Taillight lens removal - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91 thru 96 B-body Model Specific > Caprice
Thread Tools Display Modes
  #1
Old 11-17-2011, 01:01 AM
Caprisun92 Caprisun92 is offline
Junior Member
Caprisun92 is on a distinguished road
Default Taillight lens removal
Has anybody ever removed the lens of a the tail light to install new ones?? If so how do you do it?
Old 11-17-2011, 08:51 AM
Fred Kiehl's Avatar
Fred Kiehl Fred Kiehl is offline
Fred Kiehl is on a distinguished road
Default
It is done with great difficulty. You would be better off buying a used tail light, and just installing it. A used one is between $25 and $50, and will take you about 10 minutes to install. Removing the lens and getting a replacement from a used tail light will take you about 4 hours. Think about how you spend your time and money. You will have to buy the used one anyway.
__________________
1991 OCC upgraded LO5, LT1 cam, 46mm TBI, bored intake manifold, wrapped headers, true duals w/Flowmasters, 3.23 posi, flash to pass, drop spindles & springs, custom fender skirts, stainless full moons, Recaros, Blazer console, Nardi/wood SW w/QR, custom wood shift knob, Pioneer DEH P77DH
1992 OCC now with 5.7 tbi, DEH P77DH
For a parts list, check http://www.impalassforum.com/vBullet...1#post11691762
  #3
Old 11-17-2011, 10:52 AM
angelo's Avatar
angelo angelo is offline
angelo can only hope to improve
Send a message via AIM to angelo Send a message via Skype™ to angelo
Default
Sir,
if you still want to try i have 2 PASS side lights you can practice on.
here is the thread of me offering them but the guy never got back to me.
http://www.impalassforum.com/vBullet...d.php?t=265598
I can work with you on the price. they are boxed and read to GO !!!
-ALF out...
__________________
ECIRS #427 ISSCA #01978
96 WX3 DGGM Bone Stock except Bilstein 0929/1104 odom fade mod, FB & HP delete, lower bushing mod,Stealth Brake Bolt mod,9C1 air dams,160 stat,TB-Bypass,Hi-Miler Hoses,Taylor wires,SStudio TB Boot & K&N,Bonnies,Pypes-X,Spintech Super Pro Streets
CLICK ME !!!
http://www.cardomain.com/ride/2386222/1
  #4
Old 11-17-2011, 11:27 AM
96SSbbb's Avatar
96SSbbb 96SSbbb is offline
96SSbbb is an unknown quantity at this point
Default
http://www.sequentialtaillights.com/buckets.html
"Lens Bucket Modification
Another viable way to squeeze more light power out of the rear light system is to improve the reflective and focus properties of the lens reflector assembly (buckets). The red plastic lens can be separated from the bucket assembly by removing the red lens. It is not permanently sealed as a black rubbery putty is used along with a few plastic tab clips to hold the assembly together. Using a small flat knife, I was easily able to separate the lens from the bucket and remove the old sealant and clean up the joining channels for later reassembly. Once I separated the assemblies, I was disappointed in the overall quality and construction of the reflectors. Silver reflective paint sprayed over the plastic reflectors with small star impressed dimples for refraction is all that is in there. The paint literally wiped off in my fingers and did not have very good "reflective" properties on direct visual inspection. Below are some basic pictures of the before and after on a reflector bucket.
__________________
ISSCA# 930
  #5
Old 11-19-2011, 09:00 AM
The Tech's Avatar
The Tech The Tech is offline
The Tech is on a distinguished road
Default
It is a little time consuming but not that difficult. I did it about five years ago so I could remove the red plastic lens and install the clear set. On the Caprice the most difficult part is removing the chrome trim without breaking off the tabs that secure it. If your tails don't have the trim then it is just a matter of cutting through the sealing adhesive to get them off. I took my time sealing them for re-installation and have never had a problem with moisture.
__________________
1993 Caprice 9C1, Tilt Hood, Impala Grill, Ghost Flames, Flip/Flop Trunk, SS Grill with Blue SSLED Bowtie, Lowered, 18" Cragar SS Wheels, De-chromed rear, Retro LED Tails, Dual Exhausts, Bow Tie Exhaust Tips
1995 Caprice 9C1, Daily Driver, 235K miles. 9.65@73.5 mph in the 1/8 mile.
2011 Caprice 9C3, the new family car.
Vice-President, Carolina's Impala SS Motoring Association
  #6
Old 11-19-2011, 03:21 PM
Junior Member
Talking
Yea I did it took me about 4 hours but got it done thanks!!
  #7
Old 11-19-2011, 09:30 PM
ghetto wagon's Avatar
ghetto wagon ghetto wagon is offline
ghetto wagon is an unknown quantity at this point
Default
I RTV'd on lenses. Does anyone have any IDEA on how to remove that? I should have used 3m Strip caulking on reinstall. Gasoline might soften up RTV but might eat the lens too!
__________________
  #8
Old 11-25-2011, 10:40 AM
ejschultz's Avatar
ejschultz ejschultz is offline
ejschultz is on a distinguished road
Default
You could try baking them at about 100 degrees for a little while. The heat will soften the RTV. We did my friend's headlights in his Alero when he wanted to remove his amber reflectors (it's kinda like us getting clear corners). We also painted the bezel black in there while the lens was off. We then used a silicone based caulk to seal it off. It's been like that for about 5 years now with no problems with moisture. The only issue he has with the car now is a terrible rod knock. Someone's going to find a pretty neat set of custom Alero lights in the JY soon...
__________________
-94 Caprice Classic LS - system, Gary's wires, 200 amp alt, tint, first base/home plate delete, clear corners w/green parking lights, LTZ hood emblem, SS springs
-97 Grand Cherokee TSi - 4" IRO lift, OEM skids/hooks/hitch, sliders, 31s, rear locker, system, tint, cloth, clear corners, Magnaflow stuff
Refs: DesertDawg, 214Texas, QUICKSSILVER, SSon22s, MadMav, gary burton
  #9
Old 11-25-2011, 10:54 AM
Tx0ut1aw's Avatar
Tx0ut1aw Tx0ut1aw is offline
Tx0ut1aw is on a distinguished road
Send a message via Yahoo to Tx0ut1aw
Default
Me personally, I would go with the replacing the lens, cause its not hard at all, just a few hours depending on the quality of the seal you have on the taillights. On the Imp SS, the taillights have tabs to pull back and pry the lens off with something as simple as a screwdriver. I take it you want to change the color of your lens to a smoke or clear. After you have removed them you can buy the sealant at Autozone for under 7 bucks. At least try it out yourself, if you so happen to break it, then go the other route.
__________________
1995 Impala SS
LT1, 160k miles, 2.5 Exhaust, K&N Cold Air Intake, Func. Fiberglass Ram Air Hood,Smooth Polyurathane bumpers, Aluminum Performance Radiator, Mirror Gloss Blk Paint, Blisten Shocks,22in U2 Wheels,Clarion VX501 Navigation, 2 10" W6v2 w/ Memphis PRD1000.1 amp, and much more soon...
  #10
Old 11-25-2011, 11:38 AM
ejschultz's Avatar
Default
I forgot to mention, The Tech, I like how you kept the chrome around the clear tails. I've really wanted to get the smoked lenses, but I don't have the patience to sit there and remove the chrome without breaking it. Maybe one day it'll happen for me...maybe one day.
__________________
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
