Best way to run power wire into the cabin? - Chevy Impala SS Forum
Impala SS Forum
Go Back   Chevy Impala SS Forum > Audio/Video/Security > Audio
Thread Tools Display Modes
  #1
Old 12-06-2011, 09:53 PM
chapel's Avatar
chapel chapel is offline
chapel is on a distinguished road
Default Best way to run power wire into the cabin?
Just curious, what's the best way to get power wire into the car? Is there any existing firewall grommets that are big enough to safely feed wire through?
__________________
1995 Buick Roadmaster Limited Estate Wagon
BATTLE WAGON
Old 12-06-2011, 10:43 PM
6spdImpala 6spdImpala is offline
6spdImpala is on a distinguished road
Default
On the engine side of the firewall. Under the brake booster pull the foam junk foward and its 8-10 inches below the booster. youll see an oval shaped plug about the size of your thumb
  #3
Old 12-06-2011, 10:53 PM
ejschultz's Avatar
ejschultz ejschultz is offline
ejschultz is on a distinguished road
Default
^^^This. It's large enough for a single run of 1/0. I also managed to squeeze the wire for my siren for my alarm through it. It's easily accessible from the inside of the car as well. The only downside to it is it's on the driver side and the battery is on the passenger side. I had to run a full 20 foot package of 1/0 to reach the trunk.
__________________
-94 Caprice Classic LS - system, Gary's wires, 200 amp alt, tint, first base/home plate delete, clear corners w/green parking lights, LTZ hood emblem, SS springs
-97 Grand Cherokee TSi - 4" IRO lift, OEM skids/hooks/hitch, sliders, 31s, rear locker, system, tint, cloth, clear corners, Magnaflow stuff
Refs: DesertDawg, 214Texas, QUICKSSILVER, SSon22s, MadMav, gary burton
  #4
Old 12-06-2011, 11:05 PM
chapel's Avatar
Default
thanks.
where's a good grounding point in the trunk of the wagons?
__________________
BATTLE WAGON
  #5
Old 12-07-2011, 05:22 AM
ejschultz's Avatar
Default
You could ground to a seatbelt bolt. You'd have to make sure you clean all the sticky stuff off the bolt. GM used a "gummy" sticker then put the bolt through that to create a seal. If you really want to do it right, ground it to the seatbelt bolt and crawl underneath the car and ground that seatbelt bolt the the chassis. Or, you could find an inconspicuous place to drill and run the ground wire directly through the floor to the chassis. I'd personally rather not drill a hole like that though. That's why I'd rather ground the back side of the seatbelt bolt to the chassis.
__________________
  #6
Old 02-07-2012, 09:49 PM
chapel's Avatar
Default
I'll have to see how much cable I have... didn't occur to me that I'd need to run 20' of cable... most cars aren't that long
__________________
BATTLE WAGON
  #7
Old 02-08-2012, 11:18 AM
Capriceboi's Avatar
Capriceboi Capriceboi is offline
Capriceboi is on a distinguished road
Default
Hey I have always gone through the passenger side. If you pull back the carpet and firewall on the inside i do believe there is a spot there that takes you right into the engine bay under the AC lines. Or maybe I drilled it, I forget but worth checking!
__________________
Reppin' that East Coast
  #8
Old 02-08-2012, 11:21 AM
96hvychvySs's Avatar
96hvychvySs 96hvychvySs is offline
96hvychvySs is on a distinguished road
Default
I have a 17' Rockford kit..just run on the passenger side..my pics and write up
http://www.impalassforum.com/vBullet...d.php?t=268975
  #9
Old 02-08-2012, 01:49 PM
stills's Avatar
stills stills is offline
stills is an unknown quantity at this point
Default
1/o on the drivers side:
inside:
trunk:
  #10
Old 02-10-2012, 10:56 PM
chapel's Avatar
Default
awesome pics. thanks for the assist
__________________
BATTLE WAGON
Insurance
Random Question
Forum Jump
(c) 2007-2014 Impala SS Forum
