Headlight Adjustment Help - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > 91-96 Impala/B-body > Electrical
Thread Tools Display Modes
  #1
Old 12-06-2011, 04:46 PM
kiddpitt kiddpitt is offline
kiddpitt is on a distinguished road
Default Headlight Adjustment Help
I feel real stupid for not being able to figure this out...but how the hell do I do the side-to-side adjustment on stock headlights for a 96 Impala?
Old 12-06-2011, 05:28 PM
350 350 is offline
350 is an unknown quantity at this point
Send a message via AIM to 350
Default
The only adjustment is up/down.
__________________
95 DGGM SS. Cam and headers, boring stuff, classic tags, garaged
15 Durango R/T AWD, Fiat with a Hemi and 8 gears
07 Wimpala Super 44, CAI
  #3
Old 12-07-2011, 06:24 AM
Default
Thanks 350
  #4
Old 12-07-2011, 10:24 AM
1slow96's Avatar
1slow96 1slow96 is offline
1slow96 is on a distinguished road
Default adjust headlights
On my 96 Impala the headlights are adjusted to the right, or left by turning a long,plastic 10mm nut on the side of the headlight assembly extending to the rear. Turning this nut moves the inside edge of the headlight in,or out. In effect moving the beam of light right,or left. Hope this helps.
  #5
Old 12-07-2011, 10:40 AM
350 350 is offline
Default
Weird I never noticed that.
__________________
  #6
Old 12-07-2011, 11:31 AM
GA95DCMSS's Avatar
GA95DCMSS GA95DCMSS is offline
GA95DCMSS
Send a message via Yahoo to GA95DCMSS
Default
That is correct. Alot of people don't know this. (see above lol)
__________________
Quentin-1995 Impala SS-6.0L LQ4-222/226-L92 Heads.PB: 1.75 60ft 12.70 @ 107.75 so far
  #7
Old 12-07-2011, 12:16 PM
Default
I spent 45 minutes messing with that black plastic nut the other day and it didn't seem to affect the headlight. There's a small threaded rod that goes from the 10mm nut toward the 2 torx screws. The small silver screw goes into a hole in the rod, the black screw tights the rubber that seems to hold the light in place. I figured turning the black nut would move the rod....but it wasn't.
I loosened the black torx screw & turned that black nut righty-tighty & lefty loosey, with that silver screw in place and with the silver screw removed & couldn't get it to do anything. What am I actually supposed to do??
  #8
Old 12-07-2011, 12:47 PM
1slow96's Avatar
The pivot point maybe stuck. Some gentle encouragement in the direction you want to go may free it. There may be some play in the two body bolts which attach the assembly to the core support,or the vertical bolt hidden behind the marker light. GOOD LUCK.
  #9
Old 12-07-2011, 03:18 PM
Mr pogo's Avatar
Mr pogo Mr pogo is online now
Mr pogo is on a distinguished road
Default
I vaguely remember a couple screws on the inner side of each headlight that traveled in slots, I think they may have to be loosened first before adjusting.
__________________
evil T-47 seatbelt bolts and cutdown ZQ8 bumpstops, Kore3 front brakes, TB bypass, Dynotech DS, F-body EGR, Meziere WP, Comp Cams 1.6RR/CM springs, trans by Moi Industries, Yank 3600, Earls trans cooler/rad cooler delete/Derale t-stat, RAISS, SLP headers, SLP injectors, pypes X-pipe/magnaflows, Borgeson shaft, Hotchkis springs, PPM front stuff, Metco rear arms, Clear Image DS loop/trans crossmember, 3.73s, eaton posi, Hypertech for smog \"[<img BH tuned PCM
  #10
Old 12-07-2011, 03:26 PM
1slow96's Avatar
Default
If you are referring to the small torx screws, I have messed with them in the past to no avail.
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
