Random Misfire PO300 - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > Forum Announcement > New Member Introductions
Thread Tools Display Modes
  #1
Old 11-14-2011, 09:51 PM
Joebucks Joebucks is offline
Junior Member
Joebucks is on a distinguished road
Default Random Misfire PO300
I have been having engine trouble for quite a while now. Car runs great when its cool. After about 30-40 minutes of driving I get the check engine light. Scan comes up with PO300 which is a random misfire. Car is mostly stock with minor upgrades. Some friends told me to replace the intake manifold gasket. WHat do you guys think?
Old 11-14-2011, 10:09 PM
Nassim Nassim is offline
Nassim is on a distinguished road
Default
I used to have the same Random Misfire (P0300) problem. Changed my wires and spark plugs (NGK IridiumIX), haven't had a problem since
__________________
96 Impala SS BBB - Original Owner Custom Modified - Lost to Hurricane Sandy on 10/29/2012
96 Impala SS BBB - Purchased 12/23/12 with 38K on odometer
67 Impala SS - Custom Modified
  #3
Old 11-14-2011, 10:14 PM
Junior Member
I already changed the plugs, wires, optispark and crank sensor.
  #4
Old 11-15-2011, 09:44 AM
angelo's Avatar
angelo angelo is offline
angelo can only hope to improve
Send a message via AIM to angelo Send a message via Skype™ to angelo
Default
First off Welcome Joebucks !!!
the helpful folks will see this if it's in the proper section ie.... problems/maintenance
Try and use this section to say Hey i'm new What's up !?
lastly i am guessing you have a 96 caprice cuz that's a obdII code, therefore instead of throwing parts at the car I suggest you get a scanner or take it to the shop so they can see what is happening when it goes from open loop to closed loop, as that is when you say the problem starts.
BTW my P0300 was #3 Fuel injector needed to be cleaned and i was fine after that....
Search P0300 and read a ton of threads about the various things that set that code.
GL
-ALF out....
__________________
ECIRS #427 ISSCA #01978
96 WX3 DGGM Bone Stock except Bilstein 0929/1104 odom fade mod, FB & HP delete, lower bushing mod,Stealth Brake Bolt mod,9C1 air dams,160 stat,TB-Bypass,Hi-Miler Hoses,Taylor wires,SStudio TB Boot & K&N,Bonnies,Pypes-X,Spintech Super Pro Streets
CLICK ME !!!
http://www.cardomain.com/ride/2386222/1
  #5
Old 11-17-2011, 10:41 PM
Junior Member
Default
Thanks Angelo. I have a 96 Impala. I'll try cleaning the injectors. If that doesn't work I'll try changing the intake manifold gasket.
Insurance
Random Question
You may post new threads
You may post replies
Forum Jump
(c) 2007-2014 Impala SS Forum
