Tire pressure question - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Wheels & Tires
Thread Tools Display Modes
  #1
Old 12-06-2011, 11:17 AM
Crime Scene 96's Avatar
Crime Scene 96 Crime Scene 96 is offline
Crime Scene 96 is on a distinguished road
Default Tire pressure question
I guess this question would apply to those up north, but what is an acceptable tire pressure setting for winter weather? My car is relieved of the door stickers with that information. I asked a forum member via facebook this same question and he provided me some information to include this forum amongst other websites. After spending a day or so reading, forum wise to the best of my knowledge no one has asked this question but the various websites says to stay with the factory settings.
I have 255 50 zr17 in the rear and 235 50 17 up front. What ive noticed is when i had the 235's in the rear before aquiring the 255's i had a problem traction wise when its wet outside. Since then with the 255's not so much if at all. So is it a game of physics by lowering tire pressure for better traction for the cold days? Better tires? Try to park the SS for the winter? Just looking for a little insight from those that "do" know first hand, because although we are not use to winter weather here in GA, the last couple of years have been pretty rough at times and painful.
__________________
1996 Chevy Impala SS BBB -
R.I.P. 4/15/2012
1996 Chevy Impala SS DGGM -
Replaced BBB on 4/30/2012
Old 12-06-2011, 11:55 AM
KW Baraka's Avatar
KW Baraka KW Baraka is offline
Location: South Central Texas....By Way of the South Side of Chicago!!!!!
KW Baraka has a little shameless behaviour in the past
Default
Originally Posted by Crime Scene 96 View Post
I guess this question would apply to those up north, but what is an acceptable tire pressure setting for winter weather?..........I have 255 50 zr17 in the rear and 235 50 17 up front.........is it a game of physics by lowering tire pressure for better traction for the cold days? Better tires?.......
Quality all-weather tires are a big step in the right direction. Optimal air pressure is an important issue as well.
But......more specificity from you would be a good thing, too.
Are you JUST wanting to know about cold weather?
Are you wanting to know for cold and 'wet' (40'ish degrees) or cold and snowy (20-ish degrees)?
FWIW, the recommended tire pressure with the 255/50/17's (Impala SS) was 32 PSI. I normally ride at about 36-37 PSI. But.....I'd drop that pressure for snowy, winter driving to the 32 PSI range......If I had to drive in the snow (I'm from Chicago so I've had my share of driving on snow ).
Otherwise.....if you're just concerned about cold (40'ish) and wet driving.....well, I'd still have 36-37 PSI in my tires.
YMMV, of course .
KW
__________________
1996 BBB SS, 398ci Solid Roller LT4
1995 DCM SS, Heads/Cam LS3
2014 Chevy SS; 429ci LS3 -- 508HP, 455TQ @ the wheels....track results pending
  #3
Old 12-06-2011, 01:31 PM
Default
Im sorry shouldve been more clear. Im asking in reference to snowy, and rain/icy weather... If temps here can stay above *35 degrees while raining, then im good concern wise. But its those night time temps with the added wind which freezes the wet pavement that concerns me a little. Really the snow driving isnt too bad, as long as when it melts, it melts to water completely. This year when it snowed, it started thawing in day light, but frozen over night which caused crazy sheets of ice, and put me on the shelf as a result.
__________________
R.I.P. 4/15/2012
  #4
Old 12-06-2011, 01:45 PM
kiddpitt kiddpitt is offline
kiddpitt is on a distinguished road
Default
Maybe you want these?
On a serious note, I've never adjusted my tire presurre for winter/cold weather and I've been up north my whole life. Just be careful and know the dangers.
  #5
Old 12-06-2011, 11:06 PM
Black-SS Black-SS is offline
Black-SS is on a distinguished road
Default
Are you having any ABS problems since your rear tires are taller than your fronts? And why aren't you running 255-50-17's up front? I try to keep my psi around 35. In my Camaro, I run 40F and 30R.
  #6
Old 12-07-2011, 11:37 AM
k gee's Avatar
k gee k gee is online now
k gee has a little shameless behaviour in the past
Default
WTF? That's a huge difference!
Is that just for winter snow/ice?
__________________
96 Caprice B4U
96 RMW Collector's Edition
www.cali-ss.com The cars unite us, the people make us come back.
  #7
Old 12-07-2011, 01:54 PM
Default
When i bought this car last year, it came with 235's on it. Ive been wanting the 255's that it was equipped with from the factory. So far i only have 2. I will get 2 more around tax time which should be soon.... ABS light was already on when i bought the car. Dont know why, and dont care really cause if its any benefit of having the whole system removed, its coming off. Otherwise i will get it fixed one day, as long as the daggum car stops.
__________________
R.I.P. 4/15/2012
  #8
Old 12-07-2011, 03:09 PM
angelo's Avatar
angelo angelo is offline
angelo can only hope to improve
Send a message via AIM to angelo Send a message via Skype™ to angelo
Default
here's the stock info
i like 35 PSI all around... mileage is good, tire wear is good, handling is good.
tire choice is the biggest factor to help yourself in winter driving weather.
-ALF out...
__________________
ECIRS #427 ISSCA #01978
96 WX3 DGGM Bone Stock except Bilstein 0929/1104 odom fade mod, FB & HP delete, lower bushing mod,Stealth Brake Bolt mod,9C1 air dams,160 stat,TB-Bypass,Hi-Miler Hoses,Taylor wires,SStudio TB Boot & K&N,Bonnies,Pypes-X,Spintech Super Pro Streets
CLICK ME !!!
http://www.cardomain.com/ride/2386222/1
  #9
Old 12-07-2011, 04:34 PM
Default
Thanks a lot, that was a big help from all of you. But those stickers really showed me what i needed mostly. Do you guys know who can make replacements with or without vin info?
__________________
R.I.P. 4/15/2012
  #10
Old 12-08-2011, 01:05 AM
KW Baraka's Avatar
Default
......Do you guys know who can make replacements with or without vin info?
Check with a GM dealership (the parts department). If you're lucky, they can do a label.....or point you in the right direction.
KW
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
