should be behind or just above the PS kick panel. From there it goes into C400, which is in the trunk on the DS near the tail lamp. There is one other connection that is outside the trunk behind the license plate. You might want to check continuity between the different points to see where the break is before pulling the engine harness. It's most likely near the back of the car.
__________________
  #8
Old 11-11-2011, 04:53 PM
2TONCHEVY's Avatar
2TONCHEVY 2TONCHEVY is offline
2TONCHEVY
Default
Also check the fuel pump ground, in the trunk, on the DS hinge...
__________________
95 Caprice, LSx-LQ4 / 6.0,L92,L76.. front 20x9= 285-30-20 , Rear 20x12=345-25-20
http://www.cardomain.com/ride/456803
  #9
Old 05-20-2013, 09:19 PM
Samsauto Samsauto is offline
Junior Member
Samsauto is on a distinguished road
Default
I am looking for a wiring harness for a 2004 impala ss 3.8l supercharged motor. I'm changing my 03 to a supercharged motor. Please pm me if you have this please. I need the one for the engine and ECM
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
